Elapsed Timer Demo
Results 1 to 40 of 112
    Jun 2006
    Bangalore, India
    Question Having trouble getting accuracy
    Hi Darrel,
    I tried making a LCD clock with calender with the elapsed timer code, but the clock runs nearly 2 seconds slow per day.
    I've made some modifications to the Elapsed_INT.bas.txt file so attached that also with my code ...
    I dont know how to fix this error...
    What should i do?... try tweeking the TimerConst or something???
    Hi shahidali55,
    "tweeking the TimerConst" won't help. 1 count either direction will change the timing by more than you are off. @ 4mhz, 1 count will change the time by about 4 seconds per day.
    At 2 seconds per day, it works out to around 23 PPM (parts per million), which is within the normal 50 PPM tolerance of the crystal. Not to mention the +/- 100 PPM variance due to temperature.
    To get closer than that, you'll need to calibrate the crystal frequency. You may be able to use a small Trimmer Capacitor in place of one of the capacitors on the crystal. The size needed depends on your crystal, but 0-20pf will probably work.
    Other than that, you could simply add 1 second every 12 hours. But if you build more units, that could be problamatic since they won't all be the same.
    Here's a couple links to some more crystal info:
    http://www.circuitcellar.com/library...ujanos91/3.htm
    http://ww1.microchip.com/downloads/e...tes/00588b.pdf
    http://ww1.microchip.com/downloads/e...tes/00949a.pdf
    Jun 2006
    Bangalore, India
    Question
    I dont think the problem is with the oscillator.
    I noticed that the time loss takes place every time the hours increase...
    Could it be some flaw in the code execution?
    If its losing time on every change of the hour, and the total loss is 2 seconds per day, then each change of the hour would lose 1/12th or 0.083 seconds.
    @ 4mhz, that's 83,000 instruction cycles. No, I don't think it's accidently losing that many instructions to increment an hour. And, looking at the ClockCount interrupt routine, if that were the case, it would also happen on every second, minute, and day as well. Which it doesn't.
    Why don't you think it's the crystal?
    Have you measured the frequency?
    Jun 2006
    Bangalore, India
    Post
    when i run Josepino's code, on the same board with the same crystal, i do not get any error.
    This is why I think it is a fault in the software...
    Too bad the guy only gives out HEX files.
    Otherwise, we could see what special magic he has, to cancel out the tolerance of crystals.
    Jun 2006
    Bangalore, India
    Talking Finally, Got the accuracy
    Hi Darrel,
    Some where Josepino had mentioned on his site that he had used Roman Black's one_sec.asm routine in his clocks (maybe he mentioned this by accident).
    I tried making a similar program in PBP but had no success, till now.
    Finally i got the progam running. its the exactly same one_sec.asm routine running with instant interrupts, and guess what,... it worked, and really accurately...
    Its even more accurate than the Elapsed Timer...
    I'll post the code so that it may be useful for someone...
    (I'm not as mean and selfish as Josepino...
    and thanks a lot for the instant interrupts program...
    Chiao...
    Jun 2006
    Hi Guys.
    I'm writing a program to control a drag racing xmas tree and time the 1/4 mile but I need .0000 (ie thousandths) second accuracy.
    Looking a the ASM routine I'm wondering if I can just change the 100Hz freq to 1KHz by triggering the interupt more often.
    Will this work?
    Thanks and Regards
    Thirsty
    That should work.
    But .0000 would be Ten Thousandths of a sec. That'll be harder.
    Using a 12F675 I am getting wsave position request beyond ram_end errors how do I fix this?
    Quote Originally Posted by geckogrotto View Post
    Open the ASM_INTS.bas file and comment out the offending lines.
    The 12F675 only has 2 banks of RAM.
    Thanks got it
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 22:14
  2. Get elapsed time while TIMER samples pulses
    By RodSTAR in forum mel PIC BASIC Pro
    Last Post: - 27th March 2009, 16:27
  3. Elapsed Timer Demo in a PIC12F675
    By Leonardo in forum mel PIC BASIC Pro
    Last Post: - 21st November 2008, 00:01
  4. Totally Baffled with Elapsed Timer
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 11th June 2008, 21:01
  5. Darrel Taylor Elapsed Timer
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 13th March 2008, 01:22
