Serial problem between BasicStamp code and PBP code
Results 1 to 23 of 23
Threaded View
  1. #8
    Default Re: Serial problem between BasicStamp code and PBP code
    No "NIBs" in pbp only bits, bytes, words & longs. Are you using "Default" configs ? have you gotten an LED to blink? I see NO "DEFINE OSC 4" in your code to tell PBP the pic is operating at 4 mhz
    Are you using a crystal, a resonator or internal RC oscillator? Does you config statement reflect what you actually have ?
    I have tried changing serial config from true to inverted the manual also says bit 15 can be for open or driven. Whatever that means.
    open is an open collector where a pullup resistor pulls the output high whereas driven means an output transistor drives the output high or low.
  1. Zero-error 1 second Timer code for PBP?
    Last Post: - 29th June 2013, 15:31
  2. pbp code
    By samixta in forum PBP Wish List
    Last Post: - 2nd July 2011, 21:53
  3. pbp code for DS3234
    By itsssyam in forum General
    Last Post: - 23rd December 2009, 11:31
  4. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Changing Swordfish code to PBP
    By Ron Marcus in forum mel PIC BASIC Pro
    Last Post: - 29th April 2008, 02:28
