Elapsed Timer Demo
Results 1 to 40 of 112
    Eng4444's Avatar
    Eng4444 Guest
    Exclamation One question..
    This might sound strange for some of you and stupid for others... but i'll say it again, i do not have any previous knowledge in all this...
    i already asked how to make it work for PIC16876A with a 4 lines LCD.
    i got : 1. Set the DEFINEs to match your hardware.
    2. Add CMCON = 7 if using PORTA
    3. compile and run.
    i'm thankful for this.. but at that time, i didn't pay attention to what was written in the first post! :
    " Note2: They are written for use as the only interrupt in the program. If you need to use other interrupts as well, the program will have to be modified before it will work. "
    then, i opened the .zip file and found...4 files!
    ASM_INTS.BAS
    ELAPSED.BAS
    TEST_ELAPSED_LCD.pbp
    Tets_elapsed_ser.pbp
    So what to do with all these......? where to download each of them?....
    Naaa. Don't bother.
    Try Melanie's Olympic timer instead (cheers Darrel, you keally know how to make friends - Melanie). It doesn't have the ASM stuff to worry about.
    Or Paul's clock that doesn't even need interrupts.
    Jun 2006
    Just wanted to say thanks, works great on a 16F690.
    I was going to modify your program a bit, I have an application which uses count down timers, but I thought I should check with you, I noticed a copyright on the code.
    Mike
    Hi Mike,
    Glad it's working.
    No problem with the copyright.
    You're free to use it any way you want. Well, except posting it somewhere saying you wrote it
    Jun 2006
    Bangalore, India
    Question Having trouble getting accuracy
    Hi Darrel,
    I tried making a LCD clock with calender with the elapsed timer code, but the clock runs nearly 2 seconds slow per day.
    I've made some modifications to the Elapsed_INT.bas.txt file so attached that also with my code ...
    I dont know how to fix this error...
    What should i do?... try tweeking the TimerConst or something???
    Hi shahidali55,
    "tweeking the TimerConst" won't help. 1 count either direction will change the timing by more than you are off. @ 4mhz, 1 count will change the time by about 4 seconds per day.
    At 2 seconds per day, it works out to around 23 PPM (parts per million), which is within the normal 50 PPM tolerance of the crystal. Not to mention the +/- 100 PPM variance due to temperature.
    To get closer than that, you'll need to calibrate the crystal frequency. You may be able to use a small Trimmer Capacitor in place of one of the capacitors on the crystal. The size needed depends on your crystal, but 0-20pf will probably work.
    Other than that, you could simply add 1 second every 12 hours. But if you build more units, that could be problamatic since they won't all be the same.
    Here's a couple links to some more crystal info:
    http://www.circuitcellar.com/library...ujanos91/3.htm
    http://ww1.microchip.com/downloads/e...tes/00588b.pdf
    http://ww1.microchip.com/downloads/e...tes/00949a.pdf
    Jun 2006
    Bangalore, India
    Question
    I dont think the problem is with the oscillator.
    I noticed that the time loss takes place every time the hours increase...
    Could it be some flaw in the code execution?
    Jun 2006
    Hi Guys.
    I'm writing a program to control a drag racing xmas tree and time the 1/4 mile but I need .0000 (ie thousandths) second accuracy.
    Looking a the ASM routine I'm wondering if I can just change the 100Hz freq to 1KHz by triggering the interupt more often.
    Will this work?
    Thanks and Regards
    Thirsty
    That should work.
    But .0000 would be Ten Thousandths of a sec. That'll be harder.
    Using a 12F675 I am getting wsave position request beyond ram_end errors how do I fix this?
    Quote Originally Posted by geckogrotto View Post
    Open the ASM_INTS.bas file and comment out the offending lines.
    The 12F675 only has 2 banks of RAM.
    Jun 2006
    Bangalore, India
    Question Sorry
    Sorry for posting that same message again...
    I was getting an error message...
    The attachment wasn't uploading correctly...
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 22:14
  2. Get elapsed time while TIMER samples pulses
    By RodSTAR in forum mel PIC BASIC Pro
    Last Post: - 27th March 2009, 16:27
  3. Elapsed Timer Demo in a PIC12F675
    By Leonardo in forum mel PIC BASIC Pro
    Last Post: - 21st November 2008, 00:01
  4. Totally Baffled with Elapsed Timer
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 11th June 2008, 21:01
  5. Darrel Taylor Elapsed Timer
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 13th March 2008, 01:22
