PORTB + PORTC Interrupt-On-Change
Results 1 to 28 of 28
    Default Re: PORTB + PORTC Interrupt-On-Change
    Hi Barry
    1/. Towlerg: "Why not use a logic analyser?" - simply because I don't have one. I also need to replicate this test in other parts of the world so I don't think purchasing multiple logic analysers is a cost effective approach to solving the problem.
    You can buy a Saleae for 119Euros. Accepted that you'll need an old laptop for display. It'll store billions of samples @ 24Mhz, thats at least a decade better that Darrel is suggesting, and he writes great code. How many samples before the PIC runs out of memory?
    Anyways, good luck with the project.
    George
    Jan 2011
    Sydney, Australia
    Hi George,
    Yes, there are always a number of different ways to "skin a cat" but if I went with the logic analyser route then I would have nothing to design and build using a PIC
    If we end up with more than a byte's worth of fault counts on any of the nine data lines within a one minute test period then we have more problems to worry about than a PIC running out of memory!
    Cheers
    Barry
    VK2XBP
    Jan 2011
    Sydney, Australia
    Hi All,
    I am still waiting for my PIC16F1783 chips to arrive so I have been doing some testing with a PIC16F1829.
    I am getting good results but unsure if my code can be improved. Here is the stripped down version for comment.
    ' Connect LCD D4 to RC4 (Pin 6)
    ' Connect LCD D5 to RC5 (Pin 5)
    ' Connect LCD D6 to RC6 (Pin 8)
    ' Connect LCD D7 to RC7 (Pin 9)
    ' Connect LCD RS to RC3 (Pin 7)
    ' Connect LCD E  to RC2 (Pin 14)
    ' Connect Data Line 1 to RA0 (Pin 19)
    ' Connect Data Line 2 to RA1 (Pin 18)
    ' Connect Data Line 3 to RA2 (Pin 17)
    ' Connect Data Line 4 to RA3 (Pin 4)
    ' Connect Data Line 5 to RA4 (Pin 3)
    ' Connect Data Line 6 to RA5 (Pin 2)
    ' Connect Data Line 7 to RB4 (Pin 13)
    ' Connect Data Line 8 to RB5 (Pin 12)
    ' Connect Data Line 9 to RB6 (Pin 11)
            __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _MCLRE_OFF & _BOREN_OFF
            __config _CONFIG2, _PLLEN_ON & _LVP_OFF & _WRT_HALF
    OSCCON = %11110000              ; Fosc = 32MHz
                                    ; Clock determined by Fosc<1:0> Config Word
    DEFINE OSC 32                   ; Define socillator as 32MHz
    Define	LCD_DREG	PORTC
    Define	LCD_DBIT	4
    Define	LCD_RSREG	PORTC
    Define	LCD_RSBIT	3
    Define	LCD_EREG	PORTC
    Define	LCD_EBIT	2
    Define	LCD_BITS	4
    Define	LCD_LINES	4
    PAUSE 500               ' Pause to initialise LCD Display
    ' Define program variables
    DisplayFlag var BIT
    DisplayFlag = 0
    Counter1    var BYTE
    Counter2    var BYTE
    Counter3    var BYTE
    Counter4    var BYTE
    Counter5    var BYTE
    Counter6    var BYTE
    Counter7    var BYTE
    Counter8    var BYTE
    Counter9    var BYTE
    IOCA        var BYTE
    IOCB        var BYTE
    Counter1 = 0
    Counter2 = 0
    Counter3 = 0
    Counter4 = 0
    Counter5 = 0
    Counter6 = 0
    Counter7 = 0
    Counter8 = 0
    Counter9 = 0
    ANSELA = 0                      ' Disable PORTA ADC
    ANSELB = 0                      ' Disable PORTB ADC
    ANSELC = 0                      ' Disable PORTC ADC
    DACCON0.7 = 0                   ' Disable DAC
    CM1CON0.7 = 0                   ' Disable comparator 1
    CM2CON0.7 = 0                   ' Disable comparator 2
    TRISC = %00000001               ' Set PORTC.0 and PORTC.1 as digital input
    TRISA = %00111111               ' Set PORTA as digital inputs
    TRISB = %01110000               ' Set PORTB.4-6 as digital inputs
    OPTION_REG.7 = 0                ' Enable Weak Pull-ups
    WPUA = %00111111                ' Pull-ups enabled on PORTA.0 - 5
    WPUB = %01110000                ' Pull-ups enabled on PORTB.4 - 6
    WPUC = %00000001                ' Enable PORTC.0 pull-ups
    IOCAP = %00111111               ' Enable IOC rising edge on PORTA.0-5
    IOCBP = %01110000               ' Enable IOC rising edge on PORTB.4-6
    IOCAN = 0                       ' Disable IOC falling edge on PORTA
    IOCBN = 0                       ' Disable IOC falling edge on PORTB
        IOCA = IOCAF                ' Save IOCAF to IOCA
        IOCB = IOCBF                ' Save IOCBF to IOCB
        IOCAF = 0                   ' Reset IOCAF
        IOCBF = 0                   ' Reset IOCBF
        IF IOCA > 0 OR IOCB > 0 THEN    ' Test if IOC Flags have changed
            DisplayFlag = 1             ' If so, set Display flag
        Counter1 = Counter1 + IOCA.0
        Counter2 = Counter2 + IOCA.1
        Counter3 = Counter3 + IOCA.2
        Counter4 = Counter4 + IOCA.3
        Counter5 = Counter5 + IOCA.4
        Counter6 = Counter6 + IOCA.5
        Counter7 = Counter7 + IOCB.4
        Counter8 = Counter8 + IOCB.5
        Counter9 = Counter9 + IOCB.6
        IF DisplayFlag = 1 THEN         ' Go to Display subroutine if DisplayFlag set
            Gosub Display
            DisplayFlag = 0             ' Reset DisplayFlag
    GOTO Main
    Display:
        LCDOUT $FE, $80, "    Fault Status    "
        LCDOUT $FE, $C0, "1. ", DEC3 Counter1, " 2. ", DEC3 Counter2, " 3. ", DEC3 Counter3
        LCDOUT $FE, $94, "4. ", DEC3 Counter4, " 5. ", DEC3 Counter5, " 6. ", DEC3 Counter6
        LCDOUT $FE, $D4, "7. ", DEC3 Counter7, " 8. ", DEC3 Counter8, " E. ", DEC3 Counter9
    Any suggested improvements would be greatly appreciated.
    Cheers
    Barry
    VK2XBP
    Hi Barry,
    First suggestion is very minor but still, clear IOCAF immediately after reading it, ie
    The longer the time is between reading it and clearing it is the bigger the risk of missing an "event" is. In this case, as I said, very minor but still.
    Next suggestion is to really try to tweak the display routine. Measure how long it takes now, then tweak it and compare. You want to make it as quick as you possibly can.
    With tweaking I mean things like not rewriting static information each update. Instead, write the static information ONCE and then only update/overwrite what's actually needs to be updated.
    You could, for example, use the bits in IOCA and IOCB to determine which counters content actually needs updating on the display. A possible drawback of doing this is that the execution time of the routine isn't constant so it's hard to tell exactly how fast the system will be able to detects consecutive events on the same "line". At the very least, don't rewrite that [ Fault Status ] - waste of time ;-)
    As the code is currently written, I think you can skip the DisplayFlag semaphore and just do
        GOSUB Display
    But you may have something else in there preventing you from doing that, I don't know.
    Another possible option to flip it around and have the Display routine as part of your main code (with the flag indicating it needs updating) and then GOSUB the code that checks the interrupt flags. That way can insert a GOSUB at various places WITHIN the Display routine (and the rest of the main loop) in an effort to really catch multiple events on the same line.
  1. PortB Change Interrupts
    By backstabber in forum mel PIC BASIC Pro
    Last Post: - 8th October 2011, 04:52
  2. Replies: 10
    Last Post: - 24th September 2011, 19:09
  3. Replies: 6
    Last Post: - 12th March 2011, 14:11
  4. Returning from Int on PortB change
    By sheryl in forum mel PIC BASIC Pro
    Last Post: - 11th December 2008, 19:09
  5. Interrupt portb
    By tazntex in forum mel PIC BASIC Pro
    Last Post: - 18th August 2008, 22:05
