ADCIN does not work with AN16
Results 1 to 5 of 5
    Dec 2009
    Canada
    Default ADCIN does not work with AN16
    Hello All,
    Is there any limitation in analog input #? I have ADCIN working OK with AN15 but it does not work with AN16.
    Defines are standard:
    DEFINE ADC_BITS 10 'Set number of bits in result
    DEFINE ADC_SAMPLEUS 50 'Set sampling time in uS
    DEFINE ADC_CLOCK 3
    adcin 16 , READING returns a value around near 14000 (READING is word) which is strange for 10 bit conversion...
    I use microcontroller PIC18F25k22
    adcin 15 works OK
    Can someone comment please?
    Thank you
    Default Re: ADCIN does not work with AN16
    Anselc correctly set ?
    Dec 2009
    Canada
    Yes,
    ANSELC = %11000 'C.3, C.4 analog
    C.3 and C.4 are AN15 and AN16
    I suspect that unless there is my mistake somewhere, input # may be a byte variable in PBP3
    I did the reading manually:
    ADCON2 = %10000000 '111 'LEFT JUSTIFIED(0),not used,...
    ADCON0 = %1000001 'AN16 USED 10000, NO GO NOW,STAY ON
    ADCON1 = %1000 'VOLTAGE REFFERENCES
    VREFCON0 = %10010000 'ENABLED, SET FOR 1.024 VOLT
    RefNotReady:
    IF VREFCON0.6 = 0 THEN GOTO RefNotReady
    PAUSEUS 50
    ADCON0 = %1000011 'GO NOW
    ADCNotComplete:
    IF ADCON0.1 = 1 THEN GOTO ADCNotComplete
    AMB_TEMP.BYTE1 = ADRESH
    AMB_TEMP.BYTE0 = ADRESL
    VREFCON0 = 0 'DISABLE REFERENCE
    ADCON1 = 0
    ADCON0 = 0 'CONVERTER OFF, NO CURRENT
    This seems to be working well
    Dec 2010
    Which version of PBP are you using? The manual does not mention any limit to the number of addresses, but it is suspicious that 0-15 work and 16 and up do not...
    Dec 2009
    Canada
    It is PBP3 3.0.7.4, must be the most recent. Actually I did not try higher #s than 16.
  1. Help with ADCin
    By RDavid60 in forum mel PIC BASIC Pro
    Last Post: - 18th May 2011, 03:56
  2. Adcin, can't get it right
    By atwoz in forum mel PIC BASIC Pro
    Last Post: - 4th January 2008, 21:38
  3. adcon1/ adcin
    By Patrick in forum mel PIC BASIC Pro
    Last Post: - 9th July 2006, 08:39
  4. help using adcin
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 31st January 2006, 08:46
  5. ADCIN Help
    By Tear in forum mel PIC BASIC Pro
    Last Post: - 25th July 2005, 19:47
