Trigger 12v Solenoid Valve from a PIC
Results 1 to 7 of 7
    Smile Trigger 12v Solenoid Valve from a PIC
    I'm playing with PICs for a long time, but still a beginner.
    I want to build a hobby project that must switch a 12v Solenoid Valve on and off from a PIC running on a single battery.
    How would I do this without complicating the circuit?
    Default Re: Trigger 12v Solenoid Valve from a PIC
    The easiest way is to use a NPN transistor or a N-channel MOSFET and switch the lowside of the solenoid. Ie +12V -> Solenoid -> Switch -> GND.
    Drive the transistor with an output of the PIC. Don't forget to put a diode in reverse across the solenoid to clamp the inductive kickback when it's turned off.
    Google low side transistor switch and you should find plenty of information.
    Thank you Henrik!!!
    Will the PIC then also be able to run on the 12V?
    No, not directly on 12V it won't.
    You'll need a voltage regulator to bring down the battery voltage to a range that the PIC can operate on, what that range is is stated in the datasheet but usually 2.5V to 5V.
    will a 7805 do?
    Jan 2012
    Grid EN19MV
    Quote Originally Posted by koossa View Post
    will a 7805 do?
    It certainly will, as long as your PIC is designed for 5V
    -Stephen Hawking
    Thank you very much for your help!!!
  1. Replies: 8
    Last Post: - 19th August 2012, 04:43
  2. Schematic for Proportional Control of Hydraulic Valve?
    By Kirk Fraser in forum Schematics
    Last Post: - 12th March 2011, 07:53
  3. Solenoid Vavle
    By koossa in forum Off Topic
    Last Post: - 4th November 2008, 13:35
  4. Electric water valve
    By Christopher4187 in forum Off Topic
    Last Post: - 6th April 2008, 22:41
  5. Controlling a DC solenoid
    Last Post: - 23rd December 2007, 02:26
