beginer help needed
Results 1 to 7 of 7
    Mar 2014
    Pakistan
    Default Re: beginer help needed
    thankyou sir ur reply was helpful, i have another question to ask, my device is pic 16f72 and port b is digital
    when a programm run in a loop how can i intrrupt it for example
    high portb.7
    low portb.7
    now this loop keep repeating how can i intrrupt this loop ? if i write like this
    high portb.7
    low portb.7
    if portb.2=0 then
    portb.7 = 0
    intrrupt here doesnt work what is the way out to get out of the loop now
    high portb.7
    low portb.7
    if portb.2=0 then goto EXIT 'test for exit 1 time for each loop
    EXIT:
    portb.7 = 0
    remaining code goes here...........
    OR
    high portb.7
    if portb.2=0 then goto EXIT 'test for exit after setting port pin high
    low portb.7
    if portb.2=0 then goto EXIT 'test for exit after setting port pin low
    EXIT:
    portb.7 = 0
    EN82fn
    There are several ways of doing it.
    One way is to actually use a hardware interrupt, another way is to simply poll the input periodically as you go thru the loop. Yet another way is to move away from the loop structure and use a state machine aproach instead. Instead of using PAUSE, which "blocks" the processor, you can use hardware timers, either with interrupts or by simply polling the interrupt flag. It really depends on what you want to do and how fast you need to do it.
    If all you want to do is blink the LED untill an input goes high (or low) then you basically had it in the first example you posted. The drawback there is that the input is only checked once per iteration thru the loop so if the PAUSE is long there will be a long "reaction time".
    As you see there's not a single answer to your question, it all depends....
  1. PBP 3.0 really needed?
    By Mugelpower in forum FAQ - Frequently Asked Questions
    Last Post: - 17th December 2017, 20:19
  2. Beginer problems
    By luxornet in forum mel PIC BASIC Pro
    Last Post: - 5th February 2010, 05:55
  3. Beginer Help!
    By MINHLE in forum mel PIC BASIC Pro
    Last Post: - 5th July 2008, 04:57
  4. Help Needed
    By Bizhub in forum General
    Last Post: - 30th June 2007, 21:18
  5. Help needed to troubleshoot
    By ssocs45 in forum mel PIC BASIC Pro
    Last Post: - 26th February 2004, 19:00
