However,
why does this code not. It receives nothing
Hserin 10000, start, [WAITSTR buffer\3]
I need to wait for the three characters from an Arduino
Code:' Hserin test ' For PIC 18F45K22 with PLL ' Compiler used: PBP3 ' Assembler used: MPASMX #CONFIG CONFIG FOSC = INTIO67 ; Internal oscillator block CONFIG PLLCFG = ON ; CONFIG PRICLKEN = OFF ; Primary clock can be disabled by software CONFIG FCMEN = OFF ; Fail-Safe Clock Monitor disabled CONFIG IESO = OFF ; Oscillator Switchover mode disabled CONFIG PWRTEN = OFF ; Power up timer disabled CONFIG BOREN = SBORDIS ; Brown-out Reset enabled in hardware only (SBOREN is disabled) CONFIG BORV = 190 ; VBOR set to 1.90 V nominal CONFIG WDTEN = ON ; WDT is always enabled. SWDTEN bit has no effect CONFIG WDTPS = 32768 ; 1:32768 CONFIG CCP2MX = PORTC1 ; CCP2 input/output is multiplexed with RC1 CONFIG PBADEN = OFF ; PORTB<5:0> pins are configured as digital I/O on Reset CONFIG CCP3MX = PORTB5 ; P3A/CCP3 input/output is multiplexed with RB5 CONFIG HFOFST = ON ; HFINTOSC output and ready status are not delayed by the oscillator stable status CONFIG T3CMX = PORTC0 ; T3CKI is on RC0 CONFIG P2BMX = PORTD2 ; P2B is on RD2 CONFIG MCLRE = EXTMCLR ; MCLR pin enabled, RE3 input pin disabled CONFIG STVREN = ON ; Stack full/underflow will cause Reset CONFIG LVP = OFF ; Single-Supply ICSP disabled CONFIG XINST = OFF ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode) CONFIG DEBUG = OFF ; Disabled CONFIG CP0 = OFF ; Block 0 (000800-001FFFh) not code-protected CONFIG CP1 = OFF ; Block 1 (002000-003FFFh) not code-protected CONFIG CP2 = OFF ; Block 2 (004000-005FFFh) not code-protected CONFIG CP3 = OFF ; Block 3 (006000-007FFFh) not code-protected CONFIG CPB = OFF ; Boot block (000000-0007FFh) not code-protected CONFIG CPD = OFF ; Data EEPROM not code-protected CONFIG WRT0 = OFF ; Block 0 (000800-001FFFh) not write-protected CONFIG WRT1 = OFF ; Block 1 (002000-003FFFh) not write-protected CONFIG WRT2 = OFF ; Block 2 (004000-005FFFh) not write-protected CONFIG WRT3 = OFF ; Block 3 (006000-007FFFh) not write-protected CONFIG WRTC = OFF ; Configuration registers (300000-3000FFh) not write-protected CONFIG WRTB = OFF ; Boot Block (000000-0007FFh) not write-protected CONFIG WRTD = OFF ; Data EEPROM not write-protected CONFIG EBTR0 = OFF ; Block 0 (000800-001FFFh) not protected from table reads executed in other blocks CONFIG EBTR1 = OFF ; Block 1 (002000-003FFFh) not protected from table reads executed in other blocks CONFIG EBTR2 = OFF ; Block 2 (004000-005FFFh) not protected from table reads executed in other blocks CONFIG EBTR3 = OFF ; Block 3 (006000-007FFFh) not protected from table reads executed in other blocks CONFIG EBTRB = OFF ; Boot Block (000000-0007FFh) not protected from table reads executed in other blocks #ENDCONFIG DEFINE OSC 64 ' Setup PLL for 64 MHZ OSCCON = %01110100 ; 16 mhz (NOTE: SCS=0 so PLL works) OSCTUNE.6 = 1 ; PLL enable Mhz * 4 ANSELA = 0 ANSELB = 0 ANSELC = 0 ANSELD = 0 ANSELE = 0 ' Set receive register to receiver enabled DEFINE HSER_RCSTA 90h ' Set transmit register to transmitter enabled DEFINE HSER_TXSTA 20h ' Set baud rate DEFINE HSER_BAUD 9600 DEFINE HSER_CLROERR 1 ' Auto clear over-run errors buffer Var byte[3] ' Storage for serial character Pause 2000 Hserout ["PIC - UP RUNNING :-)", 13, 10] ' Send text followed by carriage return and linefeed start: pause 10 mainloop: toggle PORTC.0 ' Alive LED Hserin 10000, start, [WAITSTR buffer\3] pause 10 Hserout [str buffer\3] Goto mainloop ' Do it all over again End
