Serial problem between BasicStamp code and PBP code
Results 1 to 23 of 23
    Unhappy Serial problem between BasicStamp code and PBP code
    I wrote a program for a BasicStamp2p and it works perfect. I then copied the code to PBP and made the necessary changes. When I take the two serial lines from the Stamp and connect them to the PIC16F84, the program will not function. The first thing it should do is center the 2 servos. I have attached the 2 files. Any help will be greatly appreciated.
    Default Re: Serial problem between BasicStamp code and PBP code
    If it is serial communication, I would start by sending a simple text to a PC in Stamp, then do the same in PBP.
    Don't use your entire logic, just "HELLO". It will be much easier to show code here and debug.
    (I can't see your files from my phone)
    Dec 2011
    IO93ok
    Two questions.
    Is there a serial ground connection between communicating modules (Not mentioned in pin assignments notes)
    Is the Bluetooth module receiving commands and outputting serial. Scope checked etc.
    Rob.
    The moment after you press "Post" is the moment you actually see the typso
    Hi
    Not sure about your code. But when using Basic Stamp syntax for serial. You should place at the top of your code.
    Include "modedefs.bas"
    In the back of the Picbasic Pro manual there is a section on the differences between PBP and Basic Stamp.
    Hopefully you can make it work.
    I have tried it with Include "modedefs.bas" and without. The code is not very long. What I need is for someone to look at the 2 files and see if they can tell why it won't work on the PIC. I have both the PIC and the Stamp and FT639 and Bluetooth module on breadboard. When I hook the 2 serial lines to the Stamp I can control the servos. When I remove the two serial lins and connect them to the PIC. it won't work. All the pin configuration is documented in the 2 files. lt appears to be a serial problem. When I power up the circuit it should automatically center both servos. It does with the Stamp but not with the PIC. Hope this helps.
    You might get more help if you post your code directly. Some may not be able to open those files on mobiles.
    Click GO ADVANCED at bottom right of a new post and use the code tags like this (CODE)...(/CODE) but using [ ].
    My money is on a config.
    What version of PIC BASIC PRO?
    I am new to this. Have never posted before. Am 67 and trying to learn. I am using PBP ver 2.50C. The code files can be opened with notepad they are not very complicated or big. I don't know how to add my code files to a post. When I tried it the first time, it put them at the bottom of the post. The commands go over the air via Bluetooth then serially to BasicStamp then serially to servo controller. Works great. When I try it with the PIC nothing happens. I assume it is a serial problem from PIC to servo controller because it does not need the bluetooth at the start . It first sends centering command serially to servo controller to center servos. That does not happen. I have tried changing serial config from true to inverted the manual also says bit 15 can be for open or driven. Whatever that means.
    No "NIBs" in pbp only bits, bytes, words & longs. Are you using "Default" configs ? have you gotten an LED to blink? I see NO "DEFINE OSC 4" in your code to tell PBP the pic is operating at 4 mhz
    Are you using a crystal, a resonator or internal RC oscillator? Does you config statement reflect what you actually have ?
    open is an open collector where a pullup resistor pulls the output high whereas driven means an output transistor drives the output high or low.
    Thank you for the reply. I had to rewrite the send routines because of the no "NIBS". Yes I am using default configs. I tried DEFINE OSC 4, INCLUDE "bs2defs.bas" and INCLUDE "modedefs.bas. I even tried their new program "meCONFIG" which gave me nothing but errors. I am using a 4 Mhz resonator on a PICBIT-18 board. I have used this board and PIC to blink an LED to make sure my PIC and board were working. The PIC I am using is a PIC16f84 /10 but I assume you can run a 10 Mhz at 4 Mhz with no problems. Thank you for the info on bit 15, good to no. I thought of disabling all interrupts, but don't know if the serial commands use interupts.
    Dec 2011
    IO93ok
    Whats the control protocol? Is it numeric or ASCII ?
    i.e. what are the units expecting between themselves. At the moment 122 is "z" sent serially.
    Rob.
    From the android app I receive ASCII over the air to the Bluetooth module. From the Blutooth out serial numeric to FT639 which requires 2 bytes as per the send1 or send 2 depending whether or not to move pan servo or tilt servo. The protocol for the 2 bytes is Lower Byte = 0sssxxxx Upper Byte 1sssxxxx sss = servo number xxxx = lower nibble of position byte yyyy = upper nibble of position byte position byte is from 0 - 255.
    Dec 2011
    IO93ok
    OK lets get this straight. Is it like this :-
    Android --over air ---ASCII ---- BTooth BTooth ----- Z ------PIC16F84 PIC16F84 ----2bytes------FT639
    What is Z protocol? You have that as expecting ASCII in the code.
    Rob.
    Dec 2011
    IO93ok
    Ah following it a bit better now.
    I'm near your age and still learning PBP, usually by trial and error.
    Try this and see if it works, SEROUT2 according to manual is same as BS2 serout
    I'm probably completely wrong
    Rob.
    Dec 2011
    IO93ok
    Allan,
    Search the net for MicroCode Studio Editor (MCS) it is free and will help tremendously.
    Any code posted on forum will likely be raw. i.e. no code formatting unless it is written that way
    so usually people copy the code into MCS which displays in formatted code.
    The code tag is the # button on the posting panel.
    Rob.
    The Android APP has U D L R arrows plus a button in the center. When I press one of the arrow keys or the center button, it sends a Capital U D L R or C via Bluetooth to the HC-06 bluetooth module which sends it to the PIC. I then check what was sent and select which way to move the servos using the appropriate servo controller command bytes. The ASCII values are only used to tell which button was pressed. The values 122(z) 117(u) 85(U) 90(Z) and 103(g) are numeric values needed to send to the FT639 to intialize it. Once it it initialized then the protocol explained previously is used to position the servos.
    I am using MicroCode Studio Editor. That's where the example code was written in. I had to change the extensions on the 2 files. otherwise it would not let me upload them. The BasicStamp extension shoul be .bsp and the PIC code ext should be .pbp
    I tried your code. Still not working. What I am having a hard time with is the code for the BasicStamp works 100%. The only changes I needed to make according to the PBP manual was the baud rate. The BasicStamp2p is faster than the BasicStamp2 and the baud rates in the PBP manual Appendix A are the same as the BasicStamp2 which is what I need for the PIC16F84 at 4Mhz. The other change was the move1 and move2 routines. PBP does not support nibble so I had to modify the code to send the apporpriate low and high bytes.
    position1 and position2 are declared as byte vars . there is no position1.highbyte
    the position1 high nibble is Hbyte = ( position1 & %11110000 )>>4 , low nibble Lbyte = position1 & %00001111.
    SEROUT2 2,16780,[BIN Lbyte,BIN Hbyte] would send 16 ascii 0 or 1's ( 0x30/0x31) is that what you really want ?
    I suspect you should try SEROUT2 2,16780,[position1]
    The code you are referring to is wrong. I uploaded 2 files Pan_andTilt.bas is for the BasicStamp2p and Pan_andTilt2.bas was for the PIC. I had to change the move1 and move2 subs because PBP does not support the .LOWNIB .HIGHNIB commands. If you look at Pan_and_Tilt2.bas you will see the changes in move1 and move2. They accomplish the same thing. I am adding the PDF for the FT639.
    I have added an LCD to see what is going on. I have verified that the bluetooh module is receiving correctly, also the Lbyte and Hbyte I'm sending to the FT639 are correct. For some reason the data is not going to the FT639 correctly. I have tried all four possible 2400 baud rates, 396, 16780, 33164, and 49548. The serial_in works perfect, The serial_out command is the problem.
    Problem solved. Added PAUSE 5 after each command sent in intialize subs setup: setpulse: setheader: and setactive: and works like a charm. Going to have a glass of wine. My guess is that in the BasicStamp code the interpreter takes a while but the PIC code needs no interpretation and therefore executes faster which was to fast for the FT639. By giving the chip time before the next instruction works. Thanks to all who tried to help. Much appreciated.
    glad you got it to work .
    the pan_and_tilt2 as posted still looks wrong to me the moves should look like this
    move1:
    Lbyte = (position1 & %00001111) 'servo 0 + lownib
    Hbyte = %10000000 |( (position1 & %11110000)>>4) 'servo 0 + highnib
    SEROUT2 serial_out,baud1,[Lbyte,Hbyte] 'send command to FT639
    PAUSE 100
    You are correct. I modified the code to the following a few days ago.
    Move1:
    interim = position1 & %00001111
    Lbyte = interim | %00000000
    interim = position1 & %11110000
    Hbyte = (interim >> 4) | %10000000
    Your's look more compact I think I will change mine. Thanks. I'm learning.
  1. Zero-error 1 second Timer code for PBP?
    Last Post: - 29th June 2013, 15:31
  2. pbp code
    By samixta in forum PBP Wish List
    Last Post: - 2nd July 2011, 21:53
  3. pbp code for DS3234
    By itsssyam in forum General
    Last Post: - 23rd December 2009, 11:31
  4. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Changing Swordfish code to PBP
    By Ron Marcus in forum mel PIC BASIC Pro
    Last Post: - 29th April 2008, 02:28
