HPWM with zero duty cycle on PIC18F2550
Results 1 to 6 of 6
    Jan 2010
    Default Re: HPWM with zero duty cycle on PIC18F2550
    I have attempted to attach the code. I couldn't figure out how to insert it.
    I have an autocad wiring diagram but haven't figured out how to attach it or insert it yet.
    Sort of a humbling experience.
    thanks
    Feb 2014
    Consider this section of your code:
    'create a  +/- value centered at 512
        left1 = abs(analogleft-512)
        right1 = abs(analogright-512)
        'scale value and create centered deadband of +/-10
        'value should fall between -10 and 256 for duty cycle
        dutycycleleft = ((left1 * 52)/100)-10
        dutycycleright =  ((right1 *52)/100)-10
    PBP only supports unsigned integers, meaning negative numbers are not supported. There can be no "-10"
    For example, you have a word variable "dutycycleleft". As a word, it can hold a value from 0 to 65555. If the current value is 5 and you subtract 10 then the variable will underflow by 5 and become 65531 instead of -5. This will cause the PWM to go full on.
    A quick and dirty way to fix the code is to take this from your code:
    if dutycycleleft < 1 then       'if dutycycle is between -10 and 1
           dutycycleleft = 0         'then it equals zero
    And change it to:
      if dutycycle left > 300 then
          dutycycleleft = 0
    Do the same for dutycycleright
    Try this and let me know how it works out
    Feb 2011
    if dutycycle left > 255 then
    dutycycleleft = 0
    Or whatever -- HPWM value must be 0 to 255.
    Feb 2011
    if dutycycle left > 32777 then
    dutycycleleft = 0
    elseif dutycycle left > 255 then dutycycleleft = 255
  1. Duty Cycle
    By Gord11 in forum mel PIC BASIC Pro
    Last Post: - 29th September 2011, 09:53
  2. how to generate 83.33khz with 16.7% duty cycle?
    By donatelo in forum mel PIC BASIC Pro
    Last Post: - 23rd September 2008, 18:08
  3. How can I measure Duty cycle ?
    By MaxiBoost in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 16:02
  4. PWM _ Duty Cycle in Tenths
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 17th May 2004, 13:09
  5. Duty Cycle Dilemmas
    By crankshaft in forum mel PIC BASIC Pro
    Last Post: - 27th February 2003, 13:40
