Quote Originally Posted by aratti View Post
In post # 3 you wrote:
Which is in contradiction with your last post.
Al.
A poor solder joint that worked "sometimes". So, I replaced the LED thinking it was it initially. The re and re fixed the problem. I should have said a bad solder connection to the LED. But I only found this out after replacing the LED.
