How to?????? >> square wave inverter. Feedback option needed
Results 1 to 2 of 2
    Sep 2013
    Dhaka, Bangladesh
    Exclamation How to?????? >> square wave inverter. Feedback option needed
    I design a Full bride Inverter. But I want to add feedback option to my project. I got 50Hz freq from my full bridge.
    plz anyone help me!!!!!!!!!! How I add feedback to my project??????
    DEFINE OSC 16
    ON INTERRUPT GOTO UPDATE
    DIR VAR BYTE
    '************************* Assign some Interrupt associated aliases
    T0IE VAR INTCON.5 ' TMR0 Overflow Interrupt Enable
    T0IF VAR INTCON.2 ' TMR0 Overflow Interrupt Flag
    GIE VAR INTCON.7 ' Global Interrupt Enable
    PS0 VAR OPTION_REG.0 ' Prescaler ratio bit-0
    PS1 VAR OPTION_REG.1 ' Prescaler ratio bit-1
    PS2 VAR OPTION_REG.2 ' Prescaler ratio bit-2
    PSA VAR OPTION_REG.3 ' Prescaler Assignment (1=assigned to WDT 0=assigned to oscillator)
    T0CS VAR OPTION_REG.5 ' Timer0 Clock Source Select (0=Internal clock 1=External PORTA.4)
    PWM1 VAR PORTC.5 ' Alias servo pin1
    PWM2 VAR PORTC.6 ' Alias servo pin2
    TRISC = 000000 ' Configure PORTC as outputs
    PORTC = 0 ' Clear PORTB
    '********************* Initiate the interrupt
    GIE = 0 ' Turn off global interrupts
    PSA = 0 ' Assign the prescaler to external oscillator
    PS0 = 1 ' Set the prescaler
    PS1 = 1 ' to increment TMR0
    PS2 = 1 ' every 256th instruction cycle
    T0CS = 0 ' Assign TMR0 clock to internal source
    TMR0 = 0 ' Clear TMR0 initially
    T0IE = 1 ' Enable TMR0 overflow interrupt
    GIE = 1 ' Enable global interrupts
    MAIN:
    GOTO MAIN
    DISABLE
    UPDATE:
    TMR0 = 100
    IF DIR = 0 THEN
    PWM1 = 1
    PWM2 = 0
    DIR = 1
    PWM2 = 1
    PWM1 = 0
    DIR = 0
    T0IF = 0
    RESUME
    ENABLE
    OK
    Default Re: How to?????? >> square wave inverter. Feedback option needed
    Just some observations first:
    "PORTC = 0 ' Clear PORTB", your comment says Clear PORTB yet your code states PORTC = 0
    "MAIN:
    GOTO MAIN" Add a pause in there; "MAIN: : PAUSE 10 : GOTO MAIN"
    With that out of the way, what do you wish to look at for feedback? If you have an analog voltage, you can use an ADCIN 0, FB command followed with:
    IF FB > X then
    take action
    IF FB < X then
    no action
    Let's start there before I type 3 pages and still not answer your question.
    Mike
  1. Replies: 6
    Last Post: - 31st March 2014, 14:25
  2. generating square wave
    By boscox in forum mel PIC BASIC Pro
    Last Post: - 24th April 2012, 08:29
  3. square wave inverter with pic 16f72
    By Rupesh in forum mel PIC BASIC
    Last Post: - 25th December 2011, 18:42
  4. Generating square-wave of 200kHz
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 2nd March 2011, 22:06
  5. square to sine wave help
    By TONIGALEA in forum General
    Last Post: - 2nd July 2006, 10:32
