Help with example button program
Results 1 to 9 of 9
Threaded View
  1. #5
    Default Re: Help with example button program
    Any ideas how I can improve this code? I'm trying to use a push button switch to toggle between 2 LEDs. For the most part it works, but the switch does not debounce very well. I'm actually trying to toggle between turning an LED on and turning a relay off, which is why one of the variables is named LATCH1, but for testing purposes I'm just using 2 LEDs.
    ' Name : BUTTONTEST.pbp
    ' Compiler : PICBASIC PRO Compiler 3.0
    ' Assembler : PM
    ' Target PIC : 8-pin PIC12F675 or similar type
    ' Hardware : Kee
    ' Oscillator : 4MHz internal
    ' Keywords : HIGH, LOW
    ' Description : PICBASIC PRO program to show button press on LED.
    #config
    __CONFIG _CP_OFF & _WDT_OFF & _BODEN_ON & _PWRTE_ON & _INTRC_OSC_NOCLKOUT & _MCLRE_OFF & _CPD_OFF
    #endconfig
    Define OSCCAL_1K 1 ' PIC12F675, Calibrate internal oscillatordefine MCLRE_OFF
    define BUTTON_PAUSE 65
    LED1 Con 0 ' Alias GPIO.0 to LED1
    LATCH1 con 1 'Alias GPIO.1 to LATCH1
    PB1 Var GPIO.2 ' Alias GPIO.2 to push button
    B1 var byte 'Working buffer for switch1 button command
    ANSEL = 0 ' Set all digital
    CMCON = 7 ' Analog comparators off
    clear
    low LED1 'Begin program with LED1 off
    high LATCH1 'Begin program with relay1 in bypass
    switch1:
    button PB1, 0, 40, 5, B1, 0, main
    toggle LATCH1
    toggle LED1
    Goto main ' Do it forever
  1. [Help] PIC 16F886 with 9 button program with CCS
    By keviltran in forum General
    Last Post: - 8th October 2013, 22:40
  2. Toggle program branch ussing interrupot by button?
    Last Post: - 14th September 2013, 10:58
  3. Replies: 1
    Last Post: - 23rd May 2009, 10:22
  4. button help
    By Kalind in forum mel PIC BASIC Pro
    Last Post: - 14th October 2008, 14:12
  5. Program Code and Program Memory
    By DenFrod in forum mel PIC BASIC Pro
    Last Post: - 8th February 2007, 15:51
