Elapsed Timer Demo
Results 1 to 40 of 112
    It works like a charm, thank you vary much. Now I can finish making my waterbed temperature controller.
    Jul 2005
    Smile To Darrel
    Hi Darrel
    I was wondering if elapsed timer code is accurate enough to make a digital clock and calender, showing time and date.
    Hi crematory,
    That depends on the accuracy of the crystal being used, and the ambient temperature.
    And, you'd probably need to have some kind of backup battery, to keep it going during any power outages.
    I think I calculated it at around +/- 4 minutes per year with a standard 20mhz crystal. It was around 20 seconds/year with one of those temperature compensated TTL Oscillators.
    Jul 2005
    Smile
    Quote Originally Posted by Darrel Taylor
    Hi crematory,
    4 Minutes a year, that is more than acceptable for me, I will be happy with that in deed.
    I was wondering if you can through a hint for using the rest of interrupts in the PIC when using the elapsed timer code, shall I use your way to handle other interrupts, or what should I exactly do.
    Thanks Darrel
    I've been working on something that'll answer that question, but it's still in bits and pieces right now. I guess it's time to finish it.
    Give me a couple days to put it together. Hopefully it'll be worth the wait.
    Jul 2005
    Thumbs up That amazing Darrel
    Darrel,
    I will be waiting for the answer.
    Good luck
    Almost there. &nbsp; I keep getting sidetracked.
    I hope you're using MPASM. I've been unable to make it work with PM.
    Jan 2006
    Istanbul
    Hi crematory,
    Hi Darrel,
    Could you suggest a good "one of those temperature compensated TTL Oscillators" please ?
    Also, if aging for an oscillator is stated, say, +/-5ppm a year or +/- 100ppm a year, what would it mean in your elapsed timer application?
    Last question, if I modify your routine to work for 100years, forget about power failures etc., and use a good osc as you may suggest, what would be a possible problem as years pass by?
    Thanks.
    The way I understand it is that the Total PPM error stated for crystals includes 10 years of aging.
    Say you have a crystal with +/-50ppm tolerance. When you first install the crystal it will be very close to the specified frequency (+/-5ppm), and it's anticipated that in 10 years, the frequency will still be within the stated 50ppm @25°C.
    Most crystals have an aging of less than 5-10 ppm per year. If you've come across a crystal that has +/-100ppm per year, throw it in the garbage.
    For a recommendation, I'd still have to say the DS32KZ is the best for the price at less than $10.
    http://pdfserv.maxim-ic.com/en/ds/DS32kHz-DS32KHZS.pdf
    With an indoor application it will hold to +/- 2 ppm, which is 1 minute per year.
    For outdoor apps, it's 7.5 ppm, or 4 minutes per year.
    TCXO's for the CPU's osc at 10-20Mhz are more expensive, but some are really accurate. Like this one that holds to 0.28 ppm, or about 9 seconds/year. So after your 100 years it would only be off by 15 minutes. ($30US, 3.3V)
    http://www.conwin.com/datasheets/tx/tx236.pdf
    There are so many possible combinations of tolerance, compensation and time, it's difficult to give a direct answer. But for any of the possibilities, if you can come up with the anticipated PPM Error, this calculator will help to determine how much it would affect the long term timing of a clock.
    Press the Recalculate button after changing the Freq or Error.
    <table cellspacing="10"><tr><td valign="top"><OBJECT CLASSID="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" CODEBASE="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,40,0" WIDTH="400" HEIGHT="250" ><PARAM NAME="MOVIE" VALUE="http://www.pbpgroup.com/CrystalErr/CrystalPPM.swf"><PARAM NAME="PLAY" VALUE="true"><PARAM NAME="LOOP" VALUE="true"><PARAM NAME="QUALITY" VALUE="high"><EMBED SRC="http://www.pbpgroup.com/CrystalErr/CrystalPPM.swf" WIDTH="400" HEIGHT="250" PLAY="true" LOOP="true" WMODE="opaque" QUALITY="high" TYPE="application/x-shockwave-flash" PLUGINSPAGE="http://www.macromedia.com/go/getflashplayer"></EMBED></OBJECT></td><td valign="top">For normal crystals, the PPM tolerance is specified at 25°C. Temperature extremes in either direction can cause a 50ppm crystal to change as much as 100-300 ppm. Granted, those are extremes that would kill a human being, but somewhere in-between are the changes from summer to winter in an outdoor application.
    The TCXO (Temperature Compensated Crystal Oscillator) will actively adjust the frequency according to the temperature, so that the frequency is always within the stated PPM tolerance. It usually does this by changing the voltage to a Varactor Diode, which changes the capacitance on the crystal. While it does compensate for temperature, the relative aging of the device remains the same as an uncompensated crystal.
    </td></tr></table>
    Happy Holidays!
    Aug 2005
    Italy
    Exclamation Elapsed Timer @ 48 Mhz with USB.
    Hi Darrel,
    first of all compliments for this excellent job.
    I would use "DEFINE OSC 48", because I need to compile for PIC18F4550 using USB.
    And using USB in PBP we must set "DEFINE OSC 48" due to PLL...
    When I try, I always receive the error "Symbol not previously defined (TimerConst)".
    So I tried setting the right TimerConst in the "Elapsed_INT-18.bas" file...
    I read all in this thread, and tried using the TimerCalc form, but it seem is impossible getting: 10,000 "Ticks", 100 Freq and 48 OSC all together.
    So it means it's impossible using USB and Elapsed Timer at the same time ?
    Is there a TimerConst that work with osc @ 48 MHZ ?
    Mark
    Hi Mark, and thanks!
    Yes there is.
    In 2003 I hadn't heard of a 48mhz pic
    Hmmm, let's see here,
    pulling up mister_e's PicMultiCalc ... (Timer Helper page)
    http://www.picbasic.co.uk/forum/atta...achmentid=2957
    and ... uht oh, with the existing timer load routine, the best we can do is 99.999hz. Not so good for a long-term timer.
    But not a problem, increasing the timer reload time to 10 instructions (add 3 nop's), with a Timer1 prescaler of 2, the reload value is 5541.
    I'm sure that will elicit more questions, but I'll let you give it a go first.
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 22:14
  2. Get elapsed time while TIMER samples pulses
    By RodSTAR in forum mel PIC BASIC Pro
    Last Post: - 27th March 2009, 16:27
  3. Elapsed Timer Demo in a PIC12F675
    By Leonardo in forum mel PIC BASIC Pro
    Last Post: - 21st November 2008, 00:01
  4. Totally Baffled with Elapsed Timer
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 11th June 2008, 21:01
  5. Darrel Taylor Elapsed Timer
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 13th March 2008, 01:22
