Using Floating Point to integer subroutines
Results 1 to 10 of 10
    Feb 2009
    Southern California
    Default Using Floating Point to integer subroutines
    I am having trouble using Microchips floating point routines, and I believe I'm just missing or misreading something simple. I don't actually want to do any math, but I am taking a float from a serial stream and want to display the value with 1 decimal point. I am hard coding an easy float into aint. I have used multiple online converters to verify that 50.0 = 0x42480000. I chose it because it is nice and round and does not use the parity bit for any of the bytes when I get to the point of going back to a serial line. I can't seem to get either ftoia or itofb to do what I thought they should do.
        include "fp1832l.bas"
        aint = $42480000
        serout2 portc.6,newbaud,["a hex value = ", hex8 aint]
        gosub ftoia
        serout2 portc.6,newbaud,["after conversion, a hex value = ", hex8 aint]
        bint = 10
        serout2 portc.6,newbaud,["b hex value = ", hex8 bint]
        gosub itofb     'convert to float
        serout2 portc.6,newbaud,["after conversion, b hex value = ", hex8 bint]
    For inta the hex value before is displayed correctly, $42480000, however the value after conversion is the exact same
    For intb, the hex value is as expected, $0000000A, but after the conversion it is $20000000. the online calculators show $41200000 is what a 10 should look like as a float.
    If there is an easier way to get what I need, I would appreciate it or just helping me see what I'm missing. Again, I don't necessarily need math. I just want to convert a single float into a couple of variables for each side of the decimal to display.
    Thanks for the clarification
    David
    Default Re: Using Flaoting Point to integer subroutines
    This is new teritory for me but looking at the FPREADME.TXT it seems to me that you're basically using the wrong variables.
    itofa Convert integer aint to floating point aarg
    itofb Convert integer bint to floating point barg
    fpadd Perform floating point addition: aarg + barg
    fpsub Perform floating point subtraction: aarg - barg
    fpmul Perform floating point multiplication: aarg * barg
    fpdiv Perform floating point division: aarg / barg
    ftoia Convert floating point aarg to integer aint
    The way I interpret this is that use ftoia you should load the floating point number into aarg (not aint, like you're doing) and retrieve the result from aint. For itofb, you should load the integer value to bint and retrieve the result from barg (not bint, like you're doing).
    Could that be it?
    Along with what Henrik said ...
    Quote Originally Posted by Luckyborg
    Most online convertors will use the IEEE floating point format. The format that is used in most PC languages.
    But Microchip uses a different format. And 50 in Microchip's format is 0x84480000.
    So if you are receiving IEEE formatted floats, you will not be able to convert them with the Microchip Floating Point routines without first converting to Microchip format.
    Feb 2009
    Southern California
    I gave it a try, but aarg and barg are not declared. I loaded up the FP1832L.bas file to take a look and found aint and bint, and the comments say that aint is the Long access to AARG. My understanding is that any call on aint will overwrite itself with the new value and the original value of aint is lost.
    I pretty much based my code on the what I found on melabs website http://melabs.com/resources/fp.htm
    You had my hopes up though. Thanks for looking
    David
    Feb 2009
    Southern California
    Thanks Darrel, I didn't realize microchip had its own format. Any idea on how to convert the IEEE standard?
    Feb 2009
    Southern California
    I found some C code that helped with the transition. When I get everything running I'll post it. I was able to translate the 42480000 to 84480000 but I'm still getting nothing out of the ftoia call. The value of aint is the same before and after. I looked through the include files and the best I can tell is aint should be the variable being changed.
    aint = S_RateL 'copy over
    serout2 portc.6,newbaud,["hex value = ", hex8 aint]
    gosub ftoia
    serout2 portc.6,newbaud,["after conversion hex value = ", hex8 aint]
    C code ???? Yuck!
    And you're still missing Henrik's point. The Float goes in AARG (starting at AARGB2) not Aint which starts at AARGB3.
    ;----[Variables]----------------------------------------------------------------
    A         VAR LONG
    B         VAR LONG
    A_Float   VAR LONG EXT : @A_Float = AARGB2 ;
    B_Float   VAR LONG EXT : @B_Float = BARGB2 ;
    ;----[macro Converts IEEE to Microchip FP format]-------------------------------
    IEEEtoMCHIP?NN  macro Nin, Nout
        MOVE?BB Nin, Nout
        MOVE?BB Nin+1, Nout+1
        MOVE?BB Nin+2, Nout+2
        MOVE?TT Nin+3,7, Nin+2,7
        MOVE?BA Nin+3
        RLNCF   WREG,W
        MOVE?AB Nout+3
        MOVE?TT Nin+2,7, Nout+3,0
    ;----[Test IEEE to Microchip conversion]---------------------------------------
    A = $42480000        ; 50 - IEEE
    GOSUB ShowConversion
    A = $C1CCF5C3        ; -25.62 - IEEE
    STOP
    ;----[Show conversion via HSEROUT]---------------------------------------------
    ShowConversion:
        HSEROUT ["IEEE = ",HEX8 A,13,10]
        @ IEEEtoMCHIP?NN _A, _B
        HSEROUT ["Mchip= ",HEX8 B,13,10]
        A_Float = B
        GOSUB FtoIA
        HSEROUT ["Aint = ",SDEC Aint,13,10]
        A = Aint
        A_Float = B       ; with 1 decimal place
        Bint = 10
        GOSUB ItoFB
        GOSUB fpmul
        GOSUB FtoIA
        HSEROUT ["       ",SDEC Aint/10,".",DEC1 ABS(Aint),13,10]
        A_Float = B       ; with 2 decimal places
        Bint = 100
        GOSUB ItoFB
        GOSUB fpmul
        GOSUB FtoIA
        HSEROUT ["       ",SDEC Aint/100,".",DEC2 ABS(Aint),13,10,13,10]
  1. Microchip 32bit floating point to integer conversion
    By timmers in forum mel PIC BASIC Pro
    Last Post: - 1st February 2011, 16:49
  2. Getting out of floating point
    By jcb344 in forum General
    Last Post: - 5th August 2008, 21:18
  3. Replies: 5
    Last Post: - 28th May 2008, 10:20
  4. Floating Point
    By jrudd in forum mel PIC BASIC Pro
    Last Post: - 15th May 2005, 14:19
  5. help floating Point!
    By Eric in forum mel PIC BASIC Pro
    Last Post: - 7th December 2003, 21:18
