Hi Richard,
i need to thank you again for your time. I'll start from the part of what version am i using.
It is an old one, Pic Basic Pro 2.5 with MCSP version 3. I got it from a guy who purchased the PBP 3.0 full pack and gave me this one. I really appreciate his help as well. I have the CD and manual no any identification key on it.
Now with people like you helping here, i'm thinking also to purchase the PBP 3.1 with MCSPX 5. (but i would like to know if i could use one license with two computers) Anyway it is not a place to discuss it right now.
Lets go to coding now.
This is a mesh code, because up to now i try to add code for a specific function and then Quote some parts of the code in order to use them later if needed.
'*  Author  : LEONARDO BILALIS                                  *
'*  Notice  : Copyright (c) 2018 [LEONARDOS BILALIS]            *
'*  Date    : 12/5/2018                                         *
'*  Notes   : This is an G.TOP015 G9 MT3333 gps module          *
@ ERRORLEVEL -306 ; this command prevents the compiler to give you a notice of
                  ; crossing page boundary - make sure bits are set
@ __config _CONFIG1, _HS_OSC & _WDT_OFF & _LVP_OFF & _CP_OFF
Include "MODEDEFS.BAS"
DEFINE OSC 8
OSCCON=%01111000     '8 Mhz
CMCON = 7            'turn comparators off
ANSEL = 0            'All digital
PORTB = 0            'make low all ports at B range
input portb.0        'make input portb.0
'                           [ ULCD 1'44 4D System ]                          /
' "o" degree character is manual created for degree value
'                              [ PIC Variables ]                            /
PWRLED      var     PORTb.1   ; this shows that the initialization is finished
LCD         var     PORTb.2   ; to LCD operation
GPS_TX      var     PORTb.0   ; info from GPS
GPS_RX      var     PORTb.4   ; COMMANDS TO GPS
Testled     var     PORTb.5
dots        var     byte
dots = 21
countremain var     byte      ; we use a countremain to check the incoming from portb.0
;serout2 gps_rx,84, ["$PMTK330,62*1A",13,10]      ' check MTK manual configuration
' --------------------[ GPS Variables for NMEA sentenses ]---------------------/
'   $GPRMC,090045.000,A,3823.6645,N,02353.3600,E,0.02,195.80,170518,,,A*62   /
'   $GNGGA,140405.000,3823.6010,N,02353.3054,E,1,9,0.88,0.8,M,35.9,M,,*40   /
Timeout     con     2000
hh          var     byte    'hours
mm          var     byte    'minutes
ss          var     byte    'seconds
sss         var     word    'milisecs
degrees		VAR     BYTE	'latitude/longitude degrees
minutes		VAR		BYTE	'latitude/Longitude minutes
minutesD	VAR		word	'latitude/LONGITUDE DECIMAL MINUTES
dir       	VAR     BYTE   	' direction (latitude: 0 = N, 1 = S / longitude: 0 = E, 1 = W)
degrees2	VAR     BYTE	'latitude/longitude degrees
minutes2	VAR		BYTE	'latitude/Longitude minutes
minutesD2	VAR		word	'latitude/LONGITUDE DECIMAL MINUTES
dir2        var     byte    ;direction (latitude: 0 = N, 1 = S / longitude: 0 = E, 1 = W)
SatNo   	VAR		BYTE	'number of satellites connected
knots       var     word    'speed over ground
knots2      var     byte    'speed over ground
course      var     word    'course
course2     var     byte    'course
day         var     byte    'day
month       var     byte    'month
year        var     byte    'year
i           var     word
GNRMC       var     word    'protocol
GNGGA       var     WORD    'protocol
FIX         var     word    'fix sat V/A
Modefix     var     byte    'mode fix 1 or 2 or 3 depens
horizon     var     byte
precision   var     byte
meter       var     byte
METERS      var     byte
Meters2     var     byte
Day_added   var     byte
Numofdays   var     byte            'these are the days of each months
ndays       var     byte    [13]    'create an array with 13 byte location for Months values
'                          [ LCD Initialization ]                         /
high testled
serout2 LCD,32,[$55]      ' uOLED Initialize
pause 2000
serout2 lcd,32,[$56,$01]
serout2 lcd,32,[$45]      ' clear the lcd
serout2 lcd,32,[$55]
serout2 lcd,32,[$45]      ' clesr the lcd
serout2 lcd,32,[$73,$00,$03,$11,$ff,$ff," Leonardo Bilalis",$00]
pause 200
serout2 lcd,32,[$73,$02,$06,$10,$ff,"     Copyright 2018",$00]
pause 3000
serout2 lcd,32,[$73,$02,$06,$10,$ff,$ff,"      GPS.........",$00]
pause 200
'     [ After the lcd initialization we power the Led at PIC ]        /
HIGH pwrled
'----------------------sent a centence to gps------------------------
'Here i was planning to send a code to the GPS, i will find out the way later once i fix the Calendar part
;serout gps_rx,84,[$PMTK_103*30,,,]
;pause 100
'                         [MAIN Program]                           /
'                    [ Example NMEA Sentense of GNRMC ]                       /
' [$GNRMC,090045.000,A,3823.6645,N,02353.3600,E,0.02,195.80,170518,,,A*62]   /
serin2  gps_tx,84,timeout,lostcable,[wait("$GNRMC"),_           ;we wait for $GNRMC
wait(","),dec2 hh,dec2 mm,dec2 ss,wait("."),dec3 sss,_          ;we wait for 090045.000 which is the time when we got the info
wait(","),fix,_                                                 ;we wait for A
wait(","),dec2 degrees,dec2 minutes,wait("."),dec4 minutesd,_   ;we wait for 3823.6645
wait(","),dir,_                                                 ;we wait for N/S
wait(","),dec3 degrees2,dec2 minutes2,wait("."),dec4 minutesd2,_;we wait for 02353.3600
wait(","),dir2,_                                                ;we wait for E/W
wait(","),SKIP 4,_         ; i also used SKIP command but doesnt look like the compiler identified it as long as is not in Capital / Bold. But seems to be working and compiling the code.
wait(","),SKIP 6,_
wait(","),dec2 day,dec2 month,dec2 year]                        ;we wait for 170518
'wait(","),dec1 knots,wait("."),dec2 knots2,_                    ;we wait for 0.02
'wait(","),dec3 course,wait("."),dec2 course2,_                  ;we wait for 195.80
'                     [ Example NMEA Sentense of GNGGA ]                     /
' [$GNGGA,140405.000,3823.6010,N,02353.3054,E,1,9,0.88,0.8,M,35.9,M,,*40    /
serin2 gps_tx,84,timeout,lostcable,[wait("$GNGGA"),_            ;we wait for GNGGA
wait(","),SKIP 37,_
wait(","),dec2 satno,_
wait(","),SKIP 19]
;wait(","),dec2 hh,dec2 mm,dec2 ss,wait("."),dec3 sss,_          ;we wait for 140405.000 which is the time when we got info
;wait(","),dec2 degrees,dec2 minutes,wait("."),dec4 minutesd,_   ;we wait for 3823.6010 longitude
;wait(","),dir,_                                                 ;we wait for the N/S
;wait(","),dec3 degrees2,dec2 minutes2,wait("."),dec4 minutesd2,_;we wait for 02353.3054 latitude
;wait(","),dir2,_                                                ;we wait for E/W
;wait(","),modefix,_                                             ;we wait for modefix 1,2 or 3 check gps manual for NMEA
;wait(","),dec2 satno,_                                          ;we wait for the number of fixed satellites, this is impoetant info
;wait(","),dec3 horizon,dec precision,_                          ;we wait for horizon
;wait(","),meter,dec2 METERS,dec Meters2]                        ;we wait for the meters
' Here if the GPS module havent been fixed to any satellite will jump to notfix  /
if fix = "V" then notfix
'                           [ Return from notfix ]                           /
'                   [ We clear any character on the display ]               /
serout2 lcd,32,[$45]     'Clear the ulcd 1'44
'                   Here we start the calendar conversion                    /
; arraywrite ndays,13,NDAY,[0,31,28,31,30,31,30,31,31,30,31,30,31] ; This Code doesnt compile as there is a syntax error.
; numofdays=ndays[month]
day_added = 0
hh = hh + 3             'the Hour from GPS is UTC so for our country in Greece we add +3
if  hh > 23 then        'if the hh+3 hour is greater than 23 (23:00) then
day_added = 1           'we check the day added is true
hh = hh//24             'but the hour not exceed the 24 so go to 00:00
if day_added = 1 then   'now if day added is true
day = day + 1           'then ADD 1 day
if day > Numofdays then   'if day is greater than the numbers of the days in this month
lookup month,[0,31,28,31,30,31,30,31,31,30,31,30,31],numofdays
day = 1                 'then day goes to number 1
if month > 12 then      '
month = 1               'then day goes to number 1
year = year +1          'and the year will increase by 1
if ((year//4 = 0) and (year//400 != 0)) then
year = 1
if month = 2 then
numofdays = numofdays + 1
' here is where the code dispays the stored info from the NMEA sentenses  /
serout2 lcd,32,[$73,$03,$00,$00,$FF,$FF," Protocol:","NMEA",$00]
serout2 lcd,32,[$73,$01,$02,$01,$07,$E0," Date:",dec2 day,"/",dec2 month,"/",dec2 year,$00]
serout2  lcd,32,[$73,$00,$04,$00,$FF,$E0,"   TIME: ",dec2 hh," :",dec2 mm," :",dec2 ss,$00]
serout2 lcd,32,[$73,$00,$07,$00,$FF,$FF," Satellites",$00]
serout2 lcd,32,[$73,$03,$09,$11,$07,$FF,dec2 satno,$00]
serout2 lcd,32,[$73,$00,$07,$00,$FF,$FF,"               Fixed",$00]
serout2 lcd,32,[$73,$0B,$09,$11,$07,$FF,fix," 3D",$00]
serout2 lcd,32,[$73,$00,$0B,$00,$ff,$ff," Lat : ",dec2 degrees,"*",dec2 minutes,"'",dec4 minutesd,"@"," ",$00]
serout2 lcd,32,[$73,$BE,$0B,$10,$f8,$00,dir,$00]
serout2 lcd,32,[$73,$00,$0D,$00,$ff,$ff," Lon :",dec3 degrees2,"*",dec2 minutes2,"'",dec4 minutesd2,"@"," ",$00]
serout2 lcd,32,[$73,$BE,$0D,$10,$f8,$00,dir2,$00]
;serout2 lcd,32,[$73,$00,$0C,$00,$ff,$ff,"GND SPEED : ",(dec knots,".",dec2 knots2)*/1.852,$00]
;pause 200
;serout2 lcd,32,[$73,$00,$0E,$00,$ff,$ff,"Meters : ",dec2 METERS,dec Meters2,$00]
pause 5000
serout2 lcd,32,[$45]  ' clears the LCD
'                              [ SUB ROUTINES ]                              /
'                         [ Calendar days in Months ]                        /
'The following i was planning to use it with ARRAYWRITE but cant seem i can get it working.
NDAY:
ndays[0] = 0
ndays[1] = 31       'January
ndays[2] = 28       'February
ndays[3] = 31       'March
ndays[4] = 30       'April
ndays[5] = 31       'May
ndays[6] = 30       'June
ndays[7] = 31       'July
ndays[8] = 31       'August
ndays[9] = 30       'September
ndays[10] = 31      'October
ndays[11] = 30      'November
ndays[12] = 31      'December
'                         [ Waiting for GPS signal ]                         /
notfix:     ' Still looking for fixed signal
serout2 lcd,32,[$73,$00,$03,$11,$07,$ff,"   Waiting for GPS",$00]
hh = hh + 3
hh = hh//24
serout2 lcd,32,[$73,$03,$06,$10,$ff,$E0," Time:",dec2 hh," :",dec2 mm," :",dec2 ss,$00]
serout2 lcd,32,[$73,$00,$08,$10,$07,$ff,rep "." \dots,$00]
pause 200
goto main       'returns to main
'                 [ Connection lost Please check the GPS ]                   /
lostcable:
serout2 lcd,32,[$73,$00,$03,$11,$f8,$00,"  Connection lost",$00]
pause 200
serout2 lcd,32,[$73,$01,$06,$10,$07,$FF,"  Please check cable",$00]
pause 2000
'                      GREEK TIME and Correcrion                         /
' at the moment this is not connected to any part of the code
;Plusthree:
;  hh = hh + 3
;  IF hh = 25 THEN hh = 0
;RETURN
'                              [ CLEAR LCD ]                               /
Clearlcd:
Regarding the following part of the code, MARKED items with RED by Richard i will fix it on my next message. I think it is clear what needs to be done. Thanks once again.
day_added = 0
how can you test if day is greater than the month has before you have looked up how many days the month has ?
lookup month,[0,31,28,31,30,31,30,31,31,30,31,30,31],numofdays 'here it is suppose to look at a table NDAYS for each month
if month > 12 then 'if month is greater than 12 which is December
month = 1             ' then month will go to 1, January
year = year +1      ' and the year will increase by 1
what is the point of checking if its a leapyear and the month is feb after you have already  tested the number of days for month limit
year = 1
if month = 2 then numofdays = numofdays + 1
