Slow speed tachometer
Results 1 to 10 of 10
    Dec 2011
    IO93ok
    Default Re: Slow speed tachometer
    I think you need to increase the resolution to increase the accuracy of the pulse read before 1 minute is up.
    Why deal with 36 pulses per minute ? I don't know how you are breaking the IR beam but maybe you could add extra pulses using extra beam breaks.
    1 pulse per revolution of conveyer "drum" wheel could be multiplied up to 10 pulses per revolution or whatever using more beam breaks on the "drum" ? Easier to read a RPM during the one minute period.
    Just thoughts.
    Rob.
    The moment after you press "Post" is the moment you actually see the typso
  1. Tachometer with DT Interrupts?
    By DanPBP in forum mel PIC BASIC Pro
    Last Post: - 17th November 2009, 20:51
  2. Tachometer with Interrupts
    By serkanc in forum mel PIC BASIC Pro
    Last Post: - 28th August 2009, 09:10
  3. tachometer
    By aztaig in forum mel PIC BASIC
    Last Post: - 11th August 2008, 14:54
  4. Tachometer code problems.
    By PICy in forum mel PIC BASIC
    Last Post: - 28th January 2005, 16:29
  5. Tachometer code problems.
    By PICy in forum General
    Last Post: - 31st October 2004, 12:47
