I set the tris register to output and the port latch to low (I drive the LED by outputing low).
By setting the tris and port, shouldn't that stay in the state I set until a reboot or a part of code changes the state again?
I was told at some point that it's good practice to set your ports to 0 then set them to whatever you need after the rest of your registers are set. Maybe I was mis-informed on that but that is why I did it.
The processor is not re-setting for sure. I know this because there is an initial bootup sequence it goes through when booted up which would make it immediately clear that the processor reset.
I am hoping to get back in the office later and upload the routine it's jumping to although its just a simple repeat/until then returns. There are some pause and pauseus functions in there. Could that be an issue?
