Just FYI "CMCON = 7 ' Set PORTA to digital" actually turns off the comparators and doesn't set the ports to digital.
It also looks as if you need to set the ADCON bits 3-5 also to use ports as analog inputs.
Shouldn't this "Lcdout $fe, 1, "pot=", #x ' Send value to LCD" read "Lcdout $fe, 1, "pot=", DECx ' Send value to LCD"? I [U]think[U] the # returns ASCII and NOT decimail numbers. Which may or may not be what you are seeking.
Best wishes
