PBP3 Timer and RS232
Results 1 to 4 of 4
    Apr 2011
    BELGIQUE
    Default PBP3 Timer and RS232
    Hello to all
    I thought of making a small quite simple interface but that does not turn(shoot) as I want.
    The program is realized in PBP3 and the PIC is programmed with one pickit3.
    I use a PIC16F1825, chosen as its programmable internal clock to 32MHz and I make him(it) turn(shoot) in 16MHz with the internal oscillator.
    A port RS232 TTL receiving "words" (in 100Kb/) representing the width of the impulse to take(bring) out on one other pine of the pic
    The entrance(entry) RS232 is on Rx, I use the instruction Hserin, I put a temporary billposter LCD, information arrives well at the pic.
    The problem is in the management of the timer.
    I have impulses got out of it but the width does not really depend on the mass received(successful) word of command(order).
    I know that I could use the "pulsout" without using the timer but it is not possible in my case because the information arrives too quickly in RS232 and I do not have time to receive information, to handle(treat) them, and to take out again them if I do not use the timer.
    Have you a track(runway)??
    Thank you in advance
    CLAUDY
    Default Re: PBP3 Timer and RS232
    Hi Claudy
    a small drawing showing how input and output signals behave ( un chronogramme, in our beloved French language ! ) would save loooooots of time, hair and coffee ...
    no need to add your English is somewhat terrible ... that obviously doesn't help either ...
    BTW Have my best wishes for this new year ...
    Apr 2011
    BELGIQUE
    Sorry.
    I wanted to help a friend
    Good evening
    OK ...
    I dug out the original Query ...
    the goal is to output a pulse whose length is given by the RS232 message received ...
    Here is the trail code ( excerpt ! )...
    DEFINE OSC 16 'Oscillator speed in MHz: 3(3.58) 4 8 10 12 16 20 24 25 32 33 40
    tmr1GE var  t1gcon.7
    TMR1ON  var  T1CON.0
    TMR1IF  VAR  PIR1.0       ' Alias RCIF (USART Receive Interrupt Flag)
    LED1  VAR  PORTC.1      ' Alias LED
    LED2  VAR  PORTC.2      ' Alias LED
    IN_SBUS var PORTC.5    'p 5
    S1  VAR  PORTA.5      ' p 2
    i   VAR  BYTE  ' loop counter
    ' voir fichier "PIC16F1825.INFO"
    'Config pour PIC16F1825
    'Configuration
        __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _MCLRE_OFF  & _CLKOUTEN_OFF
        __config _CONFIG2, _PLLEN_OFF & _LVP_OFF
    on interrupt goto timer_int
    disable
      osccon=%01111011    'page 70
      ansela=0    'page 126
      anselc=0
      option_reg=0   'page 185   bit7 à zéro pour pouvoir activer les résistances de pull up
      apfcon0=0   'page 121
      apfcon1=0   'page 122
      wpuc=%00100000  'page 137  pull up sur C5
       trisa=%11011111
       trisc=%11111001
    recom_test:
    gosub essai_timer
    gosub test_led
    led1=0
    debut:
    led2=!led2
    for i=1 to 100      'si je met "pause 100", la led régie par le timer clignote mais pas à la cadence du timer
        pause 1
        next i
    goto debut
    test_led:   ' teste les leds au début juste pour voir si le programme démarre
    for i=1 to 10
    led1=0
    pause 50
    led2=0
    pause 50
    led1=1
    pause 50
    led2=1
    pause 50
    next i
    disable
    timer_int:
    'TMR1ON=0
    led1=!led1
    tmr1h=200
    tmr1l=200
    'TMR1ON=1
    T1con=%00000101     'page 195
    'tmr1GE=1
    tmr1if=0
    resume
    enable
    essai_timer:
    ''pour timer1 :
    T1con=%00000100     'page 195
    tmr1h=128
    tmr1l=128
    intcon=%11000000    'page 90
    pie1  =%00000001    'page 91
    pie3  =0
    tmr1if=0
    T1con=%00000101     'page 195 lancer une première fois le timer
    'tmr1GE=1
    OKayyyyyyyyyyyyyyy
    I finally understood !!!
    It's a trail to tweak the FUTABA ( R/C systems ) SBus protocol ...
    output pulse is a classical servo signal ( 1.5ms +/- 500µs @ 50 Hz ) ...
    so, final goal is to convert a RS232 info into a corresponding R/C pulse .... or to be exact ... convert an RS232 stream ( 4 servo positions ? ) into ... multiple R/C pulses ( 4 ? )
    I wonder this kind of matter has already been treated here or aboard RC Groups forum ...
    Alain ( who has no interest in that except ... friendship ! )
  1. PBP3 and MCSP
    By Luckyborg in forum mel PIC BASIC Pro
    Last Post: - 25th March 2012, 16:44
  2. I really need some help with PBP3
    Last Post: - 26th February 2012, 17:05
  3. PBP3 and MPLAB 8.83
    By grahamg in forum mel PIC BASIC Pro
    Last Post: - 10th February 2012, 14:04
  4. Pbp3
    By rcbandwidth in forum mel PIC BASIC Pro
    Last Post: - 18th September 2011, 15:13
  5. What's with PBP3?
    Last Post: - 10th August 2011, 18:09
