How do I discern Maidenhead Locator from GPS lat long info.
Results 1 to 40 of 126
    Oct 2010
    Default Re: How do I discern Maidenhead Locator from GPS lat long info.
    thanks for the info once again. Is not a place to analyze it more, and im the one i need to understand better the differences of the chip's performance.
    Last question based on the pps, do you mean pulse per second? OK just checked this, Peripheral pin select
    I've also checked the supported devices from PICkit2 for k22 series : PIC18F13K22 PIC18LF13K22 PIC18F14K22 PIC18LF14K22
    No K42 is supported.
    your pk2 device list file is out of date, there are many more k22 chips supported .
    Oct 2010
    ooops i dint know.
    i tried many times to check if there is a newer version and didnt find any that 2.61 with the devicefile 1.61.
    I will check again. thanks for the update really i didnt know it.
    Oct 2010
    First of all i need to Apologize for my absent.
    Now :
    1. Didnt find and Update for pickit2. Not a problem because i will think to use the following PICs and i see that pickit2 at the moment supports it.
    2. As far as the pic16f88 is limited in ram i need to step up and use a better microcontroller. Im Looking at the PIC18F4550 or PIC18F2550.
    3.The project as i have it in mind need to have an SD in order to store the Data from GPS Nmea.
    I found out that only a microcontroller with 48mhz supports something like that. Apart from that i have a question.
    May i use the same speed for All the peripherals SD, Ulcd, GPS? Or do i need to specify different one for each module?
    May i use 48mhz for processor speed and use low speed baudrate to communicate for Serial?
    Could You help me and clarity what i need for each GPS, SD, Ulcd?
    So i need to communicate Serial with GPS module and then i need to store the raw Nmea Data to SD and display what i need from the Nmea protocols to display.
    Jan 2014
    Quote Originally Posted by astanapane View Post
    ooops i dint know.
    The file "PK2Devicefile.dat" have not edited the microcontroller type. Use DEVICE EDITOR software from here https://sites.google.com/site/pk2devicefileeditor/ and here is the Device ID PIC's
    where did you find that , its not what I understand the case to be. are you confusing usb support for sd card support ?
    unless you specify what spi rate the sd card supports and what sd card system you intend to use [sdfs3 ? fat16? fat 32?] along with
    the baud rate used for the serial I/f's and your osc speed it would be guesswork only.
    not really you need to supply a lot more info
    compared to PIC18F4550 or PIC18F2550 a pic 18f26k22 has two times the flash memory , sram ,spi ports, eusarts has more timers and can run at 64 MHz . I think it would be a good fit
    for that sort of project
    Oct 2010
    Oops well i'm wrong, base on the following and FAT16 it is not necessary.
    http://melabs.com/samples/PBP-mixed/sdfs3.htm
    I was confused with this link as they specify high MCU speed for FAT32
    http://www.picbasic.co.uk/forum/showthread.php?t=18370
    Regarding Serial speed baudrate:
    1) For GPS, i have tried to send the "right" command for increase the baudrate, with no sucess....it seems that the GPS receives the command but does not like it :P.
    2) ulcd seems to work with higher baud rate, but i need to configure the delay times for each command. I havent really understand how to increase the baudrate corresponding to delays. The ulcd needs some delay time to accept the command and display it properly. Is it right?
    3) SD card with FAT 16 (when i reach that point we will discuss further). At the moment it is clear that up to 2GB fat 16 is required and is not necessary high MCU speed. But i will try to get the maximum from the PIC.
    I understand that im not clear, as i really wont have the knowledge to explain it. Actually im confused with MCU speed, which is the speed that PIC running each command and calculate each command, with the speed of the communication ports.
    I guess that a higher MCU speed is better in order to calculate faster the information from the peripherals. I know my questions are too basic, and believe me i start reading all these stuff in order to understand better. I feel that you cannot help me i i dont understand these basic processes of the PIC.
    So i started to read about MCU speed, clock and counter.
    Really appreciate your advice....PIC18LF26K22 or PIC18LF4550 fits to my project better because i would like to use a single 3.7V Lipo battery not more than 800-1000mha. The Final circuit will have:
    1. PIC18LF26K22 or PIC18LF4550
    2. GPS module for all the info....Date, Time, Speed, Coordinates etc.
    3. SD for storage the raw NMEA Data
    4. A display only for the on the go use. For battery saving, a ulcd will not be used normally. SD will keep the info.
    Many thanks once again.
    I would like to apologize for "breaking" the original TOPIC. Is it possible an Admin to move all the discussion i have started from POST #66, in a NEW thread? Thanks.....
    the data sheet for the module should resolve that issue
    the ulcd data sheet should give you that information
    since sd cards use spi [a synchronous data transfer method] cpu osc speed is largely irrelevant as long as it not too fast for the card/mssp combination
    when you use the mssp module there are several spi clock options.
    a PIC18LF4550 is in my opinion not a good choice , the project calls for a chip with two eusarts.
    I agree, as I have said from the start what you are asking has no relevance to maidenhead in any way shape or form
    Quebec, Canada
    Some modules requires you to send a checksum at the end of the command. Here for a NEO-6M GPS Module:
    'Turn off RMC - Recommended minimum specific GPS/Transit data
    hserout2 ["$PUBX,40,RMC,0,0,0,0,0,0*47", 13, 10]
    'Turn off GSA - GPS DOP and active satellites
    hserout2 ["$PUBX,40,GSA,0,0,0,0,0,0*4E", 13, 10]
    'Turn off GSV - GPS Satellites in view
    hserout2 ["$PUBX,40,GSV,0,0,0,0,0,0*59", 13, 10]
    'Turn off GLL - Geographic position, latitude / longitude
    hserout2 ["$PUBX,40,GLL,0,0,0,0,0,0*5C", 13, 10]
    'Turn on  ZDA
    hserout2 ["$PUBX,40,ZDA,0,1,0,0,0,0*45", 13, 10]
    Do you really need to change the baud rate? If you are just logging then 9600 is more than enough.
    FYI, here is my source for most of the NMEA sequences: http://aprs.gids.nl/nmea/
    Oct 2010
    Quote Originally Posted by midali View Post
    Really thanks a lot for your kind help. I would keep the dat. file as it is for now. I'm a bit afraid to play with that .dat file at the moment. If i need to use a PIC that is not on the pickit2 list, then i will give it a try.
  1. LAT replaces PORT command?
    By markscotford in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2011, 17:37
  2. Need Info for PBP?
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 30th January 2009, 08:44
  3. Replies: 1
    Last Post: - 27th July 2008, 07:14
  4. dmx info.
    By oscar in forum mel PIC BASIC Pro
    Last Post: - 8th May 2005, 12:54
