Auto-Dectect EEProm Size
Results 1 to 5 of 5
    Jun 2005
    Wisconsin
    Fair enough that does help. That being said I really do need a routine for those "baby" EEProms (2000 bytes is nothing to scoff at)
    I have read through the AN690 written by micro chip but am having a problem interpalting that to PICBasic.
    The example they give is written in a pseduo language:
    EXAMPLE 1:
    function TestIfSizeIs(Size N): boolean
    ( // is memory range 0..N-1 ?
    var TEMP;
    TEMP = Read( 0000);
    if ( Read( N) == TEMP)
    Write( 0000, TEMP+1)
    if ( Read( N) == TEMP+1)
    Write( 0,TEMP-1)
    return( TRUE)
    // else
    return( FALSE)
    ) //end function
    Having this function, we can then set up a loop to test
    memory sizes.
    In the case of the Standard I2C, we can loop and test
    from N=128 to N=2048 corresponding to models from
    24C01 up to 24C16 doubling N at each iteration as in
    the following:
    EXAMPLE 2:
    function StandardI2CMemDetect() : integer
    ( // returns a model number 1..16
    N = 128
    MODEL = 1
    loop
    if (TestIfSizeIs( N))
    break
    N=N*2
    MODEL=MODEL*2
    while(N<=2048)
    return ( MODEL);
    ) //end function
    Similarly, a function to measure Smart Serial memories
    will loop with N=4096 up to N=32768.
    Thoughts?
    Microchip Application Notes should really be taken with a liberal pinch of salt. Use them as a guide only as to the theory of what you're trying to achieve. Beyond that a lot of them are seriously misleading and erroneous.
    OK... I've thrown this together... deliberately written in a long-winded fashion so you can follow the code... try it... see what happens...
    Address var Byte
    CounterA var Byte
    EpromType var Byte
    Control var Byte
    For CounterA= 5 to 1 Step -1
    	Address=%11111111
    	Control=%10100000
    	If CounterA=5 then Control=%10101110
    	If CounterA=4 then Control=%10100110
    	If CounterA=3 then Control=%10100010
    	If CounterA=1 then Address=%01111111
    	I2CWRITE SDA,SCL,Control,Address,[CounterA]
    	Pause 10
    	Next CounterA
    Address=%11111111
    Control=%10101110
    I2CRead SDA,SCL,Control,Address,[EpromType]
    If you want to know where I got the figures from, just look at the table in the I2CREAD command in the PBP manual.
    This should write a byte in the last memory location of each of the five sizes of chip...
    Into a 24LC16 at address 2047 it will write a 5
    Into a 24LC08 at address 1023 it will write a 4
    Into a 24LC04 at address 511 it will write a 3
    Into a 24LC02 at address 255 it will write a 2
    and into a 24LC01 at address 127 it will write a 1
    Naturally if you have a 24LC16 you will end up writing into five memory locations, at each of the addresses. A 24LC08 will have four memory locations written to... with the one at 1023 being written to twice... first with a 5 then overwritten with a 4. The 24LC04 will have three addresses written to, but it's top one will be written to three times, first with a 5, then with a 4 and finally with a 3. The 24LC01 will only have one address written to, but it will be written five times, first with a 5, then a 4... etc until finally it gets a 1.
    When reading back, by selecting Address 2047, chips that cannot access that high will read-back the highest memory address that they can (ignoring the higher bits), and in so doing so, the variable EpromType will hold the number identifying the type of chip you've got installed.
    Like I mentioned in my original reply, all we've done is taken the same routine and principals and rehashed them for the Page addressing of the baby sized EEPROMs.
    I'm sure you can test this and report back if it works, as unfortunately I don't have anything smaller than a 24LC64 in stock.
    ooops... found a small error in the code which I corrected this morning 7am 17 June, so anyone copying the code before that please check.
    Dec 2007
    Paris
    I updated Melanie's code which did not behaved as expected on small EEPROMs. Here's the new topic: EEPROM automatic identification routine
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. How to define constants that specify eeprom addresses
    By DwayneR in forum mel PIC BASIC Pro
    Last Post: - 8th December 2009, 05:07
  3. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 04:17
  4. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 07:26
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 20:59
