Serial data sending#do someone came across programming 16f676 with TRH031M?
Results 1 to 17 of 17
    Default Re: Serial data sending#do someone came across programming 16f676 with TRH031M?
    Not sure what you mean by The only solution I have thought was "nested IF loop" but microcode studio don't support this kinda command rather just "IF...THEN".
    First of all MicroCodeStudio is just the editor, the support or lack there of for any commands etc is down to the compiler - which is PBP. And yes, PBP supports nested IF/THEN
    If myData[0] = "A" THEN
      If myData[1] = "B" THEN
        If myData[2] = "C" THEN
        ' Do whatever
    And yes PBP supports IF/THEN in loops...
    i VAR BYTE
    DataIn VAR BYTE[16]
    ActualData VAR BYTE [6]
    ' DataIn is 16 bytes containg A A A A A H A N S O N E E E E E
    ' Verify that the first 5 bytes are all "A"
    For i = 0 to 4
      If DataIn[i] <> "A" THEN GOTO Start   ' Nope, not qualified, start over...
    NEXT
    ' Verify that the last 5 bytes are all "E"
    For i = 11 to 15
      If DataIn[i] <> "E" THEN GOTO Start   ' Nope, not qualified, start over...
    NEXT
    ' Yes, header and footer qualified. Now extract actual data, 6 bytes, store in array ActualData
    For i = 5 to 10
      ActualData[i-5] = DataIn[i]
    NEXT
    You could/should also look into the WAIT or possibly WAITSTR modifiers of the SERIN command. Or, once you've got all the data in the array, you might want to look at the ARRAYREAD command to parse the data. Lots of options available.
    Hi Henrik,
    • i VAR BYTEDataIn VAR BYTE[16]ActualData VAR BYTE [6]' DataIn is 16 bytes containg A A A A A H A N S O N E E E E E' Verify that the first 5 bytes are all "A"For i = 0 to 4 If DataIn[i] <> "A" THEN GOTO Start ' Nope, not qualified, start over...NEXT' Verify that the last 5 bytes are all "E"For i = 11 to 15 If DataIn[i] <> "E" THEN GOTO Start ' Nope, not qualified, start over...NEXT' Yes, header and footer qualified. Now extract actual data, 6 bytes, store in array ActualDataFor i = 5 to 10 ActualData[i-5] = DataIn[i]NEXT
    If first 5 bytes received are correct then GOTO start. In this case if first 5 bytes received correctly and last 5 bytes are wrong? It runs "start" subroutine without checking the last 5 bytes?
    No.... It checks the first 5 bytes, if any of them is NOT "A" it jumps to start.
    No.... If it finds that the first 5 bytes are received correct it continues to check the last 5 bytes. If they TOO are correct it extracts the data. If any of the last the 5 bytes are wrong it'll jump back to start without extracting the data.
    Only when the first bytes are "A" AND the last 5 bytes are "E" will it extract the data. As soon as ANY of the first 5 bytes OR the last 5 bytes does NOT match will it jump back to start - which is whay you said it should do:
    if all conditions matched (receive first 5 "A" and last 5 "E" properly) then store data_in
  1. Problem on sending data on serial port
    By bwaxing in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2011, 22:05
  2. Ir problem sending data
    By Mus.me in forum mel PIC BASIC Pro
    Last Post: - 6th December 2009, 06:27
  3. 16F676 programming problem
    Last Post: - 18th May 2009, 18:39
  4. VB sending serial data to PIC
    By Tissy in forum Serial
    Last Post: - 8th March 2006, 19:31
  5. Sending data over USB via VB
    Last Post: - 12th September 2005, 02:00
