Simple If.. Then help:
Results 1 to 7 of 7
Threaded View
    Tear's Avatar
    Tear Guest
    Default Simple If.. Then help:
    In this very simple code I am just trying to play with the if statement. I have set port A pin 0 to be an input and have it hotwired to be high. However, the led connected to port B pin 0 WONT TURN ON. The led for port B pin 1 is just a heartbeat. I know that my circuit is wired correctly, and I can't see anything wrong in this code. Any help would be appreciated.
    TRISA.0 = 1
    loop1:
    if PORTA.0 = 1 then
    PORTB.0 = 1
    high PORTB.1
    goto loop1
    EDIT: I went back and changed the line:
    PORTB.0 = 1
    to
    high PORTB.0
    After this change the led is always on even when I disconnect PORTA.0 from the 5 volt supply. It seems as if the IF statement is being ignored. Also, I dont have resistors connected to any of the PORTA or PORTB pins. I dont think this is the problem though.
  1. Simple RF remote control code
    Last Post: - 22nd January 2014, 10:45
  2. Simple Blinking LED - WTF!!
    By johnnylynx in forum mel PIC BASIC Pro
    Last Post: - 1st February 2010, 06:19
  3. Simple LCD code not working!...WHY?
    Last Post: - 29th November 2009, 19:48
  4. Replies: 0
    Last Post: - 2nd February 2009, 23:23
  5. Replies: 4
    Last Post: - 7th September 2005, 14:11
