How do I discern Maidenhead Locator from GPS lat long info.
Results 1 to 40 of 126
    Dec 2011
    IO93ok
    Default Re: How do I discern Maidenhead Locator from GPS lat long info.
    Hmm, guess which pins are not catered for on pcb ?
    Redesign methinks.
    Rob.
    The moment after you press "Post" is the moment you actually see the typso
    Dec 2011
    IO93ok
    Redesign completed. New board made where all pins are accessible and pads for option of pullups/down resistors.
    I have altered the software to use HSERIN and HSEROUT and all is well at the moment. It is working just fine.
    Using the code in previous post:
    My aim was to display the clock triggered by the gps pps signal. I tried DT_Ints and added the @ INT_RETURN where the original Clock sub had RETURN. This caused the display to only update the very first square with random characters per second with PPS signal.
    This is the setup naming Clock. I wasn't sure where to put the INT_Enable . I tried just after this ASM and at beginning of Clock routine with same result.
            INT_Handler    INT_INT,        _Clock,      PBP,  yes
    @   INT_ENABLE   INT_INT     ; enable external (INT) interrupts
    Rob.
    Dec 2011
    IO93ok
    This is the full code with the Ints active but it's just updating first character.
    ;        GPS NMEA Display code with GPSDO monitoring
    ; 			         PIC16F876A
    ;                                   __________
    ;                          !MCLR |1        28| RB7------D7
    ;     PLL Volt--AN0---RA0 |2        27| RB6------D6
    ;    adc spare--AN1---RA1 |3        26| RB5------D5
    ;    adc spare--AN2---RA2 |4        25| RB4------D4
    ;    adc spare--AN3---RA3 |5        24| RB3------LCD E
    ;                  spare---RA4 |6        23| RB2------LCD RS
    ;    adc spare--AN4---RA5 |7        22| RB1------spare
    ;                Ground---Vss |8        21| RB0------PPS In
    ;                OSC1---XTAL |9        20| VDD------ +5 V
    ;                OSC2---XTAL |10       19| Vss------Ground
    ;                  spare---RC0 |11       18| RC7------H-RX -- GPS NMEA In
    ;                  spare---RC1 |12       17| RC6------H-TX -- GPS Command Out
    ;                  spare---RC2 |13       16| RC5------spare
    ;               Pbutton---RC3 |14       15| RC4------spare
    ' Program to display returned value of a GPS NMEA string on RA4
    ' LCD in 4-BIT mode PIC16F876a controller 4Mhz clock Fuse PWRT BODEN
    'Typical GPS sentence string: $GPRMC,192144.62,A,5041.6058,N,00412.6124,E,0.45,3 57.74,081205,,*0B
    'The default sentences are continuously output.
    'Now suppose I want to read only one particular sentence I need to program the GPS to do that.
    'The input message  ILOG controls which sentences are logged.
    '$PRWIILOG,???,V,,,\r,\n
    'Inputting this sentence, disables all the sentences.
    'Now suppose we want only RMC sentence then input the following sentence serially to gps
    '$PRWIILOG,RMC,A,,,,\r\n
    'The \r() and \n () are sentence terminator in NMEA
    'V disables that particular sentence while A enables that sentence.
    @  __config  _HS_OSC & _WDT_ON & _PWRTE_ON & _BODEN_OFF & _LVP_OFF & _CPD_OFF & _WRT_OFF & _DEBUG_OFF & _CP_OFF
    ; Place a copy of these variables in your Main program for digit characters--
    ;--   The compiler will tell you which lines to un-comment                --
    ;--   Do Not un-comment these lines                                       --
    ;wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    wsave   VAR BYTE    $70     SYSTEM       ' alternate save location for W
    'wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    'wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    ;wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
                              ; Must use the 32-bit Floating Point routines
    INCLUDE "FP2032.bas"      ; 32-bit Floating Point for 14-bit cores with RAM at $20
    INCLUDE "Average.bas"     ; DT's 16-bit Analog Module averaging values
    INCLUDE "DT_INTS-14.bas"  ; Base Interrupt System
    INCLUDE "ReEnterPBP.bas"
    Define LCD_DREG PORTB     ' Port for LCD Data
    Define LCD_DBIT 4         ' Set LCD starting data bit
    Define LCD_RSREG PORTB    ' Port for RegisterSelect (RS) bit
    Define LCD_RSBIT 2        ' Port Pin for RS bit  (pin9)
    Define LCD_EREG PORTB     ' Port for Enable (E) bit
    Define LCD_EBIT 3         ' Port Pin for E bit    (pin7)
    Define LCB_BITS 4         ' Using 4-bit bus
    Define LCD_COMMANDUS 1500 ' Command Delay (uS)
    define LCD_DATAUS 50      ' Data Delay (uS)
    DEFINE ADC_BITS 10        ' Setup ADC
    DEFINE ADC_SAMPLEUS 5
    DEFINE ADC_CLOCK 1
    DEFINE HSER_BAUD 4800
    OPTION_REG.6 = 1            ' Interrupt rising edge
    OPTION_REG.7 = 0            ' Enable Pull-Up's
    PPS VAR PORTB.0
    Pbutton VAR PORTC.3
    ' Initialise ADC
    ADCON1 = %10000100 ' Set PORTA analog and RIGHT justify result
    ADCON0 = %01000001 ' Configure and turn on A/D Module channel 0 Fosc 8
    'Declare variables
    volt VAR WORD     ' scaled value real part
    voltd1 VAR WORD   ' scaled value first decimal place
    voltd2 VAR WORD   ' scaled value second decimal place
    'Allocate Variables for GPS: ####################
    TimeOut CON 2000
    hh VAR BYTE             'hours
    mm VAR BYTE             'minutes
    ss VAR BYTE             'seconds
    knots VAR WORD          'speed in knots (units)
    knotsten VAR BYTE       'speed in knots (tens)
    course VAR WORD         'heading
    latdeg VAR BYTE         'degrees latitude
    latmin VAR BYTE         'minutes latitude
    latsecs VAR WORD        'seconds latitude
    NS VAR BYTE             'north or south
    londeg VAR BYTE         'degrees longitude
    lonmin VAR BYTE         'minutes longitude
    lonsecs VAR WORD        'seconds longtitude
    EW VAR BYTE             'east or west
    d VAR BYTE              'day
    m VAR BYTE              'month
    y VAR BYTE              'year
    butt VAR BYTE           'pushbutton variable
    marker VAR BYTE         'toggle marker
    marker2 VAR BYTE        'UTC or BST
    MH     VAR BYTE[10]     'locator variables##########
    Idx       VAR BYTE                                 ;
    AddChar   VAR BYTE                                 ;
    Divisor   VAR BYTE[4]                              ;
    AARG_SAVE VAR BYTE[4]   '----------------###########
    nPos  var byte          ' digit variables
    nDig  var byte          '--------------------
    Idx2 VAR BYTE           ' Month variables
    X VAR BYTE                                  ;
    Char VAR WORD           '--------------------
    scroll VAR BYTE
    fix VAR BYTE            'GPS fix - Yes="A"  No="V"
    butt = 0                ;clear button variable
    marker = 0              ;set marker to zero for full info display at start
    marker2 = 0             ;set UTC
    PAUSE 50
    LCDOut $fe,$80,"    GPS Decoder     "   ; scrolling opening display
    LCDOut $FE,$c0," G8VLQ  March 2014  "
    Pause 2000
       for scroll = 1 to 20                 ' FOR..NEXT loop so message scrolls off the LCD to the left
                lcdout $fe,24               ' Scrolls display one position to the left
                pause 100                   ' Pause 150 ms
       next scroll                          ' do loop again till max count
                pause 1500                   ' Pause 1000ms
                lcdout $fe,1                ' Clears LCD
    Initialisation:    ;Leaving GPRMC as only sentence output
    HSEROUT ["$PRWIILOG,GGA,V,,,",13,10]
    PAUSE 100
    HSEROUT ["$PRWIILOG,GSA,V,,,",13,10]
    PAUSE 100
    HSEROUT ["$PRWIILOG,GSV,V,,,",13,10]
    PAUSE 100
    HSEROUT ["$PRWIILOG,ZCH,V,,,",13,10]
    PAUSE 100
    GPS: 'read GPS  #############################################################################################
    HSerIn Timeout,Clock,[wait("$GPRMC"),wait(","),DEC2 hh,DEC2 mm,DEC2 ss,wait(","),fix,wait(","),DEC2 _
    latdeg,DEC2 latmin,wait("."),DEC4 latsecs,wait(","),NS,wait(","),DEC3 londeg,DEC2 lonmin,wait("."),DEC4 lonsecs,_
    wait(","),EW,wait(","),knots,wait("."),DEC2 knotsten,wait(","),DEC3 course,wait(","),DEC2 d,DEC2 m,DEC2 y]
    IF marker = 1 THEN BigClock     ; keeps big clock running if value is 1
    IF marker2 = 1 THEN Plusone
    BUTTON Pbutton,0,100,0,butt,1,BigClockClear      ;button press to jump to fullscreen big clock
    GOSUB PLL         ;get the A/D value of pll control voltage
    GOSUB ShowMonth   ;show month as letters
    GOSUB Locator     ;maidenhead locator
    ;GOSUB BST
    GOSUB Clock       ;medium digit clock
    goto GPS          ; ##########################################################################################
    ;         MAIDENHEAD CONVERSION   --  Darrel Taylor
    Locator:
    MOVE?CF32  macro C, F       ; put a Floating Point Constant in an FP variable
        MOVE?CW  (C & 0xFFFF), F
        MOVE?CW  (C >> 16), F + 2
    MOVE?FF32  macro Fin, Fout  ; Copy an FP var to another FP var
        MOVE?WW  Fin, Fout
        MOVE?WW  Fin + 2, Fout + 2
    ;----[convert Longitude Sexagesimal to Decimal Degrees]-------------------------
    Aint = lonsecs : GOSUB ItoFA    ; decimal portion of Minutes
    Bint = 10000 : GOSUB ItoFB          ; divided by 100
    GOSUB fpdiv
    Bint = LonMin : GOSUB ItoFB       ; add whole portion of Minutes
    GOSUB fpadd
    Bint = 60 : GOSUB ItoFB           ; divide by 60
    GOSUB fpdiv
    Bint = LonDeg : GOSUB ItoFB       ; add degrees
    GOSUB fpadd
    IF EW = "W" THEN              ; if west of Prime Meridian
        @ MOVE?FF32 AARGB2, BARGB2    ; copy Float AARG to BARG
        Aint = 0    : GOSUB ItoFA     ; subtract from 0 to negate
        GOSUB fpsub
    Bint = 180  : GOSUB ItoFB         ; add 180
    GOSUB fpadd
    ;----[Have Longitude in AARG as Float]------------------------------------------
    FOR Idx = 0 TO 8 STEP 2
        SELECT CASE Idx
          CASE 0 : AddChar = "A"
                   @ MOVE?CF32 0x83200000, _Divisor   ; 20
          CASE 2 : AddChar = "0"
                   @ MOVE?CF32 0x80000000, _Divisor   ; 2
          CASE 4 : AddChar = "a"
                   @ MOVE?CF32 0x7B2AAAAB, _Divisor   ; 0.0833333
          CASE 6 : AddChar = "0"
                   @ MOVE?CF32 0x78088889, _Divisor   ; 0.00833333
          CASE 8 : AddChar = "a"
                   @ MOVE?CF32 0x73360B61, _Divisor   ; 0.000347222
        END SELECT
        GOSUB MH_Digit
    NEXT Idx
    ;----[convert Latitude Sexagesimal to Decimal Degrees]--------------------------
    Aint = latsecs : GOSUB ItoFA    ; decimal portion of Minutes
    GOSUB fpdiv
    Bint = LatMin : GOSUB ItoFB       ; add whole portion of Minutes
    GOSUB fpadd
    GOSUB fpdiv
    Bint = LatDeg : GOSUB ItoFB       ; add degrees
    GOSUB fpadd
    IF NS = "S" THEN              ; if south of equator
        GOSUB fpsub
    Bint = 90  : GOSUB ItoFB          ; add 90
    GOSUB fpadd
    ;----[Have Latitude  in AARG as Float]------------------------------------------
    FOR Idx = 1 TO 9 STEP 2
        SELECT CASE Idx
          CASE 1 : AddChar = "A"
                   @ MOVE?CF32 0x82200000, _Divisor   ; 10
          CASE 3 : AddChar = "0"
                   @ MOVE?CF32 0x7F000000, _Divisor   ; 1
          CASE 5 : AddChar = "a"
                   @ MOVE?CF32 0x7A2AAAAB, _Divisor   ; 0.0416666
          CASE 7 : AddChar = "0"
                   @ MOVE?CF32 0x770882F1, _Divisor   ; 0.00416666
          CASE 9 : AddChar = "a"
                   @ MOVE?CF32 0x723603EC, _Divisor   ; 0.000173583
        END SELECT
        GOSUB MH_Digit
    NEXT Idx
    ;----[Maidenhead conversion complete]-------------------------------------------
    ;----[Calculate one digit of the Maidenhead Locator]----------------------------
    MH_Digit:
        @ MOVE?FF32 _Divisor, BARGB2      ; put divisor in BARG
        GOSUB fpdiv                       ; do the divide
        @ MOVE?FF32 AARGB2, _AARG_SAVE    ; save AARG for modulus
        GOSUB FtoIA                       ; get integer
        MH(Idx) = Aint + AddChar          ; The Character
        Bint = Aint                       ; copy integer result to BARG
        GOSUB ItoFB                       ; convert it to float
        @ MOVE?FF32 _AARG_SAVE, AARGB2    ; restore previous AARG
        GOSUB fpsub                       ; subtract integer
        @ MOVE?FF32 _Divisor, BARGB2      ; multiply times original divisor
        GOSUB fpmul                       ; AARG now contains the remainder
    ;         Month routine
    ShowMonth:
        LCDOut $fe,$80+9,DEC2 d," "
        GOSUB Month
        LCDOut " ","20",DEC2 y
    Month:
        Idx2 = (m - 1) * 3
        FOR X = Idx2 TO Idx2 + 2
            LOOKUP X,["JanFebMarAprMayJunJulAugSepOctNovDec"],Char
            LCDOUT Char
        NEXT X
    ;                British Summer Time
    BST:
     IF m = 3 AND d = 30 THEN Plusone
     IF m >= 03 and m <= 10 THEN Plusone
    Plusone:
      IF m = 10 and d = 26 then UTC
      IF m >=10 and m <3 then UTC
      hh = hh + 1
      IF hh = 25 THEN hh = 0
      marker2 = 1
    UTC:
      marker2 = 0
    ;                PLL control voltage read result via Average routine
    PLL:             ' Measure GPSDO PLL control voltage for TCXO  - Approx 1.65v for lock
    ADCON0.2 = 1     ' Start conversion
    NotDone:
    pause 1
    IF ADCON0.2 = 1 Then NotDone
    value =((ADRESH * 256)+(ADRESL))
    gosub Average
    ' Calculate Voltage to 2 decimal places
    volt = value * 5/1024
    voltd1 = ( value * 5//1024) * 10/1024
    voltd2 = ((value *5 //1024) * 10//1024) * 10/1024
    lock:
    IF (volt=1) AND (voltd1 =6) AND (voltd2 =<9) THEN
    LCDOUT $FE,$C0+9,"Lock  "
    ClockClear:             ;Returning from Big Digit Clock, need to clear screen
    LCDOut $FE, 1           ;Clear Screen
    marker = 0              ;set marker to full info display
    GOTO GPS
    Clock:                   ;Display medium character time clock
    'Set up the digits (http://www.darreltaylor.com/files/CustChar.htm)
    LCDOUT  $FE,$40,$03,$03,$03,$03,$03,$03,$03,$03  ' Cust Char #0
    LCDOUT  $FE,$48,$0E,$1F,$1B,$1B,$1B,$1B,$1B,$1B  ' Cust Char #1
    LCDOUT  $FE,$50,$1F,$1F,$18,$18,$18,$18,$1F,$1F  ' Cust Char #2
    LCDOUT  $FE,$58,$03,$03,$03,$03,$03,$03,$1F,$1F  ' Cust Char #3
    LCDOUT  $FE,$60,$0E,$1F,$1B,$1B,$1B,$1B,$1F,$0E  ' Cust Char #4
    LCDOUT  $FE,$68,$1B,$1B,$1B,$1B,$1B,$1B,$1F,$0E  ' Cust Char #5
    LCDOUT  $FE,$70,$1F,$1F,$03,$03,$03,$03,$1F,$1F  ' Cust Char #6
    LCDOUT  $FE,$78,$1E,$1F,$03,$03,$03,$03,$03,$03  ' Cust Char #7
        nDig=ss dig 0 : nPos=7 : gosub displaydigit
        nDig=ss dig 1 : nPos=6 : gosub displaydigit
          npos=5 : gosub colon
        ndig=mm dig 0 : npos=4 : gosub displaydigit
        ndig=mm dig 1 : npos=3 : gosub displaydigit
          npos=2 : gosub colon
        ndig=hh dig 0 : npos=1 : gosub displaydigit
        ndig=hh dig 1 : npos=0 : gosub displaydigit
    LCDOUT $FE,$C0+9,"False Data "            ;displays
    IF fix = "A" THEN
    LCDOUT $FE,$C0+9,"Fix  ",#volt, ".", # voltd1,# voltd2,"v"            ;overwrites No Data
    GOSUB lock                                ;checks for pll lock if Fix valid
    LCDOUT $fe,$94," G8VLQ  ",STR MH\10," " ;STR is 10 digit Maidenhead Locator
    LCDOut $fe,$d4,DEC2 latdeg,$DF,DEC2 latmin,"'",DEC latsecs DIG 3,DEC latsecs DIG 2,_
    NS,"  ",DEC2 londeg,$DF,DEC2 lonmin,"'",DEC lonsecs DIG 3,DEC lonsecs DIG 2,EW
    ;$DF is degree symbol, some LCD displays have it in different location
    @ INT_RETURN
    ;RETURN
    displaydigit:
    if ndig=0 then gosub zero
    if ndig=1 then gosub one
    if ndig=2 then gosub two
    if ndig=3 then gosub three
    if ndig=4 then gosub four
    if ndig=5 then gosub five
    if ndig=6 then gosub six
    if ndig=7 then gosub seven
    if ndig=8 then gosub eight
    if ndig=9 then gosub nine
    Zero:
    	LCDOUT $FE,$80+nPos,1
    	LCDOUT $FE,$C0+nPos,5
    One:
    	LCDOUT $FE,$80+nPos,0
    	LCDOUT $FE,$C0+nPos,0
    Two:
    	LCDOUT $FE,$80+nPos,7
    	LCDOUT $FE,$C0+nPos,2
    Three:
    	LCDOUT $FE,$80+nPos,6
    	LCDOUT $FE,$C0+nPos,3
    Four:
    	LCDOUT $FE,$80+nPos,5
    Five:
    	LCDOUT $FE,$80+nPos,2
    Six:
    Seven:
    Eight:
    	LCDOUT $FE,$80+nPos,4
    Nine:
    colon:
          lcdout $fe,$80+nPos,$A5
          lcdout $FE,$C0+nPos,$A5
    BigClockClear:
    LCDOut $FE, 1           ;Clear original full data screen
    marker = 1              ;set marker for fullscreen clock loop
    'THICK DIGITS
    LCDOUT  $FE,$40,$07,$07,$07,$07,$07,$07,$07,$07  ' Cust Char #0
    LCDOUT  $FE,$48,$1C,$1C,$1C,$1C,$1C,$1C,$1C,$1C  ' Cust Char #1
    LCDOUT  $FE,$50,$0F,$1F,$1F,$1E,$1C,$1C,$1C,$1C  ' Cust Char #2
    LCDOUT  $FE,$58,$1E,$1F,$1F,$0F,$07,$07,$07,$07  ' Cust Char #3
    LCDOUT  $FE,$60,$1C,$1C,$1C,$1C,$1E,$1F,$1F,$0F  ' Cust Char #4
    LCDOUT  $FE,$68,$07,$07,$07,$07,$0F,$1F,$1F,$1E  ' Cust Char #5
    LCDOUT  $FE,$70,$1F,$1F,$1F,$00,$00,$00,$00,$00  ' Cust Char #6
    LCDOUT  $FE,$78,$00,$00,$00,$00,$00,$1F,$1F,$1F  ' Cust Char #7
    GPS2:
    HSerIn Timeout,Clock,[wait("$GPRMC"),wait(","),DEC2 hh,DEC2 mm,DEC2 ss]
    BUTTON Pbutton,0,100,0,butt,1,ClockClear     ;button press to change back to full info display
    BigClock:               ;Display Big Digit fullscreen clock
        nDig=ss dig 0 : nPos=17 : gosub displaydigit1
        nDig=ss dig 1 : nPos=14 : gosub displaydigit1
                        npos=13 : gosub colon
        ndig=mm dig 0 : npos=10 : gosub displaydigit1
        ndig=mm dig 1 : npos=7 : gosub displaydigit1
                        npos=6 : gosub colon1
        ndig=hh dig 0 : npos=3 : gosub displaydigit1
        ndig=hh dig 1 : npos=0 : gosub displaydigit1
    GOTO GPS2
    displaydigit1:
    if ndig=0 then gosub Zero1
    if ndig=1 then gosub One1
    if ndig=2 then gosub Two1
    if ndig=3 then gosub Three1
    if ndig=4 then gosub Four1
    if ndig=5 then gosub Five1
    if ndig=6 then gosub Six1
    if ndig=7 then gosub Seven1
    if ndig=8 then gosub Eight1
    if ndig=9 then gosub Nine1
    Zero1:
        LCDOUT $FE,$81+nPos,3     ;note added 1 to position for right side of character
        LCDOUT $FE,$C0+nPos,1
        LCDOUT $FE,$C1+nPos,0     ;note added 1
        LCDOUT $FE,$94+nPos,1
        LCDOUT $FE,$95+nPos,0     ;note added 1
        LCDOUT $FE,$D4+nPos,4
        LCDOUT $FE,$D5+nPos,5	;note added 1
    One1:
          LCDOUT $FE,$80+nPos," "
    	LCDOUT $FE,$81+nPos,0
    	LCDOUT $FE,$C0+nPos," "
    	LCDOUT $FE,$94+nPos," "
    	LCDOUT $FE,$D4+nPos," "
    	LCDOUT $FE,$D5+nPos,0
    Two1:
    	LCDOUT $FE,$C0+nPos,7
    	LCDOUT $FE,$C1+nPos,5
    	LCDOUT $FE,$95+nPos," "
    	LCDOUT $FE,$D5+nPos,7
    Three1:
    	LCDOUT $FE,$95+nPos,3
    	LCDOUT $FE,$D4+nPos,7
    Four1:
    	LCDOUT $FE,$81+nPos," "
    	LCDOUT $FE,$C0+nPos,4
    	LCDOUT $FE,$C1+nPos,7
    	LCDOUT $FE,$95+nPos,1
    	LCDOUT $FE,$D5+nPos,1
    Five1:
    	LCDOUT $FE,$81+nPos,6
    	LCDOUT $FE,$C1+nPos," "
    	LCDOUT $FE,$94+nPos,6
    Six1:
    	LCDOUT $FE,$94+nPos,2
    Seven1:
    Eight1:
    Nine1:
    colon1:
          lcdout $fe,$C0+nPos,$A5
          lcdout $FE,$94+nPos,$A5
    Rob.
    Dec 2011
    IO93ok
    Hi Darrel,
    Hmmm, looking at the various timings I don't see how this can be done.
    The NMEA string is output at the same point, the epoch of the PPS pulse, so the code is executing the string read when it also needs to start to display the 'advanced' time.
    As I see it at the moment, the code reads the gps string, then parses it, saving each piece to the assigned variable and runs the subroutines before initiating the display.
    As a test, I added two seconds to the seconds variable. Then comparing against a radio time signal it was almost the same. I say almost as it is not quite two seconds out in code execution.
    I suppose I could add a suitable pause value and bring it inline but I would have to test the offset, if any, over a period of operation. This assumes code execution always takes the same time to execute.
    Any ideas would be welcome.
    Rob.
    Hi Rob,
    I haven't been following this thread in detail so I apolgize if I'm suggesting something that's already been covered or isn't doable for whatever reason.
    Looking at the code you posted, and as you mentioned, you spend quite a bit of time in the ISR. I have two questions/suggestions.
    A) Why do you need to reload the custom characters each time? Wouldn't it be better to load them once at startup?
    B) Can't you simply set a flag in the ISR (ie UpdateDisplay = 1) which you then poll in the main loop? If the flag is set you update the display and reset the flag.
    Obviously there must be enough clock cycles between interrupts to do whatever needs to be done - no matter "where" it's being done (inside or out of the ISR).
    Doing (B) above you basically can't have the HSERIN statement within the main loop as it will "block" the processor for up to TimeOut ms (2000 in the code as posted). What you'd need to do is either introduce UART interrupt or simply poll the UART RX interrupt flag within the mainloop (provided the mainloop is "tight" enough to not overflow the UART receive buffer (2 bytes).
    Yes and no. It doesn't read, then parses it. HSERIN is parsing the string as the bytes comes in, one by one. If it didn't do that you'd have to have a recieve buffer as big as the complete NMEA string. But again, the code in your ISR takes considerable amount of time and it's quite possible that if an interrupt occurs in the middle of the HSERIN statment (quite possible) the ISR is stealing too much time so the the receive buffer (2 bytes) overruns and HSERIN "gets lost".
    At 4800 baud each byte is a about 2ms long so if your ISR takes more than 4ms to execute it will most definitely cause issues for the HSERIN. Seeing all those LCDOUT statements within the ISR and the subroutines it calls makes me think your ISR runs way up into the tens of ms.
    Dec 2011
    IO93ok
    Hi Henrik,
    Quite a bit to digest there. Good food for thought. Thanks.
    I missed the fact that the custom characters for the medium digits was constantly loading in the loop. I've moved that to the beginning now out of the loop, it is loaded at start up.
    The BigDigit clock did only load it's characters once then entered it's own loop, so that's taken care of.
    The main problem as I see it is that the gps string start occurs at the same time as the 'seconds' rise point. In the gps module the start of the rise of the PPS also triggers the NMEA string output. In other words the seconds epoch occurs for both. I don't know if it's possible to receive the string and trigger the display code at the same time. I was just trying to get to a more accurate time.
    The time is very close now anyway allowing for code run timing. I could add a small pause to bring it closer I suppose.
    Rob.
    Hi Rob,
    More thoughts.....
    Since, if I'm not mistaken, the time is parsed from the NMEA string using the PPS signal to initiate a display update will update the display with the time information from the last received string which is basically one second "old". I think that the best you can do really is to simply grab and parse the string and then update the display.
    If you're receiving the full 82byte NMEA string that will take ~170ms, add the actual display update code to that - you'll be a couple of hundred ms off.
  1. LAT replaces PORT command?
    By markscotford in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2011, 16:37
  2. Need Info for PBP?
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 30th January 2009, 07:44
  3. Replies: 1
    Last Post: - 27th July 2008, 06:14
  4. dmx info.
    By oscar in forum mel PIC BASIC Pro
    Last Post: - 8th May 2005, 11:54
