need help!!! >> 2 channel SPWM variable duty cycle.
Results 1 to 13 of 13
    Sep 2013
    Dhaka, Bangladesh
    Question need help!!! >> 2 channel SPWM variable duty cycle.
    I modified SPWM software and add a more SPWMpin but I need a variable duty cycle. (see the photo)
    define OSC 10
    SPWMpin var PORTC.2
    SPWMpin1 var PORTC.3
    Include "SSPWM.INC"
    START:
    Freq = 50
    DutyCycle = 50
    gosub StartSPWM
    MAIN:
    'MY CODE HERE
    GOTO MAIN
    sspwm.zip
    HOW I ADD VARIABLE CODE TO MY PROJECT????
    HELP ME ANYBODY PLZ.......
    Sep 2013
    Dhaka, Bangladesh
    Default Re: need help!!! >> 2 channel SPWM variable duty cycle.
    I hoped that is site is useful but I never get any help from this site. So this is my last post if I will not get any response I never post in this site.
    Proteus File: Attachment 7283
    Oct 2009
    Utah, USA
    Antorbd,
    to add a variable to your code you simply declair it at the beginning like this...
    AdjustPWM VAR BYTE
    Then you can read the AD converter connected to your variable resistor like this...
    ADCIN 5, AdjustPWM
    then you can use the value you read in to your variable "AdjustPWM" in your PWM adjust command, something like the...
    HPWM 1, AdjustPWM, 500
    are you using PicBasic ?? or some other basic language??
    If PicBasic do you have the manual?
    for a beginner it is extremely helpful to read and study other working code examples.
    Use the search function at the top of the forum and enter a couple of search terms and you will find lots of examples.
    Also go to the WIKI section at the top also and look at the projects there.
    Good luck and keep asking questions.
    Dwight
    Quote Originally Posted by Antorbd04 View Post
    SSPWM was only for 1 channel.
    For multiple channels, use Multi_SPWM
    http://www.pbpgroup.com/modules/wfse...p?articleid=12
    Sep 2013
    Dhaka, Bangladesh
    Quote Originally Posted by darrel taylor View Post
    sspwm was only for 1 channel.
    For multiple channels, use multi_spwm
    i want a pwm which as output as:
    but multi_spwm give me a output which as:
    how i will get my expected output from multi_spwm????
    Sep 2013
    Dhaka, Bangladesh
    sspwm was only for 1 channel.for multiple channels, use multi_spwmhttp://www.pbpgroup.com/modules/wfse...p?articleid=12
    i expect output from this project as picture for inverter slow pwm:::::Attachment 7287
    Sep 2013
    Dhaka, Bangladesh
    I unable to find something helpful from your link.
    Sep 2013
    Dhaka, Bangladesh
    Multi_SPWM not suitable for Inverter project & I tested this for Inverter and the result was worst. Plz modify this Multi_SPWM software.
    What else ???
    a cup of "Nespresso" ???
    May be you want to rent someone's knowledge ???
    Sep 2013
    Dhaka, Bangladesh
    Quote Originally Posted by Acetronics2 View Post
    What else ???
    hello bro,
    I just need help that I post. But you mean something different. I don't want to rent someone knowledge.
    What he is trying to say is, when you make a statement like the following:
    "Multi_SPWM not suitable for Inverter project & I tested this for Inverter and the result was worst. Plz modify this Multi_SPWM software."
    it makes us think you want us to do the project for you. You got the routine for free but you don't understand how it works. Now you want someone to please fix it for you. Don't you know any thing about the language? Don't you understand the processor you are working with. People are here to help but, not to re-write someone elses code to suite you. I see this all the time, someone asking for the forum members to write there code for them.
    Just my 2 cents worth.....
    EN82fn
    You want channel 2 to be the exact opposite of channel 1 and don't see how an inverter could be handy?
    I suggest you google <electronic tutorial logic gates>.
  1. Duty Cycle
    By Gord11 in forum mel PIC BASIC Pro
    Last Post: - 29th September 2011, 09:53
  2. 3 channel PWM with customize duty cycle
    By photoelectric in forum mel PIC BASIC Pro
    Last Post: - 16th May 2011, 14:49
  3. How can I measure Duty cycle ?
    By MaxiBoost in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 16:02
  4. PWM _ Duty Cycle in Tenths
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 17th May 2004, 13:09
  5. Duty Cycle Dilemmas
    By crankshaft in forum mel PIC BASIC Pro
    Last Post: - 27th February 2003, 13:40
