help with ad pic16f88
Results 1 to 10 of 10
    Jan 2013
    Default help with ad pic16f88
    Hi all, please help me, the example program page on the PIC16F88 ad converter did not work,
    shows me error ANSEL =% 00010000
    Greetings!
    Default Re: help with ad pic16f88
    WHICH example program ?, what page ? which 16F88 ? ...
    please show your program listing here ...
    so we can answer you something useful else than " may be it will rain, may be sun will shine tomorrow " ...
    Apr 2011
    Welches, Oregon
    It may be as easy as removing the [SPACE] between the percent symbol and the binary value as : %00000000. I don't know that, because (as Alain suggests) I have seen neither the code nor the error, but I am foolish enough to risk a guess!
    Here is MPLAB Answer for this ghost space ...
    WARNING Line 38: Bad token "%".
    C:\PROGRAM FILES\MICROCHIP\MPLAB IDE\PROJETS\TWINAIR_LIGHTS3.BAS WARNING Line 38: 01110000 Malformed binary numeric, value truncated.
    Loaded C:\Program Files\Microchip\MPLAB IDE\Projets\Twinair_Lights3.COF.
    BUILD SUCCEEDED: Sun Apr 13 16:06:36 2014
    just a WARNING ... but compiling still occurs ...
    note the generated HEX shows $70 for right scripting and $F0 for the wrong script
    Jan 2013
    Hi, this is the code sample page of melabs,
    Error when compiling throws me online 23
    what happens?
    Greetings!
    ' Name : ADCX18.pbp
    ' Compiler : PICBASIC PRO Compiler 2.6
    ' Assembler : PM or MPASM
    ' Target PIC : PIC16F88 or similar
    ' Hardware : LAB-X18 Experimenter Board
    ' Oscillator : 4MHz external crystal
    ' Keywords : ADCIN, LCDOUT
    ' Description : PICBASIC PRO program to read potentiometer on LAB-X18
    ' and display on LCD.
    ' Define LCD pins
    Define LCD_DREG PORTA
    Define LCD_DBIT 0
    Define LCD_RSREG PORTB
    Define LCD_RSBIT 6
    Define LCD_EREG PORTB
    Define LCD_EBIT 3
    ' Allocate variables
    x Var Byte
    ANSEL = %00010000 ' Make the pot input analog and rest digital
    CMCON = 7 ' Set PORTA to digital
    Pause 100 ' Wait for LCD to start
    mainloop:
    Adcin 4, x ' Read the pot
    Lcdout $fe, 1, "pot=", #x ' Send value to LCD
    Pause 100 ' Do it about 10 times a second
    Goto mainloop ' Do it forever
    Sep 2010
    Las Vegas, NV
    Just FYI "CMCON = 7 ' Set PORTA to digital" actually turns off the comparators and doesn't set the ports to digital.
    It also looks as if you need to set the ADCON bits 3-5 also to use ports as analog inputs.
    Shouldn't this "Lcdout $fe, 1, "pot=", #x ' Send value to LCD" read "Lcdout $fe, 1, "pot=", DECx ' Send value to LCD"? I [U]think[U] the # returns ASCII and NOT decimail numbers. Which may or may not be what you are seeking.
    Best wishes
    Jan 2013
    thanks, proves what you suggest and I'll tell you then,
    Greetings!
    Jan 2013
    Hi all, this code works with adc pic, thanks for your help,
    Greetings!
    DATO VAR BYTE
    CMCON=7
    DEFINE ADC_BITS 8
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    ANSEL=%0100000
    LED VAR PORTB.0
    HIGH LED
    PAUSE 100
    LOW LED
    PAUSE 200
    INICIO:
    ADCIN 5,DATO
    LCDOUT $FE,$C4,DEC dato
    PAUSE 300
    GOSUB INICIO
    You probably want GOTO, not GOSUB.
    Jan 2013
    Thanks, that's the right way.
    I'm working with a lm35z converter pic with 8 bits, as I can convert the value to degrees Celsius gives me?
  1. ISD17240 on PIC16F88
    By drewcog in forum mel PIC BASIC Pro
    Last Post: - 17th December 2008, 21:07
  2. Pic16f88
    By nonny in forum mel PIC BASIC Pro
    Last Post: - 20th November 2007, 15:10
  3. Pic16f88
    By jcleaver in forum mel PIC BASIC Pro
    Last Post: - 28th March 2007, 23:27
  4. Pic16f88
    By Maurice in forum mel PIC BASIC Pro
    Last Post: - 17th November 2005, 22:46
  5. Pic16f88
    By Maurice in forum General
    Last Post: - 19th May 2005, 21:35
