how to control the contrast of GLCD
Results 1 to 10 of 10
    Feb 2012
    PERTH AUSTRALIA
    Default Re: how to control the contrast of GLCD
    the glcd generates the negative supply so using an opto transistor connected to the negative Vo output of the glcd to the glcd VLCD input ( contrast control ) is possible , not sure how linear an opto fet would be to adjust the voltage for the contrast though ,
    I had looked at a digital pot , but seems that the voltage cant be negative on the resistor divider network , in respect to the chips supply vdd and grd rails.
    Hello,
    Maybe something like this using a pnp in a open collector configuration. Much like we control a 12v relay with a NPN and a 5v mcu. Set the PWM to 50% duty and adjust the contrast pot to good level. Now you should have a +/- contrast changing the duty. Basic idea only. Might want to add a resistor and cap to the pwm line to smooth it out.
  1. Easy LCD Contrast
    By Melanie in forum Schematics
    Last Post: - 6th January 2015, 00:46
  2. Samsung 5'' GLCD 320x240 on sale, who knows control it?
    By HYETİK in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 21:38
  3. LCD contrast
    By Demon in forum General
    Last Post: - 21st March 2009, 16:19
  4. Controlling LCD contrast?
    By jblackann in forum mel PIC BASIC Pro
    Last Post: - 27th December 2006, 02:31
  5. How to change contrast LCD?
    By MCU Destroyer in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2005, 13:16
