WHICH example program ?, what page ? which 16F88 ? ...
please show your program listing here ...
so we can answer you something useful else than " may be it will rain, may be sun will shine tomorrow " ...
It may be as easy as removing the [SPACE] between the percent symbol and the binary value as : %00000000. I don't know that, because (as Alain suggests) I have seen neither the code nor the error, but I am foolish enough to risk a guess!
Hi, this is the code sample page of melabs,
Error when compiling throws me online 23
what happens?
Greetings!
' Name : ADCX18.pbp
' Compiler : PICBASIC PRO Compiler 2.6
' Assembler : PM or MPASM
' Target PIC : PIC16F88 or similar
' Hardware : LAB-X18 Experimenter Board
' Oscillator : 4MHz external crystal
' Keywords : ADCIN, LCDOUT
' Description : PICBASIC PRO program to read potentiometer on LAB-X18
' and display on LCD.
' Define LCD pins
Define LCD_DREG PORTA
Define LCD_DBIT 0
Define LCD_RSREG PORTB
Define LCD_RSBIT 6
Define LCD_EREG PORTB
Define LCD_EBIT 3
' Allocate variables
x Var Byte
ANSEL = %00010000 ' Make the pot input analog and rest digital
CMCON = 7 ' Set PORTA to digital
Pause 100 ' Wait for LCD to start
mainloop:
Adcin 4, x ' Read the pot
Lcdout $fe, 1, "pot=", #x ' Send value to LCD
Pause 100 ' Do it about 10 times a second
Goto mainloop ' Do it forever
Just FYI "CMCON = 7 ' Set PORTA to digital" actually turns off the comparators and doesn't set the ports to digital.
It also looks as if you need to set the ADCON bits 3-5 also to use ports as analog inputs.
Shouldn't this "Lcdout $fe, 1, "pot=", #x ' Send value to LCD" read "Lcdout $fe, 1, "pot=", DECx ' Send value to LCD"? I [U]think[U] the # returns ASCII and NOT decimail numbers. Which may or may not be what you are seeking.
Best wishes
