sine wave inverter (modified tahmid mikro C 16f877 to 16f72) problem in: feedback
Results 1 to 7 of 7
    Sep 2013
    Dhaka, Bangladesh
    Question sine wave inverter (modified tahmid mikro C 16f877 to 16f72) problem in: feedback
    feedback not working!!!!!
    proteus & main mikro C file : TAHMID SINE WAVE.zip
    DEFINE OSE 16
    ON INTERRUPT GOTO ISR
    '*************************VARIABLES
    tblpointernew VAR WORD
    tblpointerold VAR WORD
    tblpointershift VAR WORD
    setfreq VAR WORD
    tbltemp VAR WORD
    dutycycle VAR BYTE
    flag VAR WORD
    SINVAL VAR BYTE
    FBV VAR BYTE
    FBS VAR BYTE
    ADDER VAR BYTE
    direction VAR BIT
    '*************************ALIAS
    MOSA VAR PORTC.3
    MOSB VAR PORTC.4
    PEIE VAR INTCON.6
    GIE VAR INTCON.7
    TMR1IF VAR PIR1.0
    TMR2IF VAR PIR1.1
    TMR2IE VAR PIE1.1
    MAIN:
    setfreq = 410
    tblpointernew = 0
    tblpointerold = 0
    tblpointershift = 0
    dutycycle = 0
    TRISC = 0
    PORTC = 0
    PR2 = 249
    CCPR1L = 0
    CCP1CON = 12
    TMR2IF = 0
    T2CON = $04
    TMR2IF = 0
    TMR2IE = 1
    GIE = 1
    PEIE = 1
    direction = 0
    START:
    ADCIN 0, FBV
    IF FBV < 256 THEN
       FBS = FBS + 1
       IF FBS > 8 THEN FBS = 8
        IF FBS > 0 THEN FBS = FBS - 1
    ADDER = FBS << 5
    TMR1L = 0 : TMR1H = 0 : TMR1IF = 0
    GOTO START
    DISABLE
    isr:
    IF TMR2IF == 1 THEN
    update:
     tblpointernew = tblpointerold + setfreq
     IF tblpointernew < tblpointerold THEN
     IF direction == 0 THEN
     mosa = 0
     mosb = 1
     direction = 1
     mosa = 1
     mosb = 0
     direction = 0
     tblpointershift = tblpointernew >> 11
     dutycycle = tblpointershift + ADDER
     LOOKUP dutycycle, [0, 16, 32, 47, 62, 77, 91, 103, 115, 126, 136, 144, 151, 156, 160, 162, 163, 162, 160, 156, 151, 144, 136, 126, 115, 103, 91, 77, 62, 47, 32, 16,_          '65%
    0, 17, 34, 51, 67, 82, 97, 111, 124, 135, 146, 154, 162, 167, 172, 174, 175, 174, 172, 167, 162, 154, 146, 135, 124, 111, 97, 82, 67, 51, 34, 17,_                             '70%
    0, 18, 37, 55, 72, 89, 104, 119, 133, 145, 156, 166, 174, 180, 184, 187, 188, 187, 184, 180, 174, 166, 156, 145, 133, 119, 104, 89, 72, 55, 37, 18,_                           '75%
    0, 20, 39, 58, 77, 94, 111, 127, 141, 155, 166, 176, 185, 191, 196, 199, 200, 199, 196, 191, 185, 176, 166, 155, 141, 127, 111, 94, 77, 58, 39, 20,_                           '80%
    0, 21, 42, 62, 82, 100, 118, 135, 151, 165, 177, 188, 197, 204, 209, 212, 213, 212, 209, 204, 197, 188, 177, 165, 151, 135, 118, 100, 82, 62, 42, 21,_                         '85
    0, 21, 43, 64, 84, 103, 122, 139, 155, 169, 182, 193, 202, 210, 215, 218, 219, 218, 215, 210, 202, 193, 182, 169, 155, 139, 122, 103, 84, 64, 43, 21,_                         '87.5%
    0, 22, 44, 65, 86, 106, 125, 143, 159, 174, 187, 198, 208, 215, 221, 224, 225, 224, 221, 215, 208, 198, 187, 174, 159, 143, 125, 106, 86, 65, 44, 22,_                         '90%
    0, 23, 45, 67, 88, 109, 128, 147, 163, 179, 192, 204, 213, 221, 227, 230, 231, 230, 227, 221, 213, 204, 192, 179, 163, 147, 128, 109, 88, 67, 45, 23],SINVAL                  '92.5%
     CCPR1L = SINVAL
     tblpointerold = tblpointernew
    TMR2IF = 0
    RESUME
    ENABLE
    Default Re: sine wave inverter (modified tahmid mikro C 16f877 to 16f72) problem in: feedback
    OK!!!!!!
    FBV is declared as a BYTE so IF FBV < 256 THEN will always evalute true. FBV can never be larger then 255 so FBS will always be incremented to 8 and then stay there.
    Sep 2013
    Dhaka, Bangladesh
    OK!!!!!!
    hmm.... you are right.
    but from this blog (http://forum.allaboutcircuits.com/blog.php?b=512) i found that i convert to picbasic. but not working!!!!
    can you solve this problem????
    Sep 2013
    Dhaka, Bangladesh
    OK!!!!!!
    i ALSO TRY THE FOLLOWING CODE. BUT DON'T WORKING. PROTEUS OUTPUT::::
    pLZ HELP ME SIR.......
    ADCIN 0, VOLT
    FBV = FBV + VOLT
    IF FBV = FBV + 30 THEN
    THERE'S NO NEED TO SHOUT, WE HEAR YOU LOUD AND CLEAR!
    Think about that last statement for a while.
    When exactly do you expect FBV be equal to itself + 30? That's simply never going to evalute true because it will always compare itself to a larger value.
    In PBP bytes and words are unsigned, they can never be less then zero. So something like IF A > 0 THEN will always evalute true.
    When you do ADCIN 0, Volt the variable Volt will always be positive so FBV=FBV+Volt will keep accumulating FBV over and over and over again untill it overflows and starts over.
    Finally, in the code in your first post you have DEFINE OSE 16, that's not correct and you don't seem to do any sort of setup for the ADC, manually or with DEFINEs - check the manual.
    Sep 2013
    Dhaka, Bangladesh
    I am very sorry for that. But I need this project as soon as possible.
    I hope your advise is correct but unfortunately I unable to understand what you say & what you order me to change in my code. If you give me the correct code then I will very happy.
    Thanks.
    I see that you have started a new thread. Looking for more code giveaways? Once again your statement:
    "I hope your advise is correct but unfortunately I unable to understand what you say & what you order me to change in my code. If you give me the correct code then I will very happy." sounds like you know nothing about the project you are trying to re-create. It also sounds like you want everybody to drop everything they are doing to write your code for you when you say:
    "I am very sorry for that. But I need this project as soon as possible" Maybe you should have been studying the language and the project before the last minute.
    Just my 2 cents.....
    EN82fn
  1. Sine wave power inverter
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 23rd February 2017, 05:16
  2. sine wave inverter
    By BADAL123 in forum Off Topic
    Last Post: - 7th January 2014, 13:20
  3. square wave inverter with pic 16f72
    By Rupesh in forum mel PIC BASIC
    Last Post: - 25th December 2011, 17:42
  4. Low pass filter help - pure sine wave inverter
    By George in forum Off Topic
    Last Post: - 9th April 2011, 05:24
  5. sine inverter
    By anybisi in forum General
    Last Post: - 21st March 2008, 11:08
