Code programming error at 0000
Results 1 to 40 of 42
    Quote Originally Posted by Bruce
    The splash screen is on all the download versions of MeLabs programmer software. It shouldn't affect operation.
    Good, one hting less to worry about. I'm so confused I can't even remember how I got rid of that last time I upgraded.
    Can you program the device you're having problems with in the programmer zif socket?
    I would have, but this is SOIC.
    Quote Originally Posted by MisterE
    how about if you disconnect what is on PGD, PGC,PGM pins then, use a 100-1K resistor to gnd on PGM?
    I will try straight to 0V, I think that is what I read last night in the Help, gotta check up on that.
    Try to place your Programmer far of your PIC
    I think you meant close, and I did, no difference.
    No i really meant far... not a mile away.. few inches 6-12 inches. i had some issue like that before on breadboard when a programmer was to close of the PIC... kind of interference or sort of...
    At first it was about 6-12 inches of combined cables and traces, now 4-6 inches, no difference.
    So I got another unit and soldered thru-hole components directly onto the legs and everything worked fine for several programming cycles. At least I know the programmer can indeed program a 16F628A SOIC in-circuit (not that it should make any difference from a PDIP unit).
    I will replace the oscillator and capacitors on the circuit. If that doesn't make a difference I will solder this 'working' unit onto the circuit.
    By the time I removed the 'working' 16F628A from the temporary circuit I totally forgot about the plan to replace the oscillator first.
    I removed the unworking 16F628A from the circuit and put in the tested unit and everything fired up as expected. I was able to reprogram it several times too, so no idea what was the exact cause of the problem.
  1. Code doesn't work on 16F648A
    By Mr_Joe in forum mel PIC BASIC Pro
    Last Post: - 1st September 2018, 22:09
  2. Error programming 10F222
    By JoelMurphy in forum mel PIC BASIC Pro
    Last Post: - 25th July 2009, 15:23
  3. Making Program Code Space your playground...
  4. "Program Memory Error" with MPLAB IDE (PBP)
    By aggie007 in forum mel PIC BASIC Pro
    Last Post: - 13th November 2007, 19:27
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
