HSEROUT & Sleep Question
Results 1 to 4 of 4
    Dec 2010
    Melbourne Australia
    Default HSEROUT & Sleep Question
    I have some code that sends commands via hardware serial port from one 18F14K50 to another. Due to UHF EMI (it's a UHF transmitter application) I need to put the master PIC into nap or sleep mode immediately after sending the command as you can actually hear the master's audio signature over the UHF's transmitted audio stream if it's in normal power mode (go figure).
    Anyway... The problem I have is when I place a sleep or nap command immediately after the HSEROUT, it doesn't appear to send the serial command or at least, not all of the serial command ie. it's likely missing the terminating character of the command thereby the slave processor isn't registering the command.
    If I replace the sleep or nap commands with pause or place a small pause between the HSEROUT & Nap/Sleep commands, it appears to work ok.
    So any ideas as to what is going on here?
    Troy
    Default Re: HSEROUT & Sleep Question
    You need to wait until the USART has finished sending all the bits before going to sleep.
    The TRMT bit (TXSTA.1) reads 0 (TSR full) while the USART is still shifting out data.
    Wait for it to go to 1 (TSR empty) before going back to sleep.
    TRMT   VAR TXSTA.1
    HSEROUT ["Hello World!"]
    WHILE NOT TRMT : WEND
    @ SLEEP
    Dec 2010
    Melbourne Australia
    Thanks Darren!
    Cheers,
    Troy
    Dec 2010
    Melbourne Australia
    Thanks Darrel! (not Darren) [whacking forehead]
    Troy
  1. Replies: 0
    Last Post: - 26th June 2010, 17:52
  2. Hserin & Hserout - Trying to blink an LED
    Last Post: - 24th May 2010, 12:25
  3. Sleep & nap
    By keymuu in forum mel PIC BASIC Pro
    Last Post: - 4th December 2008, 18:45
  4. Replies: 5
    Last Post: - 5th February 2006, 16:51
  5. interupt & Sleep Problem - HELP!!
    By Santana in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2004, 10:39
