I can't comment on SMbus, but be aware of the voltage used by the vehicule (assuming it is one). In Canada, cars use 12 volts DC; PICs work on 5 V DC max. Just be aware you might need a voltage divider to lower the voltage at input, depending on the maximum voltage from the sensor.
Don't forget to compensate for any battery charging circuit as well. In Canada, alternators can go beyond 14V DC.
Hi Robert,
thanks for the reply
i have the hardware issues under control, there is an Li-ion pack with a fuel gauge being specified and my question is strictly about the firmware compatibility of the I2CRead I2CWrite compatibility with the SMBus and the SBS on fuel gauge type chips
