PicBasic Pro 16F628A Clock speed help !
Results 1 to 11 of 11
    Default Re: PicBasic Pro 16F628A Clock speed help !
    I'm curious why you would want to slow the PIC to 48 kHz. What requirement prevents you from running at 4 MHz?
    It might be easier to run everything at 4 MHz and tweak whatever specific logic you want to simulate 48 kHz.
    Battery conservation, perhaps?
    May 2012
    Merseyside, UK
    Yes…. Am attempting to use a pic in field from solar sources… so saving power is a premium !!!
    Miami, Florida USA
    Quote Originally Posted by andybarrett1 View Post
    This is from the datasheet
    Standby Current:
    - 100 nA @ 2.0V, typical
    • Operating Current:
    - 12μA @ 32 kHz, 2.0V, typical
    - 120μA @ 1 MHz, 2.0V, typical
    You can put the chip in standby mode and wake the chip up when needed using interrupts.
    Anonymous
    May 2012
    Merseyside, UK
    I Never thought of interrupts.... Even Better!!!
    Thank you
    Sep 2010
    Las Vegas, NV
    Not interrupts but SLEEP or NAP. Interrupts keep the clock running but with SLEEP and NAP it all shuts down for a selectable period of time, wakes up, does its thing and goes back to sleep.
    The data sheet I saw said 1uA at 3.3V so you may get down that low if you work at it.
    It also looks like this chip has LED driver pins. Maybe you should look at a different chip for your more specific needs.
  1. Picbasic pro speed issues?
    Last Post: - 27th July 2013, 17:09
  2. Replies: 2
    Last Post: - 25th July 2012, 03:19
  3. Replies: 2
    Last Post: - 1st May 2009, 09:23
  4. LED CLOCK using 16F628A
    By bentech4u in forum mel PIC BASIC
    Last Post: - 4th November 2008, 22:27
  5. clock speed
    By Armando Herjim in forum General
    Last Post: - 30th November 2006, 13:25
