help with random pause times; PIC16f88
Results 1 to 5 of 5
    Default help with random pause times; PIC16f88
    I'm working on a school project, and this is the first time the course has been taught at my small university. Naturally, the professor is from the Apollo age, and the TA isn't too much help.
    Using a PIC16F88, I want to make a simple program that illuminates an LED and displays a count from 0-9 on a small 7 segment LED display that increases each time the LED flashes. I have the ability to write this type of code, but my main goal is to insert a pause in between the LED lighting up and the counter increasing. I want this pause to be random, and if the pause duration is <= say, 900, the program goes to a Sub that prompts the user to manually reset the program and begin again.
    I have been able to somewhat get an idea of how to generate a random byte using the resources on the forum already.
    Something like...
    MyWord var Word
    MyByte var Byte
    Random MyWord
    MyByte=(MyWord//9)+1
    pause (Mybyte * 100)
    If (Mybyte == 9) Then
    GoTo errorloop
    Endif
    Is this type of math operation allowed when using pause?
    Apr 2011
    Welches, Oregon
    Default Re: help with random pause times; PIC16f88
    I believe you can. I was unable to (quickly) find an example to verify, but it should not take but a moment to try it.
    I think that one of the reasons I was unable to find an example is that long pauses are often avoided because the processor does nothing during a pause but spin a tight, uninterruptable, loop. Most often pauses are kept short purposely, during longer waits other constructs or functions are used to fill the time - such as NAP or SLEEP - that put the processor into low power mode.
    Consider: Pause 10000. For approximately 10 seconds nothing happens. Any display is not updated, any serial communications fail, no user input will be serviced, and no interrupts are processed. All that is going on is that the processor is burning thru (battery most significantly) power without any other purpose but to wait.
    Now:
    For LP0 = 0 to 9 'Loop 10 times (Loop 10 times (Loop 10 times))
    For LP1 = 0 to 9 'Loop 10 times (Loop 10 times)
    For LP2 = 0 to 9 'Loop 10 times
    Pause 10 'Pause 10
    Next LP2
    Next LP1
    Next LP0
    In this example the processor pauses an equivalent time, but interrupts can be serviced (between the much shorter pauses) and, by inserting code inside the outer loops, buttons can be checked, displays updated...
    Typically, when there is truly nothing for the processor to do, delays are managed with functions that put the processor "to sleep" so as to save power. In your case, this has the added benefit that these functions are not particularly accurate - thus adding a random element to their timing.
    One last...
    For no particular reason, you may consider a construct to make a loop of a known duration, then call the loop a random number of times, as:
    Toggle LED
    For RandomDuration = 0 to (RandomNumber between 1 and 10)
    Gosub PauseTime
    Next RandomDuration
    Goto Main
    PauseTime:
    For LP1 = 0 to 9
    For LP2 = 0 to 9
    Pause 100
    Next LP2
    Next LP1
    The only advantage I see in this scheme is that the random waits will be (likely) clearly different in duration between one and the next, where straight random pauses may vary by hundreds or even thousands of cycles and not be noticeably different in duration to the user.
    HTH,
    Another Buzz Aldrin
    Last edited by Amoque; - 27th April 2014 at 13:22. Reason: Extraneous prepositional faux pas
    Ah! Does that mean I was on the "right" track with my original idea? Although it does sound very inefficient. I'm just looking for something simple that works on a breadboard and power supply situation, as we have a limited time to do the project.. unfortunately.
    I liked your second example and it got me thinking...
    Would it be better (in my case) to have loops; say, 0-9, each loop contains a different pause duration between lighting the LED and updating the display, I would have the main loop call a random number 0-9, which would go to each loop.
    Let's see if I can mock it up...
    MyWord var Word
    MyByte var Byte
    mainloop:
    Random MyWord
    If (MyByte == 1) Then
    GoTo loop1
    EndIf
    If (MyByte == 2) Then
    GoTo loop2
    EndIf
    If (Mybyte == 3) Then
    GoTo loop3
    ;this continues to MyByte == 9
    If (MyByte == 9) Then
    GoTo errorloop ;error loop displays "E" on the LED display and waits for the user to press the reset button
    loop1:
    High led1
    GoSub updatepins ;updates the display with the count, (not included yet in example)
    Low led1
    the loops would increase in pause duration of course. I hope I am on the right track here. I still have a couple days to complete this, but aside from one introduction to C# class, this is the first time I've had any experience with coding.
    Apr 2011
    Welches, Oregon
    In every project there are a myriad ways to accomplish the goal. If what you conceive meets your goal and is within your skill level - I count that as success! I'd say, yes... you were on track.
    The purpose of the "PauseTime" subroutine is to demonstrate how a long pause may be achieved without paralyzing the processor for undue lengths of time. It is FUNCTIONALLY equivalent to Pause 10000. It is not "better" in your case, only offers advantage when other processes require service.
    First priority is to complete your assignment on time - do that using the method you understand best; I have no wish to derail your train of thought, only to explain why long pauses are not well illustrated by random example. I really enjoy the opportunity to payback some of the help I have received here, but I don't wish to influence your design decisions. Ask whatever you like, I'll (and many others likely) will try and help, but please don't let me be a distraction to your instructor's curriculum.
    That said, my approach would be to write a subroutine that provides a simple pause of a minimum acceptable length then, call the routine multiple times to provide a random factor, except in the case of "9" where you branch to the error handling routine.
    Generate random number
    If number is 9 goto Errorhandler 'If our random number is 9 GOTO where we deal with it
    This part only happens when our random is NOT 9
    Display the random number
    For Delay = 1 to Random number ' Use the variable Delay as a counter from 1 to our random number.
    gosub delay 'Go find our pause
    Next Delay 'If Delay < our random number, +1 to Delay then go back and pause again
    Goto Main 'do it all over
    Delay:
    pause 1000 'this is the shortest pause, we'll do this once if our random number was 1, three times if it was 3....
    Return 'go back to the line after the gosub
    ErrorHandler:
    Here's where we do whatever we want to happen when 9 is the random number
    Dispay an "E"....
    Goto Main: 'Go back to "Main", generate a new random number and start over
    Do you follow the logic here? The Main loop picks a number, if that number is nine, it leaves the loop for Errorhandler to handle the special case. Otherwise, it displays the number before the "For Delay" loop pauses 1 second "RandomNumber" times. Goto Main starts the process again. What the user will see: A random number, then a pause of equal number of seconds, another random number will appear and another pause of equal seconds... If a nine is our random number, an "E" appears and whatever else you code in errorhandler. Once the errorhandle coder is completed another number is generated, appears on the display, and the pause begins.
    Good ideas, but as stated, make it so it fulfills your needs.
    If your mcu does nothing else, PAUSE with a random number works. If your project will evolve, then it might be worth the effort to implement the ideas above.
    I'd go for simple, a random number between 1 and 9, multiply by 200. This gives a range of .2 - 1.8 seconds.
  1. 16F777 resetting - at seemingly random times
    By orjon1 in forum mel PIC BASIC Pro
    Last Post: - 25th June 2011, 02:47
  2. Drive relay between two times
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 15th December 2009, 09:19
  3. Instruction times
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 5th June 2009, 09:16
  4. pic18f252 hserout some times is incomplete
    By edysan in forum Serial
    Last Post: - 20th June 2006, 23:55
  5. Strange HSEROUT execution times
    By SteveB in forum mel PIC BASIC Pro
    Last Post: - 21st May 2006, 18:34
