MPLAB/PBP Simulator
Results 1 to 3 of 3
    Alabama,USA
    Default MPLAB/PBP Simulator
    16F886, PBP2.60, MPLAB/PBP, Simulator
    Greetings,
    I am working on my first attempt at Modbus CRC16. I’ve decided to write the routine in ASM following a Modbus document on the calculation. SO it doesn’t look too bad for a starting point and now I would like to use MPLAB Simulator to find my faults.
    The Simulator starts OK and I’m using the “Step Into” button to single step the program. Everything looks correct until I leave the PBP portion of the program which declares the variables and equates values then I hit the ASM routine and all progress stops. No matter what I do the simulator jumps completely over the ASM section as if I had used the “Step Over” button. Break points do not work as expected either.
    Is this because I’m using MPLAB to compile PBP? Once upon a time I was much more efficient with the simulator but I stopped using ASM as primary code fifteen years ago. Is the failure my misunderstanding of the mix of PBP and ASM or is this a dead end when using MPLAB and PBP?
    Anyone know what the problem is?
    Wayne
    Default Re: MPLAB/PBP Simulator
    Go to the build options and uncheck Source-Level Debug.
    You should then see the -k- command line option in the global settings edit box.
    -k# is for debugging at the PBP level.
    -k- debugs at the assembly level.
    -k invokes the Linker, don't ever do that.
    Alabama,USA
    thanks Darrel, that did the trick!
    Wayne
  1. pbp 3 and MPLAB X
    By Marcick in forum mel PIC BASIC Pro
    Last Post: - 1st January 2017, 15:12
  2. PBP 2.6 and MPLAB 8.4
    By ChrisKiwi in forum mel PIC BASIC Pro
    Last Post: - 13th December 2011, 07:02
  3. Looking at pic basic pro symbol values in mplab 8.15a simulator
    By ukemigrant in forum mel PIC BASIC Pro
    Last Post: - 16th May 2009, 13:18
  4. MPLAB and PBP ...
    By Acetronics2 in forum Off Topic
    Last Post: - 28th August 2008, 20:51
  5. PBP in MPLAB
    By zagisrule! in forum mel PIC BASIC Pro
    Last Post: - 29th December 2005, 01:58
