Bug in my timekeeping code
Results 1 to 8 of 8
    Nov 2008
    Default Bug in my timekeeping code
    Well my numitron clock project is nearly complete. My problem is in the code to set the initial time. It didn't allow for the minutes to be set at 00. I fixed that by moving the "mm = mm + 1" line to the bottom of the setmm loop. That allows for 00 to be selected. Now when the timekeeping loop runs it changes 00 to 01 instantly. The time is set by a button that grounds a pin. It increments the digits until the pin is brought high again. When the hours and minutes are set, grounding the pin a third time starts the timekeeping loop. While setting the time the decimal points are lit up so you know the clock is not running. Here is what the code looks like:
    @	__CONFIG _FOSC_INTOSCIO & _WDTE_OFF & _WDT_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _IESO_OFF & _FCMEN_OFF
    OSCCON = %01110101			'Internal OSC 8MHz
    DEFINE OSC 8				'8MHz
    PORTA = 0					'
    TRISA = %00100100			'Porta.2 input
    WPUA = %00100000			'Weak pullup on Porta.5
    TRISC = 0					'
    PORTC = 0					'
    ANSEL = 0					'
    CMCON0 = %00000111			'Comparators off and I/O is digital
    ADCON0 = 0					'A/D is off
    CCP1CON = 0					'PWM and CCP off
    OPTION_REG = %01110110		'Timer0 on with 128 prescaler and weak pullups on
    INTCON = %11100000			'INTCON.2 overflow bit
    Include "modedefs.bas"
    hstro		VAR	portc.3		'Strobe line for hours chip
    mstro		VAR portc.2		'Strobe line for mins chip
    dat			VAR portc.5		'Data line for chips
    clk			VAR portc.4		'Clock line for chips
    ss			VAR byte		'Seconds
    mm			VAR byte		'Minutes
    hh			VAR byte		'Hours
    v1			VAR byte		'Display bits for tube V1
    v2			VAR byte		'Display bits for tube V2
    v3			VAR byte		'Display bits for tube V3
    v4			VAR byte		'Display bits for tube V4
    ss = 0
    mm = 0
    hh = 0
    shiftout dat, clk, 0, [$80, $80]	'Turn on decimal points to show its working
    pulsout hstro, 10
    pulsout mstro, 10
    waithere:							'Wait until a button is pressed
    while porta.5 = 1
    	@ NOP
    wend
    sethh:								'Routine for setting the hours
    if porta.5 = 1 then goto waitformm
    hh = hh + 1
    if hh = 13 then hh = 1
    v1 = hh DIG 1						'Breaks the double digits into singles
    v2 = hh DIG 0						'for the lookup table
    if hh < 10 then						'This makes the leading hour digit blank
    lookup v1, [$80,$E0,$D7,$F6,$EC,$BE,$BF,$F0,$FF,$FE], v1
    lookup v1, [$FB,$E0,$D7,$F6,$EC,$BE,$BF,$F0,$FF,$FE], v1
    lookup v2, [$FB,$E0,$D7,$F6,$EC,$BE,$BF,$F0,$FF,$FE], v2
    shiftout dat, clk, 0, [v2, v1]
    pulsout hstro, 10
    shiftout dat, clk, 0, [$00, $00]
    pulsout mstro, 10
    pause 750
    goto sethh
    waitformm:							'Wait until button is pressed for next loop
    while porta.5 = 1
    	@ NOP
    wend
    setmm:								'Routine for setting the minutes
    if porta.5 = 1 then goto settime
    if mm = 60 then mm = 1
    v3 = mm DIG 1						'Breaks up double digits into singles
    v4 = mm DIG 0						'for the lookup table
    lookup v3, [$FB,$E0,$D7,$F6,$EC,$BE,$BF,$F0,$FF,$FE], v3
    lookup v4, [$FB,$E0,$D7,$F6,$EC,$BE,$BF,$F0,$FF,$FE], v4
    shiftout dat, clk, 0, [v4, v3]
    pulsout mstro, 10
    pause 750
    mm = mm + 1
    goto setmm
    settime:							'Wait until button is pressed and starts the clock
    while porta.5 = 1
    	@ NOP
    wend
    startloop:							'Need this for the interrupt routine
    enable
    on interrupt goto timekeep
    main:								'Wait until counter overflows and interrupts
    	@ NOP
    disable
    timekeep:							'Actual timekeeping code. Pretty self explanatory
    ss = ss + 1
    if ss = 60 then
    	ss = 0
     	mm = mm + 1
    if mm = 60 then
    	mm = 0
    	hh = hh + 1
    if hh = 13 then hh = 1				'Change this to 25 for 24 hour time
    v1 = hh DIG 1
    v2 = hh DIG 0
    v3 = mm DIG 1
    v4 = mm DIG 0
    if hh < 10 then
    lookup v1, [$00,$60,$57,$76,$6C,$3E,$3F,$70,$7F,$7E], v1
    lookup v1, [$7B,$60,$57,$76,$6C,$3E,$3F,$70,$7F,$7E], v1
    lookup v2, [$7B,$60,$57,$76,$6C,$3E,$3F,$70,$7F,$7E], v2
    lookup v3, [$7B,$60,$57,$76,$6C,$3E,$3F,$70,$7F,$7E], v3
    lookup v4, [$7B,$60,$57,$76,$6C,$3E,$3F,$70,$7F,$7E], v4
    pulsout hstro, 10
    pulsout mstro, 10
    INTCON.2 = 0						'Clear interrupt flag
    resume startloop					'Go back to the do nothing loop
    And here is what it looks like
    Also if anyone is curious about the accuracy of the DS32KHZ oscillator chip, here it is on a freshly calibrated frequency counter
    Bombay, India
    Default Re: Bug in my timekeeping code
    You seem to be making a basic mistake. The value of minutes should run between 00 and 59 and not 01 to 60 as you have implemented. That is why you seem to have the minutes starting at 1 instead of going to 0.
    I also see the same mistake in the 24 hour mode where you say if hour = 25 then hour = 1. 24 hour time starts from 00:00 to 23:59.
    BTW, Nice PCB. I have some RCA Numitrons with 9 pin sockets. I was thinking about using them for a clock but the lifetime of the tubes isn't very good so I built a couple of nixie clocks with VM1000 tubes. Attacked is a photo.
    EN82fn
    Apr 2011
    Welches, Oregon
    I am wondering if it would be easier to keep only a TotalElapsedSeconds count and calculate HRS, MNS, and SDS as needed? I admit that I have not tried this, but it seems feasible. A word variable easily holds 13 hours (in seconds) and AM/PM or 24 hour clock flag provides convenient flags to indicate the 12 hour adjustment needed to avoid rollover (subtract 43200 at 46800). so:
    Just a little while after midnight (when the counter and flag resets to zero), TotalElapsedSeconds might be, say... 1146. In that case,
    HRS= 1146/ 3600 = 0
    MNS= 1146 - (HRS * 3600) / 60 = 19
    SCS= 1146- (HRS * 3600) - (MN * 60) = 06 - the time 00:19:06, is correct.
    Closer to noon, the total might be 43321.
    HRS= (43321/ 3600) = 12
    MNS= 43321- (HRS * 3600) / 60 = 02
    SCS= 43321- (HRS * 3600) - (MN * 60) = 01 - the time 12:02:01, is correct.
    At 1:00, the timer would be 46800 and subtracting 12 hours (43200 seconds) leaves TotalElapsedSeconds = 3600, or exactly 1:00:00 (or by adding 12, 13:00 in 24H mode). The caveat here is that the midnight adjustment and the 1:PM adjustment are not symmetric at 12 hours each - something of a kludge or, perhaps the time as 24:00:01 is of no issue to you? If not, then the time may rollover to 1:00:00 in even 12 hour cycles.
    To set the time, adding or subtracting 3600 adjusts the time by an hour, similarly adding or subtracting 60 changes the time a minute.
    I have considered this approach as a means of simplifying clock adjustments - say a user wants to subtract 10 minutes at only 5 minutes past the hour - in this way (I think) it may be simpler than fiddling with decrementing the hour separately.
    Nov 2008
    Dave, nice looking clock as well. The boards came from a place called OSH Park. They run batches of boards so the average time is about two weeks but the quality and price is great. Purple boards seem to be their trademark. If you are worried about longevity of the numitrons you can use the TLC5916 or similar chips from TI. They are meant for driving LEDs and have an adjustable constant current feature. For some reason the minute digits were both dimmer than the hours and needed slightly different resistor values.
    Nov 2008
    Forgive my ignorance but I can not see why during the timekeep loop that the minutes increment to 01 if they are set to 00 from the previous loop
    timekeep:
    ss = ss + 1
    if ss = 60 then
    	ss = 0
     	mm = mm + 1
    if mm = 60 then
    	mm = 0
    	hh = hh + 1
    v1 = hh DIG 1
    v2 = hh DIG 0
    v3 = mm DIG 1
    v4 = mm DIG 0
    if hh < 10 then
    pulsout hstro, 10
    pulsout mstro, 10
    Looking at this statement
    ss = ss + 1
    if ss = 60 then
    	ss = 0
     	mm = mm + 1
    The minutes should be at 00 until 60 seconds have been counted. Why is it jumping to 01 instead?
    Apr 2011
    Welches, Oregon
    The only other place I see you modifying the mm value is in the "setmm:" routine. You do not say if you are setting the clock (where the code in your OP sets mm = 1) or not.
    Nov 2008
    Now it makes more sense. Change
    to
    if mm = 60 then mm = 0
    Always the little stuff. Thanks.
  1. FOR..NEXT Loop Bug?
    By MSapper in forum mel PIC BASIC Pro
    Last Post: - 12th April 2011, 01:04
  2. Bug or something else
    By pedja089 in forum mel PIC BASIC Pro
    Last Post: - 7th February 2011, 14:58
  3. Did I find a bug or bug found me?
    By sayzer in forum mel PIC BASIC Pro
    Last Post: - 13th September 2008, 09:58
  4. PBP bug ???
    By boban in forum mel PIC BASIC Pro
    Last Post: - 19th March 2008, 16:30
