Calibration Word & Processor Speed
Results 1 to 5 of 5
    May 2009
    Default Re: Calibration Word & Processor Speed
    The Define OSC 8 does not change the oscillator speed. I only tell the compiler the speed so that internal delays are calculated correctly. To change the internal oscillator speed the osccon register should be modified in you code. The define OSC x should then be set to match your selection as defined in the osccon register.
    Feb 2014
    Thanks, I should have know that !
    Apr 2011
    Welches, Oregon
    Quote Originally Posted by cyberroth View Post
    I don't see how. I mean no disrespect and not to be argumentative, but it is a frustration to me that there is this gray area in many procedures where PBP does some of the setup and leaves other parts to be done by the user. After some time I am catching on to the pattern and learning where to look when things don't work as expected, but ... from a beginner's standpoint... I could wish the manual was more clear in some respects on this. That said, I really enjoy using PBP and the process of learning it is enjoyable to me. Between reading carefully, scratching my head, and the outstanding help in these forums it is getting easier. After not too long it seems I might actually be able to create the things I envision! I hope you find this to be the case as well... and welcome to the forums!
    Feb 2014
    Not argumentative at all.
    I should have know that because I have considerable experience with another PIC based BASIC system where you can peek / poke the OSCON register to change the internal RC oscillator frequency. And , I did not read the PBP manual very thoroughly before starting.
    I do agree that the manual leaves a bit to be desired from a beginners standpoint. Aside from being unclear in places, I find some of the examples inadequate or irrelevant and not very "real word". But such is the case with a lot of products. Most of the effort goes into the software & marketing, while manuals / datasheets are an afterthought or a necessary inconvenience given a back seat . Good tech writing seems to be becoming a lost art.
    I have found that looking at others well commented code is a really good way to learn.
  1. Processor Speed Test?
    By Ramius in forum FAQ - Frequently Asked Questions
    Last Post: - 14th May 2011, 02:31
  2. High Resolution Timer & Speed Calculator
    By WOZZY-2010 in forum Code Examples
    Last Post: - 7th February 2010, 17:45
  3. 4 Low Speed PWM & HSERIN
    By MasterSparky in forum mel PIC BASIC Pro
    Last Post: - 8th October 2007, 20:12
  4. Replies: 0
    Last Post: - 26th October 2005, 07:47
  5. Inverting a Word & Assigning Array To Bytes
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 26th August 2005, 00:44
