4 x 20 LCD display with PB3 - Pin 5 High or Low?
Results 1 to 9 of 9
    Oct 2011
    East Coast USA
    Default Re: 4 x 20 LCD display with PB3 - Pin 5 High or Low?
    Thanks Darryl,
    Silly question: Is there feedback from the display to the Lcdout routine (I'm thinking of the 4 bit communication) or is the pic blindly sending data to the LCD and relying on timing for the LCD to grab data?
    Thanks again.
    No, there is no feedback to the LCDOUT routines.
    If the program stops or the chip resets when trying to display things, it could be that you have LVP enabled in the configs, and the LCD uses the PGM pin.
  1. 4x40 LCD Display Enable Pin
    By rsocor01 in forum General
    Last Post: - 10th August 2011, 03:50
  2. Use of HIGH and LOW for pin outputs
    By rnuke77 in forum mel PIC BASIC Pro
    Last Post: - 27th January 2011, 19:40
  3. Replies: 5
    Last Post: - 14th May 2010, 04:21
  4. Reading if Pin is High or Low?
    By Spindle in forum mel PIC BASIC Pro
    Last Post: - 1st August 2005, 18:39
  5. Replies: 0
    Last Post: - 25th May 2005, 11:35
