Are Pic pins normally LOW when the PIC is un-powered??
Results 1 to 11 of 11
    Oct 2009
    Utah, USA
    Default Are Pic pins normally LOW when the PIC is un-powered??
    Hey group,
    Are PIC pins normally low (tied to ground) when the PIC is un-powered?
    I have an LED tied to my PIC and then through a resistor to +12v.
    I was planning on having the PIC supply a LOW to light the LED.
    But I am finding that my LED lights even when the PIC is not powered.
    Is that normal?
    The PIC is an 12F1822.
    Dwight
    Default Re: Are Pic pins normally LOW when the PIC is un-powered??
    Sounds like it is "Back Feeding" power into the PIC. Backfeeds can blow the PIC
    Sep 2009
    Hm, LED from PIC to +12V? Isn't that weird?
    PIC operate at 5.5V maximum.
    With appropriate dropping resistor under load voltage will be correct, but when pic pin is hi Q . . .
    Oct 2009
    Utah, USA
    Yeah, I have the PIC running off of 5V for Vdd.
    I did the calculation for the LED current limit resistor to take into account the 12V (using a 2700 ohm resistor) for approx 5ma LED current.
    I thought the PIC could just be a source of Gnd (LOW) when I wanted to turn the LED on.
    I had assumed that the port pins would be in a High Impedance state when powered down, and until configured otherwise.
    Guess I'll have to insert a transistor in the ckt to control the LED.
    Anybody else had any experience with how the I/O pins behave when the PIC is powered down??
    thanks
    Dwight
    Oct 2009
    Utah, USA
    Now that I think about it...
    Even if the pins were high impedance while powered down, the way I had wanted to supply ground (LOW) to light the LED would not have worked because when I wanted to turn the LED off, by making the pin HIGH, that HIGH (5 V) would still have been lower (with respect to the +12V) and so the LED would have seen +7v across it.
    Back to the drawing board
    Dwight
    With pic powered down, I don't think you can supply voltage/current to most all pins. The limit diodes direct the current back to Vdd powering up the device and probably not run the program properly.... per Archangle.
    don
    Most pins on a PIC can drive hi efficiency LEDs directly. Either connect the LED to 5V instead of 12V, or flip the LED and connect it to ground. Size the resistor for 3-5 mA of current at 5V.
    Tim Barr
    Sep 2010
    Las Vegas, NV
    I'm away from my computer with a schematic drawing program so I hope this conveys my idea adequately. With no power to the PIC the LED would be powered on by the 12VDC thru resistor to ground. When PIC is powered a HIGH of more than 3ish VDC at the PIC pin would be enough to turn the LED off. The diode to the PIC would protect the PIC from sinking or sourcing current from the 12VDC source.
    12VDC
    Resistor
    K--Diode-A---PIC pin
    LED
    Ground
    I hope I'm using some semi-solid logic in this idea but if this isn't a good idea please let me know.
    Last edited by AvionicsMaster1; - 24th February 2014 at 21:28. Reason: formattting of components
    with what you describe, the LED won't turn off.... 3vdc'ish on led from pic will just light the LED. There are small (6 or 8 pin) normally-closed (form B) solid state relays, then the PIC energizes the SSR to turn off the led.
    don
    Sep 2010
    Las Vegas, NV
    OOps! Sounded good when I wrote it. I hope I get it right next time. Sorry about that.
  1. How can a battery powered PIC turn itself off?
    By tekart in forum mel PIC BASIC Pro
    Last Post: - 9th August 2012, 10:44
  2. All PIC pins outputting low voltage
    Last Post: - 1st July 2010, 13:31
  3. PIC powered by capacitor for 0,5 second
    Last Post: - 25th August 2007, 09:23
  4. PIC-Powered Timer Project
    By T.Jackson in forum Schematics
    Last Post: - 18th May 2007, 04:45
  5. Pic powered from USB?
    By Squibcakes in forum USB
    Last Post: - 26th June 2006, 00:03
