EPIC Programmer running hot.
Results 1 to 8 of 8
    Default Epic cooler
    The Epic current draw is 140mA. with the red programming LED on. When the Led is off the current is 40mA. So far it's working OK. The heat sinks are working well. The plastic cases of both TO-220's are much cooler to the touch. Thanks all. JS
    Italy
    Hi!
    With a power dissipation of 0.35 Watt your LM317/TO220 doesn't need a heat sink.
    How to calculate:
    PD MAX = TjMAX − TaMAX
             _____________
                 Rja
    PD MAX = Maximum Power Dissipation (Watt)
    TjMAX= maximum junction temperature (°C)
    For the LM317/TO220 is 125 °C.
    TaMAX= maximum ambient air temperature (°C)
    Room temperature or temperature inside enclosure, example 30°C.
    Rja= thermal resistance from junction to ambient without heat sink (°C/W)
    For the LM317/TO220 is 50 °C/W.
    125 − 30
    __________   = 1.9 Watt
       50
    1.9 watt is the maximum power dissipation of the LM317/TO220 without a heat sink.
    (If you use the LM317 at TjMAX its life will be reduced).
    In your case the input voltage of the LM317 is 16V and the output voltage is 13.5V.
    The voltage difference is 2.5V. (16V - 13.5V).
    The current is 140 mA. (0.14A)
    The power dissipation of your LM317 is:
    2.5V * 0.14 = 0.35 Watt
    Best regards,
    Luciano
    Italy
    The 13.5 volt (Vpp) is only a reference voltage, the PIC generates it's own internal
    programming voltage. Therefore the current of 140 mA is drawn also from the 5V regulator.
    (In reality it is less than 140 mA because some current is used by the programming LED).
    The LM7805/TO220 Rja value is 50 °C/W and its TjMAX is 125 °C.
    (Same as the LM317/TO220, see previous post).
    The input voltage of the LM7805 is 13.5V (verify that) and the output voltage is 5V.
    The voltage difference is 8.5V. (13.5V - 5V).
    The current is 140mA when programming and 40mA when not programming.
    When programming, the power dissipation of the LM7805 is:
    8.5V * 0.14 = 1.19 Watt
    When not programming, the power dissipation of the LM7805 is:
    8.5V * 0.04 = 0.34 Watt
    For the LM7805/TO220 the power dissipation is most of the time 0.34 Watt so
    there is no need for a heat sink.
    Luciano
    scorpion's Avatar
    scorpion Guest
    mine always gets hot. not hot enough to burn my fingers... but i cant feel heat in the tips of my fingers anymore. haha
    I have also had to replace the '7407 a couple of times.
    other than thats its been ok... one thing though. never leave it plugged in if youre not using it esp. if you just turned on your computer and havent run the epic software yet.
  1. epic programmer to lcd
    By rdxbam in forum General
    Last Post: - 3rd November 2008, 23:35
  2. Epic Programmer
    By forzaazzurri in forum General
    Last Post: - 3rd October 2008, 16:47
  3. epic programmer not found ---HELP!
    By dmacq in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2008, 19:38
  4. Need the programmer EPIC software
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2007, 11:42
  5. EPIC Programmer - Works for all chips but the 16F876A
    By 4Lewis in forum mel PIC BASIC Pro
    Last Post: - 12th April 2006, 23:59
