Thank you for the reply. I had to rewrite the send routines because of the no "NIBS". Yes I am using default configs. I tried DEFINE OSC 4, INCLUDE "bs2defs.bas" and INCLUDE "modedefs.bas. I even tried their new program "meCONFIG" which gave me nothing but errors. I am using a 4 Mhz resonator on a PICBIT-18 board. I have used this board and PIC to blink an LED to make sure my PIC and board were working. The PIC I am using is a PIC16f84 /10 but I assume you can run a 10 Mhz at 4 Mhz with no problems. Thank you for the info on bit 15, good to no. I thought of disabling all interrupts, but don't know if the serial commands use interupts.
