Control of servo motor wireless
Results 1 to 9 of 9
    Aug 2008
    Default Control of servo motor wireless
    I'm unable to control a servo wireless
    someone can help me
    need to control 2 motor and a servo motor.
    THANK YOU
    A VAR BYTE
    B VAR BYTE
    C VAR BYTE
    D VAR BYTE
    E VAR BYTE
    X VAR BYTE
    PAUSE 900
    lcdout $FE,1,"P1 P2 P3 P4"
    PROG:
    GOSUB LCD
    ADCIN 0,A
    ADCIN 1,B
    ADCIN 2,C
    ADCIN 3,D
    ADCIN 4,E:X=(E+20)
    PAUSEUS 50
    hserout ["PC",A,B,C,D,X]
    GOTO PROG
    LCD:
    lcdout $FE,$C0,dec3 A," ",dec3 B," ",dec3 C," ",DEC D," "
    pause 200
    A VAR BYTE
    B VAR BYTE
    C VAR BYTE
    D VAR BYTE
    E VAR BYTE
    PROG:
    hSerIn [WAIT("PC"),A,B,C,D,E]
    if (A>160) THEN FRE
    IF (A<100) THEN TRA
    IF (B>160) THEN DIR
    IF (B<100) THEN ESQ
    pulsout PORTB.0,E 'SERVO MOTOR
    PORTC.0 = 0
    PORTC.1 = 0
    PORTC.2 = 0
    PORTC.3 = 0
    PORTC.5 = 0
    GOTO PROG
    FRE:
    PORTC.0 = 1
    PORTC.1 = 0
    PORTC.2 = 0
    PORTC.3 = 1
    PORTC.5 = 1
    GOTO PROG
    TRA:
    PORTC.0 = 0
    PORTC.1 = 1
    PORTC.2 = 1
    PORTC.3 = 0
    PORTC.5 = 1
    GOTO PROG
    DIR:
    PORTC.0 = 1
    PORTC.1 = 0
    PORTC.2 = 1
    PORTC.3 = 0
    PORTC.5 = 1
    GOTO PROG
    ESQ:
    PORTC.0 = 0
    PORTC.1 = 1
    PORTC.2 = 0
    PORTC.3 = 1
    PORTC.5 = 1
    GOTO PROG
    Dec 2011
    IO93ok
    Default Re: Control of servo motor wireless
    A bit more information needed. What chip? ADCON settings? HSERIN/OUT settings?
    Is this what you mean (Renamed slightly for clarity in MCS)
    GOSUB LCD probably wants to be at end of PROG as first run will show no values.
    A VAR BYTE
    B VAR BYTE
    C VAR BYTE
    D VAR BYTE
    E VAR BYTE
    X VAR BYTE
    PAUSE 900
    PROG:
    GOSUB LCD
    ADCIN 0,A
    ADCIN 1,B
    ADCIN 2,C
    ADCIN 3,D
    ADCIN 4,E:X=(E+20)
    PAUSEUS 50
    GOTO PROG
    LCD:
    pause 200
    ;Wireless receiver
    A1 VAR BYTE
    B1 VAR BYTE
    C1 VAR BYTE
    D1 VAR BYTE
    E1 VAR BYTE
    PROG1:
    hSerIn [WAIT("PC"),A1,B1,C1,D1,E1]
    if (A1>160) THEN FRE
    IF (A1<100) THEN TRA
    IF (B1>160) THEN DIR
    IF (B1<100) THEN ESQ
    pulsout PORTB.0,E1 'SERVO MOTOR
    PORTC.0 = 0
    PORTC.1 = 0
    PORTC.2 = 0
    PORTC.3 = 0
    PORTC.5 = 0
    GOTO PROG1
    FRE:
    PORTC.0 = 1
    PORTC.1 = 0
    PORTC.2 = 0
    PORTC.3 = 1
    PORTC.5 = 1
    GOTO PROG1
    TRA:
    PORTC.0 = 0
    PORTC.1 = 1
    PORTC.2 = 1
    PORTC.3 = 0
    PORTC.5 = 1
    GOTO PROG1
    DIR:
    PORTC.0 = 1
    PORTC.1 = 0
    PORTC.2 = 1
    PORTC.3 = 0
    PORTC.5 = 1
    GOTO PROG1
    ESQ:
    PORTC.0 = 0
    PORTC.1 = 1
    PORTC.2 = 0
    PORTC.3 = 1
    PORTC.5 = 1
    GOTO PROG1
    Rob.
    The moment after you press "Post" is the moment you actually see the typso
    Aug 2008
    hello tasmod
    Thanks for responding to my message
    I need ponteciometro stay in the middle and the servant is in the center to divide right and center left.
    Could you help me with this
    thank you
    Dec 2011
    IO93ok
    Need to know which PIC chip you are using.
    What other settings you have made. Such as ADCON HSERIN etc.
    Rob.
    Aug 2008
    hello tasmod
    When the potentiometer Reaches the end the servant is out of position
    here s configuration Requested that I am using
    thank you
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_BAUD 9600
    DEFINE HSER_SPBRG 25
    DEFINE HSER_CLROERR 1
    DEFINE ADC_BITS 8
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    ADCON1=%1001001
    Dec 2011
    IO93ok
    Please say which PIC you are using
    Is it 16f88 or 16f877 or an 18f
    Rob.
  1. Servo Motor control using MATLAB and PIC.
    By shirohin in forum mel PIC BASIC Pro
    Last Post: - 15th July 2012, 03:44
  2. Servo motor control
    Last Post: - 16th July 2010, 23:44
  3. servo motor control??help
    By HYETİK in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 08:41
  4. control servo motor by using pic16F84A
    By waterlee2000 in forum PBP Wish List
    Last Post: - 23rd June 2006, 15:31
  5. inturrepts to control the servo motor position!
    By parinshah in forum mel PIC BASIC Pro
    Last Post: - 2nd May 2006, 08:55
