SEROUT and HSEROUT
Results 1 to 7 of 7
    Jan 2012
    Default SEROUT and HSEROUT
    I'm working with 18F6720 and RN171 (WiFly). I need send commands to RN171 with Uart.
    Then I send
    serout PORTC.6,N9600,["$$$"]
    and RN171 don't reply
    but if i send
    DEFINE HSER_BAUD 9600
    hserout ["$$$"]
    then RN171 reply CMD (OK).
    Where is the problem?? SEROUT and HSEROUT don't work equally??
    best regards
    Sep 2009
    Default Re: SEROUT and HSEROUT
    Try mode T9600 for serout.
    Jan 2012
    with T9600 is the same
    Dec 2010
    It's likely in the configuration bits.
    Post your complete code.
    Jul 2009
    Ohio, USA
    Try SEROUT2
    Is USART also using port c? (haven't checked datasheet from phone).
    Analog on port c?
    Configs ok?
    Quote Originally Posted by karlosguay View Post
    Then I send
    best regards
    The short answer is No, UART is the HARDWARE serial port whereas serout & serout2 are bit banged serial routines. The hardware UART will receive or send data only on the Rx & Tx pins of the PIC. The bitbang serial ports will operate on nearly any port or pin. Debug is also a bitbang serial port and many will say the neatest and fastest of the bitbang routines. The UART will send & receive 2 bytes while code is doing something else. Not so with bitbang.
  1. Serout instead of Hserout
    Last Post: - 25th February 2013, 01:14
  2. Serout instead of Hserout
    Last Post: - 24th February 2013, 22:16
  3. Serin,Serout,Hserin,Hserout
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 28th June 2005, 10:27
  4. hserout VS serout
    By johnson in forum General
    Last Post: - 3rd August 2004, 20:50
  5. SerOut, SerOut2 or HSerOut
    By FrankM in forum mel PIC BASIC Pro
    Last Post: - 1st August 2004, 16:24
