Serial problem between BasicStamp code and PBP code
Results 1 to 23 of 23
Threaded View
  1. #8
    Default Re: Serial problem between BasicStamp code and PBP code
    The code you are referring to is wrong. I uploaded 2 files Pan_andTilt.bas is for the BasicStamp2p and Pan_andTilt2.bas was for the PIC. I had to change the move1 and move2 subs because PBP does not support the .LOWNIB .HIGHNIB commands. If you look at Pan_and_Tilt2.bas you will see the changes in move1 and move2. They accomplish the same thing. I am adding the PDF for the FT639.
  1. Zero-error 1 second Timer code for PBP?
    Last Post: - 29th June 2013, 15:31
  2. pbp code
    By samixta in forum PBP Wish List
    Last Post: - 2nd July 2011, 21:53
  3. pbp code for DS3234
    By itsssyam in forum General
    Last Post: - 23rd December 2009, 11:31
  4. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Changing Swordfish code to PBP
    By Ron Marcus in forum mel PIC BASIC Pro
    Last Post: - 29th April 2008, 02:28
