Configurator
Results 1 to 28 of 28
Thread: Configurator
    Default Re: Configurator
    Charlie,
    The Melabs usb programmer program has a pull down menu for options.
    Un-check the "Update configuration from file". Now it will keep the configurations
    you selected and not reset these each time you flash the pic.
    I agree with Peter the Melabs USB programmer is the way to go. Many questions on this forum
    are on configurations problems. Melabs USB program has a pull down configuration check list for each
    pic supported. The negative is the price, I think it is about $80usd.
    Miami, Florida USA
    Quote Originally Posted by mark_s View Post
    Charlie,
    I agree 100%. The U2 USB Programmer makes your life a lot easier. I have been using it for years without any issues.
    Anonymous
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Admittedly the price may be a worry, but as far as I am concerned, $80 for the programmer is much better than $hundreds of pulling your hair out.
    All mine went years ago, so I figure I am in front.
    Peter Moritz.
    New South Wales,
    Australia.
    Dec 2010
    You can spend the money, or you can add a couple lines of code to your program. To each his own.
    The issue with using the programmer (assuming you have one that doesn't forget the settings after each use) Is that 6 months or a year from now, when you want to program another device with the same code, you have to dig through your notes to decide what to program the fuses to. If it's already in the file, you simply program.
    Honestly, I find the option names pretty intuitive, and spend less than 2 minutes at the start of a project deciding which options I want and adding them to the file. In fact, for the two devices I use most often, I have a generic file that sets fuses, turns off rarely used functions, sets up important registers and so on. The files are well commented in case I need to make changes, but are almost always more than 90% correct, and I can start coding right away.
    I did try out Darrel's program, and it was very good, but I found doing it myself to be not all that painful after the first few devices I played with.
  1. PIC Configurator
    By Ioannis in forum General
    Last Post: - 28th November 2013, 03:29
