Extending the Program Memory
Results 1 to 9 of 9
    Feb 2012
    PERTH AUSTRALIA
    Default Re: Extending the Program Memory
    THANKS JERSON ,
    i could put some of the data into the available sd as hex data tables , but i am sure it will be a speed issue
    i am surprised that data strings for menus are chewing up so much space so quickly
    i still have about 60k left in the pic but i only just getting started on the menu system
    cheers
    Sheldon
    Yeah, that is one of my big "concerns" as well. I have a couple of projects which could benefit from a more "verbose" user interface but each and every byte in a HSEROUT, ARRAYWRITE, LCDOUT etc statement increases the footprint of the generated code by 6 bytes so it eats away available space quickly. The nice thing with these commands is that it's SO easy to mix static strings with variables, formating and so on.
    For static data there are other ways of doing it of course, there's the "strings in codespace" thread from a couple of years ago and someday I need to figure out how to use that.
  1. Program Code and Program Memory
    By DenFrod in forum mel PIC BASIC Pro
    Last Post: - 8th February 2007, 14:51
  2. Use internal program memory like DATA memory
    Last Post: - 30th December 2006, 18:38
  3. using Flash Program Memory ?
    By muskut in forum mel PIC BASIC Pro
    Last Post: - 11th October 2006, 15:17
  4. Writing to program Memory
    By Chris Barron in forum mel PIC BASIC Pro
    Last Post: - 7th April 2006, 01:51
  5. program memory size
    By volcane in forum mel PIC BASIC Pro
    Last Post: - 25th October 2005, 19:45
