A/D, and compiler issues.
Results 1 to 5 of 5
    Feb 2005
    Holmfirth England
    Default A/D, and compiler issues.
    Ever since I have been using PBP I have had the same problem. If using MPASMWIN the A/D converter module does not work, and just reads zero. In the past this was not a problem as I had the option to use the other compiler, the one where you don't get progress bars during compile.
    Trouble is I now only have 64 bit OS and the old compiler will not work. I have upgraded PBP, and am currently using PBPX3.0.6.4, with micro code studio 5.0.0.3.
    I have a project that uses the A/D converter ,and really need to get it working. Can anyone please help?
    Kind regards
    Bob.
    May 2009
    Default Re: A/D, and compiler issues.
    Bob, please post your code so that we can see what you are trying to do.
    Feb 2005
    Holmfirth England
    Here is the code. PIC16F870 by the way.
    define OSC 20
    define adc_bits 10
    define adc_sampleus 50
    trisa = 255
    adcon0 = 129 'Internal clock, channel 0, switched on
    adcon1 = 142 'Right justified (10 bit), channel 0 analog
    adcin 0, temp
    let temp1 = temp * 3
    let temp2 = (temp * 5) / 100
    let temp = temp1 + temp2
    serout serial1, 2, ["A",#temp,"AA"]
    This exact same program has been working fine for around 4 years. I have always had the same issue. If using the compiler with the popup window with progress bars the A/D does not work (same with many different chips, and projects) if using the other compiler everything was fine.
    I have been using PBP for many years with micro code studio, and have always had the same issue. I no longer have a 32 bit operating system, so I can't even install my older version of PBP, and use the doss compiler. With PBP 3 I only have the option to use MPASMX or not, and both give the same result, the same result that I'v had since PBP 2.4ish.
    All defines are case sensitive, try
    define OSC 20
    define ADC_BITS 10
    define ADC_SAMPLEUS 50
    I didn't know PM (the "other" assembler, not compiler) wasn't case sensitive. Anyway, MPASM is so you have to be careful there.
    Try it and see if that fixes it.
    EDIT: Why multiple threads with the same question?
    Feb 2005
    Holmfirth England
    Henrik,
    Thank you very much, issue solved by changing to capital letters.
    It's always the simplest things that cause the issues.
    Sorry about the dual post, no one was viewing PBP 3 section, & my boss is pressuring me to get this done.
    Bob.
  1. compiler help!!!!
    By MINHLE in forum mel PIC BASIC Pro
    Last Post: - 20th April 2008, 18:52
  2. c compiler
    By Armando Herjim in forum General
    Last Post: - 7th March 2007, 03:41
  3. HT-Soft C compiler issues
    By ken_mazur in forum General
    Last Post: - 19th October 2006, 14:10
  4. Compiler problems
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 27th September 2006, 13:03
  5. I need c++ compiler to use it with pic
    By mahmoud_9111 in forum mel PIC BASIC
    Last Post: - 13th April 2005, 20:38
