led blink help needed
Results 1 to 2 of 2
Threaded View
  1. #2
    Oct 2009
    Utah, USA
    Default Re: led blink help needed
    Which PIC are you using??
    make sure that you have analog inputs turned off.
    Most PIC's defalult to analog inputs turned on.
    Check the ANSEL register (or what ever the analog select register is for the PIC you are using)
    the "HIGH" and "LOW" command can mask this problem as it somehow disables the analog for that pin during that command (or something like that)
    anyway as I said, most PIC's default to analog inputs enabled.
    You need to turn off the analogs if you are just trying to blink an LED.
    Do you have the datasheet for your PIC?
    Dwight
  1. 18F2550 and Blink Led
    By nuno106 in forum mel PIC BASIC Pro
    Last Post: - 21st September 2022, 13:01
  2. need led blink program
    By asifiqbal in forum General
    Last Post: - 4th March 2014, 12:26
  3. Led blink and interrupt
    By critix in forum mel PIC BASIC Pro
    Last Post: - 24th April 2012, 12:31
  4. blink led 12f683
    By mel4853 in forum mel PIC BASIC Pro
    Last Post: - 19th January 2010, 23:39
  5. Using HPWM to blink an LED?
    Last Post: - 7th August 2006, 01:48
