Struggling again with SEROUT2 and numbers format
Results 1 to 12 of 12
    Default Re: Struggling again with SEROUT2 and numbers format
    Hi Fanias,
    Just a guess on my part
    SEROUT2 CIVP,CIVS,[$FE,$FE,CIVA,$E0,$14,$01,$FD] ' Send this to the radio to read Audio SETTING - WORKS !!!
    CIVA is uppercase
    SEROUT2 CIVP,CIVS,[$FE,$FE,civa,$E0,$14,$01,$f3,$f4,$FD] ' Send this to the radio for NEW VOLUME setting - NOT WORKING
    civa is lowercase
    I am GUESSING, since I do not know what the radio does but uppercase and lowercase letters are different numbers as all characters are numbers . . .
    also same for F vs f
    Nah, I don't think that's it...
    CIVA must be a variable and they are not case sensitive. Had it been a string it should have been "CIVA" vs "civa"
    As a test, ditch the calculations and try:
    f3 = $01
    f4 = $28
    SEROUT2 CIVP,CIVS,[$FE,$FE,civa,$E0,$14,$01,f3,f4,$FD]      ' Send this to the radio for NEW VOLUME setting (no $)
    In this particular case you do not want the $-sign because then it'll send the hexadecimal numbers F3 and F4 and not the content of the variables f3 and f4. Having the $-sign in there would have made the above statement send 243 ($f3), 244 ($f4) instead of 1 ($01), 40 ($28).
    Oct 2012
    Thank you both for your time and answers.
    I think I found a solution, not sure why is this happening but works...
    I tread the numbers I read from radio as BCD, I convert them to binary, increase the volume by adding 10, convert them to BCD again and finally send them to the radio.
    I'm sure there must be an easier way to do this, because I can send other settings very easy.
    The civa is just a constant (address of the radio) and is civa = $70, the same as CIVA = $70.
    Here is the working code for your information, maybe you can help me to make it simpler without all these calculations.
    VOLUP1:
    ' Volume in range 000 - 254
    ' f1 values are 00,01,02
    ' f2 values are 00 - 99
    SERIN2 CIVP,CIVS,[SKIP 6,f1,f2]                             ' Skip first 6 useless bytes and read next 2 volume bytes  - WORKS !!!
    ' The next 4 lines are only for testing and to display a total volume value (000-254) to LCD in decimal
    x1 = f1 & 001111                                         ' read units - WORKS !!!
    x2 = f2 >> 4                                                ' divide / 2^4 = 16 (tens) - WORKS !!!
    x3 = f2 & 001111                                         ' read units - WORKS !!!
    Z = x1 * 100 + x2 * 10 + x3                                 ' a number between 0 - 254
    f3 = ((f1 >> 4) * 10) + (f1 & $0f)                          ' Convert BCD to binary
    f4 = ((f2 >> 4) * 10) + (f2 & $0f)                          ' Convert BCD to binary
    f4 = f4 + 10                                                ' Increase volume by 10 units - This is what I want to do
    IF f4 > 99 THEN
        f4 = 0                                                  ' Make sure result is less than 100
        f3 = f3 + 1
    IF f3 > 1 AND f4 > 54 THEN                                  ' If volume > 254 go back to volume 0
        f3 = 0
        f4 = 0
    f5 = ((f3 / 10) << 4) + (f3 // 10)                          ' Convert bin to BCD
    f6 = ((f4 / 10) << 4) + (f4 // 10)                          ' Convert bin to BCD
    pause 50                                                    ' Give some time to radio to recover from SERIN2
    SEROUT2 CIVP,CIVS,[$FE,$FE,civa,$E0,$14,$01,f5,f6,$FD]      ' Send this to the radio for NEW VOLUME setting - THIS WORKS NOW :)
    pause 50                                                    ' Give some time to radio to recover from SEROUT2
    Thanx again
    Fanias
    Oct 2012
    Red face Now PIC hangs after 14 times of a subroutine execution
    Hello again,
    after solving my problems with serial port, I found that PIC (18F46K22) hangs after I send a command 14 times exactly.
    I'm using some code I found in the forum to remote control via the NEC infrared protocol a receiver.
    It works but when I press quickly 14 times the Volume UP button (to increase volume) the PIC hangs and a reset is needed.
    Three questions for anyone who wants to help.
    • I can't increase the Oscillator speed (e.x. το 16 MHz) to get the higher serial port speeds I need, the code works only at 4 MHz.
      I realize that the values of DL1 and DL2 must be icreased, but they don't work for DL1 = 3200 and DL2 = 440 (for 16 MHz), so I'm stuck to 4 MHz
    • The program hangs PIC when I call quickly 14 times the VOLUP subroutine. What is wrong in this subroutine ? I have also implemented a basic repeat function (VOL+ button always pressed which works)
    • How can I enable a feature or a function like WDT to avoid this hang when it occurs ? As you can see in the top of the program I tried to enable the WDT and tried different prescale values but nothing happens. Can you help with that in case I cannot fix the hang ?
    Here is the complete program :
    '====================================   CONFIGURE PIC   ===========================================
    '                                                     # 18F46K22 #
    DEFINE PULSIN_MAX 10000
    @ CONFIG PBADEN = OFF                       ' PORTB<5:0> pins are configured as digital I/O on Reset
    @ CONFIG LVP = OFF                          ' Single-Supply ICSP disabled
    @ CONFIG XINST = OFF                        ' Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
    '@ CONFIG STVREN = ON                        ' Stack full/underflow will cause Reset
    '@ CONFIG WDTEN = ON                         ' WDT is always enabled. SWDTEN bit has no effect
    '@ CONFIG WDTPS = 512                          ' Watchdog Timer Postscale Select bits
    '@ CONFIG PWRTEN = ON                        ' Power up timer enabled
    '@ CONFIG BOREN = SBORDIS                    ' Brown-out Reset enabled in hardware only (SBOREN is disabled)
    '@ CONFIG BORV = 285                         ' VBOR set to 2.85 V nominal
    @ CONFIG FOSC = INTIO67                      'Internal oscillator block
    OSCCON.6 = 1         '####################   111 = 16, 110 = 8
    OSCCON.5 = 0         '###### 16 MHz ######   101 =  4, 100 = 2
    OSCCON.4 = 1         '####################
    OSCTUNE.6 = 0        '##### PLL X 4 ######
    '@ CONFIG PLLCFG = ON          'Oscillator multiplied by 4
    '#######   Make Ports Digital   ##########
    ANSELA = $00                                 'SET PORT A ALL DIGITAL
    ANSELB = $00                                 'SET PORT B ALL DIGITAL
    ANSELC = $00                                 'SET PORT C ALL DIGITAL
    ANSELD = $00                                 'SET PORT D ALL DIGITAL
    ANSELE = $00                                 'SET PORT E ALL DIGITAL
    '===================================    INCLUDE FILES    ==========================================
    '===================================    SET PIC PORTS    ==========================================
    HCDATA var PORTC.5                               ' Pin 14 74HC595
    HCCLK  var PORTD.4                               ' Pin 11 74HC595
    HCLAT  var PORTC.7                               ' Pin 12 74HC595
    CIVP   VAR PORTA.5                               ' TO ICOM REMOTE PORT CI-V
    LCDP   VAR PORTB.0                               ' SERIAL LCD PORT (OPTIONAL)
    INFRA  VAR PORTD.7                               ' Infrared LED DATA
    'LED    VAR PORTC.0                               ' STATUS LED
    '====================================    SET VARIABLES    =========================================
    Leader VAR WORD                                  ' will be up to 900 for a 9mS leader pulse
    BtnVal VAR BYTE[32]                              ' holds 32 pulse results
    DByte1 VAR BYTE                                  ' address byte
    DByte2 VAR BYTE                                  ' inverse of address byte
    DByte3 VAR BYTE                                  ' command byte
    DByte4 VAR BYTE                                  ' inverse of command byte
    X      VAR BYTE                                  ' loop count
    Y      VAR BYTE                                  ' = DByte3 (command) for subroutines selection
    Z      VAR BYTE                                  ' Generic counter FOR-NEXT Loops (digits counter)
    RBdata VAR BYTE[6]                               ' Bytes array to store digits for frequency or memory
    f1     VAR BYTE                                  ' Vol, SQL, MSB byte
    f2     VAR BYTE                                  ' Vol, SQL, LSB Byte
    f3     VAR BYTE                                  ' BCD to BIN byte store for DEC calculations
    f4     VAR BYTE                                  ' BCD to BIN byte store for DEC calculations
    pattern   VAR Byte                                ' 74HC595 output pattern
    '=====================================     SET CONSTANTS    =======================================
    DL1    CON 800                                   ' > 8.5 ms pulse for NEC Protocol (Start) -  850 @ 4 MHz
    DL2    CON 110                                   ' > 1.5 ms pulse for NEC Protocol (read bit 0 or 1) @ 4 MHX
    LCDS   CON 16468                                 ' SERIAL LCD SPEED 16468 -> 9600
    LINE1  CON 128                                   ' LCD Line 1
    LINE2  CON 192                                   ' LCD Line 2
    I      CON 254                                   ' LCD general command
    CIVS   CON 84                                    ' "188"->4800, "84"->9600, "32"->19200 "813"->1200
    CIVA   CON $70                                   ' TRX address
    '#################################     PROGRAM STARTS HERE    #####################################
    START:
    CLEAR                                       '
    pattern = %00000000                         ' LED OFF
    gosub OUT_595
    PAUSE 200
    GOSUB LCDCLS
    PAUSE 10
    SEROUT2 LCDP,LCDS,["HELLO MALAKA"]
    pattern = %11111111                         ' LED ON
    gosub OUT_595
    gosub OUT_595
    gosub LCDCLS	                             ' Clear LCD
    '==============================   MAIN LOOP CHECKS FOR INFRARED COMMAND   =========================
    MAIN:
    PULSIN INFRA,0,Leader                            ' Leader pulse is ~9mS low-going
    IF Leader < DL1 THEN Main                        ' Valid start burst check > 8.5 ms
    GOSUB READ32                                     ' Read 32 bytes (0-15 for address and 16-31 for command)
    'GOTO MAIN                                       ' ONLY FOR TESTING AND READING VARIOUS NEC REMOTES
    GOSUB COMMANDS                                   ' GOTO Check Input Commands
    PAUSE 100
    GOTO MAIN
    '===================================   VOLUME UP SUBROUTINE    ====================================
    VOLUP:                                           ' All variables are set as bytes
    Z = $01                                          ' For future functions
    DO
    	IF Leader > DL1 THEN
    		GOSUB VOLUP1                ' Go to increase volume
    			pattern = 0
    			GOSUB Out_595
            	GOTO MAIN
    PULSIN INFRA,0,Leader                    ' Check again for start pulse (autorepeat function) WORKS
    LOOP
    GOTO VOLUP                                       ' Go back to main routine to check for another button press
    '================================   VOLUME INCREASE AND BYTE CALCULATIONS   =======================
    VOLUP1:
    GOSUB READVD
    IF f3 < 2 AND f4 >= 99 THEN
    	f3 = f3 + 1                                             ' Increase hundreds by 1
    ELSEIF f3 > 1 AND f4 > 54 THEN                              ' If volume > 254 stay to 254 (max)
    	f3 = 2
    	f4 = 54
    f1 = ((f3 / 10) << 4) + (f3 // 10)                          ' Convert bin to BCD
    f2 = ((f4 / 10) << 4) + (f4 // 10)                          ' Convert bin to BCD
    SEROUT2 CIVP,CIVS,[$FE,$FE,civa,$E0,$14,$01,f1,f2,$FD]      ' NEW VOLUME setting
    pause 50
    'GOSUB PRINTVAL                                              ' Only for testing and displaying actual volume
    '=====================================    RECEIVED COMMANDS    ====================================
    COMMANDS:
    Y = DByte3
    IF Y = 7 OR Y = 3 THEN               ' VOL - (added new NEC remote)
    	pattern = 1
    	GOSUB Out_595
    '	GOSUB VOLDOWN
    IF Y = 21 OR Y = 2 THEN              ' VOL + (added new NEC remote)
    	pattern = 1
    	GOSUB Out_595
    	GOSUB VOLUP
    '########################################################   CLEAR LCD   #########################################################
    LCDCLS:
    SEROUT2 LCDP,LCDS,[254,1]           	' Clear LCD
    Out_595:
    SHIFTOUT HCDATA,HCCLK,1,[pattern]                      ' send pattern to 1st 74HC595
    PULSOUT HCLAT, 5                                       ' latch outputs
    '================================   READ 32 Bytes - Address and Command   =========================
    READ32:
    FOR X = 0 TO 31                                  ' grab 32 incoming pulses
    PULSIN INFRA,1,BtnVal[X]                         ' now measuring high-going pulse widths
    NEXT X
    FOR X = 0 TO 7                                   ' sort 1st 8 pulses
    IF BtnVal[X] > DL2 THEN                          ' > 150 x 10uS = > 1.5mS pulse period
             DByte1.0[X]=1
             DByte1.0[X]=0
    NEXT X
    FOR X = 8 TO 15                                  ' sort 2nd 8 pulses, etc....
             DByte2.0[X-8]=1
             DByte2.0[X-8]=0
    NEXT X
    FOR X = 16 TO 23
             DByte3.0[X-16]=1
             DByte3.0[X-16]=0
    NEXT X
    FOR X = 24 TO 31
             DByte4.0[X-24]=1
             DByte4.0[X-24]=0
    NEXT X
    DByte4 = ~ DByte4                                ' Reverse all the 8 bits to compare
    IF DByte3 <> DByte4 THEN
    	GOSUB LCDCLS
    	SEROUT2 LCDP,LCDS, [I,LINE1,"Command ERROR !"]
    	GOSUB LCDCLS
    	pattern = 0
    	GOSUB out_595
    	GOTO MAIN
    SEROUT2 LCDP,LCDS, [I,LINE1,"A : ",DEC3 DByte1, "-",BIN8 DByte1] ' PRINT ADDRESS
    SEROUT2 LCDP,LCDS, [I,LINE2,"C : ",DEC3 DByte3, "-",BIN8 DByte3] ' PRINT COMMAND
    '==================================   Read Volume & SQL Data   ====================================
    READVD:
    SEROUT2 CIVP,CIVS,[$FE,$FE,CIVA,$E0,$14,Z,$FD]   ' Send this to the radio to read current SETTING
    SERIN2 CIVP,CIVS,[SKIP 6,f1,f2]                  ' Skip first 6 useless bytes and read next 2 bytes
    PAUSE 5                                          ' Give sometime to rest
    RETURN                                           ' Go back to set new Volume or Squelch
    Well, that's all folks...
    Thanx in advance
    Fanias
  1. Still Struggling with the formula!
    Last Post: - 10th April 2012, 06:58
  2. Struggling Newbie
    By plakey in forum mel PIC BASIC Pro
    Last Post: - 18th March 2012, 14:05
  3. Struggling with a P18f2550
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 7th November 2011, 07:58
  4. Still Struggling with IF THEN
    Last Post: - 25th March 2007, 10:47
